Question about Pride Mobility Products Jazzy 1170 XL Plus
2 red blinking lights on control
Left motor "rebuilt" one batterie changed now 80 ah and 55 ah, it runned 2 days and back to 2 left side blinking lights. Disconnected batteries to see if it re-set same problem, please advise
thanks
Vic
  • 177 Answers
Hi. Why do you have two different sized batteries? When you charge them, they will not charge up evenly. You say it ran for two days, did you charge it each night or after the two days running? Batteries last the best if they are charged overnight after each days running. The two flashing lights might be a fault code. Can you tell us what controller is in the machine, we can look up the fault codes. Why was the left hand motor rebuilt? In power chairs and mobility scooters the motors develope a build up of carbon dust and copper bust from the brushes and commutator. This build-up causes a leakage of power from the wiring in the motor to the frame of the motor. If this happens it is possible to get a short developing between the two motors, which causes the controller to go into a fault mode.Good luck. Neil.
Posted on May 27, 2010
1988 Chevrolet k1500 350 v8 not getting signal to fuel injectors
So, it's the injector circuit. There is a 10 amp injector fuse in the fuse block, on left side, 4th one down. Check this fuse. It supplies constant power to both injectors, on the red wire to injector 1, and a white wire splice from this to injector 2. A steady 12 volts anytime key is in on, run, or start. You can check this with a test light or voltmeter. Ground the test light and probe injector connector's red wire on injector 1, and the white wire on injector 2-both should be hot with key on.
This may be why the noid light didn't blink. The noid light must have this steady power signal, and when the computer internally grounds the injector ground circuit for a split second, you get injector pulse-or a blinking noid light.
You can check the ground circuit separately with a test light also for each injector. Place the ground clip of test light on the POSITIVE battery post, and probe the blue (ground) wire on injector 1, the engine must be cranking over, and the test light should be blinking. Do the same for the green wire on injector 2. If the test light is blinking on both ground wires, with engine cranking-the ground circuit is good. You are sending power down the ground wire to computer, and when the computer grounds the circuit, the tester will light up-it will blink because the computer only momentarily grounds the circuit to cause pulsing of the injectors.
Feb 18, 2014 | 1988 Chevrolet K1500
My digital frigidaire refrigerator isnt cooling properly so did some research think it might be start relay got a 3 in 1 but know how to put that on any suggestion...How do I put the 3 in 1 in place o
You do not need the capacitor or the overload or the relay,The kit has all of them thangs built in to it. Basically that hard start has 5 wires. You put red to the right(run). Black at the top (common) and white to the left pin(start). All you need to do with the other 2 wires is hook 120 volts to them. Usually your ice box will have a red and a white wire coming down from the cold control. That is what you hook the 2 ***** wires 2. If you have a condenser motor to contend with then hook it up parallel in the circuit. What do I mean by parallel? Instead of running everything in one big continuous circle you piggyback the fan motor on top of the hard start power wires so that both items will get the same amount of power.
Nov 03, 2012 | Refrigerators
Scooter charges but doesnt run
could be one of many problems is the battery indicator blinking on the control box if so
check on/off switch
check seat switch
free wheel switch located in the slot on the back right side of the battery cover check for proper position
also there are 2 small lights just to the lower left and lower right of the battery indicator that will blink a error code examples are 1blink pause 2 blinks or 2 blinks pause 2 blinks and many others if you have the error codes contact amigo for a help 1-800-my-amigo
Aug 24, 2012 | Amigo RD 3-Wheel Scooter w/33AH Batteries...
Jag 2005 diesel 2.0 where is the fuse front right headlight
found this, hope it helps!
X-Type Fuse/Relay identificationpicture.php?albumid=77&pictureid=795
picture.php?albumid=77&pictureid=796
Engine compartment fuse box - fuses
Fuse Fuse Rating Colour Circuit
No. Type (amps)
F1 Cartridge 20 Blue Dip beam, High Intensity Discharge (HID) light relay.
F2 Cartridge 50 Red Ignition relay feed.
F3 Cartridge 60 Yellow ABS.
F4 Cartridge 30 Pink Rear window heater/heated mirrors relay.
F5 Cartridge 30 Pink Automatic transmission control module relay.
F6 Cartridge 30 Pink Heater blower relay.
F7 Cartridge 50 Red Power supply to passenger compartment fuse box.
F8 Cartridge 80 Black Blower module.
F9 Cartridge 50 Red Engine management system power relay.
F10 Cartridge 20 Blue Headlight power wash pump relay.
F11 Mini Not used.
F12 Mini Not used.
F13 Mini 30 Green Heated front screen right-hand side.
