Question about Amana RFS12MPS Microwave Oven
Microwave work for 2 minut and turns off and after 5min its turns back on and do same thing
  • Amana Master
  • 9,047 Answers
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
An overheating magnetron can be due to:
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (US homes should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
I would suspect a failure or the fan, clogged filter or bad magnetron.
You didn't mention your brand or model number, so I'm limited to general advice.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 28, 2010
Testimonial: "it was very helpfull "
Lost power and when power came back on the clock would not reset.
Try disconnecting power for 5min.then plug back in,The microprossor may have locked up this happens a lot with uprocessor controlled equipment.
Jan 27, 2011 | GE Advantium 120 Convection/Microwave Oven
My over the oven microwave turns off after a few
i would check your thermal cut offs inside he cabinet,there is a chance that your cooling fan is bad,even thought it may be turning it might not be turning at a fast enough rpm to proper;y cool the unit.
the last thing that i think would be bad is the control board.I hope this helps you get your microwave fixed
Feb 06, 2010 | Microwave Ovens
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I have R-9X58 timer that stopa @ 5min when in convection mode
"Convection cycle runs 4 minutes and 15 seconds then shuts down."
In most cases, this is a bad thermistor, but it may also be loose wiring, or a problem on the control panel.
The thermistor should be on the top of the chassis and it will look like one of the attached drawings.
You will have to remove the outer cover of the oven to get to it.
THERMISTOR TEST
Room Temperature 68°F(20°C) - 86°F(30°C)
Resistance Approx. 350k ohms - 155k ohms
(The higher the room temperature, the lower the resistance, and vice-versa).
If the meter does not indicate above resistance, replace the thermistor.
Also, if the thermistor is caked with