F14 Mini Not used.
F15 Mini 30 Green Heated front screen left-hand side.
F16 Mini 20 Yellow Left-hand dip beam, day time running lights, autolights.
F17 Mini 20 Yellow Right-hand dip beam, HID lights.
F18 Mini 20 Yellow Throttle motor supply.
F19 Mini 15 Blue Screenwash pump, rain sensing system.
F20 Mini 5 Tan Navigation display.
F21 Mini 15 Blue Side (Parking) lights.
F22 Mini 20 Yellow Accessories relay.
F23 Mini 10 Red Air conditioning compressor clutch.
F24 Mini 15 Blue Door lock power.
F25 Mini 15 Blue Direction indicators (GEM).
F26 Mini 15 Blue Horns.
F27 Mini 10 Red Automatic transmission control module, transit relay.
F28 Mini 15 Blue Ignition switch.
F29 Mini 30 Green Starter motor solenoid.
F30 Mini 30 Green Accessory sockets.
F31 Mini 10 Red Engine management relay coil.
F32 Mini 5 Tan Engine management control.
F33 Not used.
F34 Diode D3 Not used.
F35 Diode D2 Engine management control relay diode.
F36 Mini 10 Red Canister purge valve, airflow meter, throttle motor relay, power wash relay, air conditioning relay.
F37 Mini 15 Blue Engine management system, blower speed controller, road speed sensor (if fitted).
F38 Mini 30 Green Oxygen sensor heaters A.
F39 Mini 5 Tan Variable intake valves.
F40 Mini 15 Blue Automatic transmission control module.
F41 Mini 10 Red Injectors.
F42 Mini 30 Green Oxygen sensor heaters B.
Passenger compartment fuse box - fuses
No. Type (amps)
F60 Mini 20 Yellow Power windows left-hand.
F61 Mini 20 Yellow Power windows right-hand.
F62 Mini 7.5 Brown Rear fog lights.
F63 Mini 7.5 Brown Right-hand - front side light, side markers, rear tail lights.
F64 Mini 7.5 Brown Left-hand - front side light, side markers, rear tail lights.
F65 Mini Not used.
F66 Mini 30 Green Left-hand power seat switches, heater module, lumbar pump.
F67 Mini 5 Tan Battery back-up sounder, transit relay, HID/dip relay, automatic transmission control module.
F68 Mini 15 Blue Cigar lighter.
F69 Mini 7.5 Brown Telematics display, In-car entertainment head unit, antenna module, navigation module, VICS (Japan), parking aid, amplifier premium 1 system, phone handset, phone power supply module, instrument cluster, PATS module.
F70 Mini 30 Green Right-hand power seat switches, heater module, lumbar pump.
F71 Mini 15 Blue VICS (Japan), telephone transceiver, telephone handset.
F72 Mini 15 Blue Radio head unit, CD player, navigation electronic control module, Jaguar diagnostic connector/OBDII connector.
F73 Mini 15 Blue Sunroof unit/module.
F74 Mini 15 Blue Instrument cluster, Premium ICE amplifier unit.
F75 Mini 7.5 Brown Mirror fold back module, battery back-up sounder, air conditioning ECU.
F76 Mini Not used.
F77 Mini 7.5 Brown Left-hand and right-hand heated seats modules.
F78 Mini 5 Tan Phone power supply.
F79 Mini 10 Red Automatic transmission only: Reverse lights, reverse light switch, reverse park aid, electrochromic mirror, instrument cluster.
F80 Mini 7.5 Brown Park interlock, heater switch, OBDII, blower relay.
F81 Mini 20 Yellow Fuel pump control module.
F82 Mini 10 Red Variable power steering, alternator.
Manual transmission only: Reverse lights, reverse light switch reverse park aid, electrochromic mirror, instrument cluster.
F83 Mini 15 Blue Not used.
F84 Mini 5 Tan Instrument cluster, passenger airbag fascia light, seat weight sensor.
F85 Mini 7.5 Brown Right-hand high beam light.
F86 Mini 7.5 Brown Left-hand high beam light.
F87 Mini 15 Blue Front fog lights, master light switch.
F88 Mini Not used.
F89 Mini Not used.
F90 Mini 7.5 Brown Stop lights, cruise control.
F91 Mini 10 Red Sunroof, electrochromic mirror, power windows, power mirrors.
F92 Mini 10 Red Manual transmission cruise control clutch switch, ignition coils, automatic transmission rotary switch.
F93 Mini 30 Green Windscreen wipers.
F94 Mini 20 Yellow HID module.
F95 Mini 10 Red Airbag restraints module.
F96 Mini 7.5 Brown ABS module.
F97 Mini 7.5 Brown Glove compartment light, instrument cluster lights, licence plate lights.
F98 Mini 10 Red Mirror heaters.
F99 Mini 10 Red Luggage compartment light, footwell lights, puddle lights, vanity mirror lights, interior lights, aircon control unit, roof console unit.__________________
02 X-type 3.0l
04 S-type 3.0l
07 X-type 3.0l
Apr 05, 2012 | 2004 Jaguar X-Type
Error codes for 1991 dodge spirit
Turn the key to run then off, back to run, then off, then to run and leave it on. The check engine light will be on and will then go off and then on again according to the codes the engine controler happens to have in it. If the check engine light was on when you stopped the car, then there is at least one code in the controler. The light will blink the codes like this.
Cycle the key three times and leave on on the third time. light on for about 3-4 seconds then goes out for about 2 seconds and then blinks one time and goes out for 3 seconds this is for the no.1. Then the light blinks 3 times and goes out for about 3-4 seconds. You have the code 13. You could have a whole string of codes in the controler memory. It could be something like this. key cycled 3 times, light on for 3-4 seconds, then blinks 1 time, pause, 3 times, longer pause, 2 times ,pause 4 times, longer pause, then 5 times, pause 5 times the goes out.
This is code ; 13,24, 55. code 55 isn't really a code. It just tells you it's the end of any codes the controller has.
If you disconnect the battery and hook it back, you will have code 13 which simply mean 'battery disconnect'. It will errace it's self after several starts if it's not disconnected again. If you cycle the key and you get 55, this means there are no codes recorded at this time.
You will allways get 55 when checking for codes wheather there are fault codes or not. The light on for a few second before the codes start flashing is only a bulb check. Some codes like 13 will not turn the check engine on, but but will leave a code for diagnostic purposes only. If you have the check engine light on and accellerate and the light begains to blink, then the controller is telling you that you have an engine miss and are running the chance of burning out you're catalatic converter if you continue driving. Sometimes its advised to disconnect the battery after you have recorded the codes.
This will erase all codes that are present but were generated by conditions that aren't pertanent to the present condition. and then the codes that come back are the real ones to address.
This link: http://minimopar.knizefamily.net/fault/index.html
Contains the entire list of Chrysler Engine Error Codes.
Mar 03, 2011 | 1991 Dodge Spirit
My Jet 3 has new batteries and they fully charge. When I am outside of the house the chair just cuts off like you turned of a switch. Leave be a while and it runs again. when you push reset button after it...
Alvin you have a left motor problem and it could be a loose connection Check that the left motor connector is tight and that if you move it the lights blink then there is a problem with the wiring to the left motor. If Medicare paid for your chair then they will pay for 80% of the repair costs contact your provider to see if they will repair it or contact a repair service like Roadrunner Mobility @ 1-800-467-2668 Hope this helps
Mar 01, 2011 | Pride Used Mobility Jet 3 Power Wheel...
I just replaced the batteries in my Jazzy 1170 PLUS. Now my speed control lights blink constantly and the chair is totally unresponsive.I have double checked to be sure the freewheel levers are totally...
According to my 1170 manual the flashing lights are error codes. 1 red = low batt., 2 red = left motor disconnected, 3 red = Left motor wiring fault, 4 yellow = Right motor disconnected, 5 yellow = right motor wiring fault, 6 yellow = Inhibit active, 7 yellow =possible joystick fault, 8 green = possible controller fault, 9 green = Solenoid brake fault, 10 green = high batt. voltage
Feb 13, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
Ctm hs 2800 turn on key light come on and blink 7 time then go out push joystick foward motors kicks in and out and lights blink 7 times and then frist red light keeps flashing
1. Stall Timeout, Joystic out of neutral
2. Battery Voltage too over 32VDC hi or too low under 17VDC
3. Left motor Fault
4. Right Motor Fault
5. Left Brake Motor fault
6. Right Brak Motor fault
7. Shark Control Module Faul****this will be your problem***
8. Power Module Faul
9.Shark Module Faul
Contact me Direct 909-590-1388 x115 CTM HOMECARE OFFICE
Oct 31, 2010 | Ctm HS-2800 Power Wheelchair
Jazzy wheelchair 1170....left side stops and sticks,.
Change out the motor brushing on the motor that is not working, or get a nail filer & rub it against the metal pins the back of the chair for a better connection
Nov 30, 2008 | Pride Mobility Products Jazzy 1170 XL Plus
Pride Mobility Products Jazzy 1170 XL Plus Logo
135 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
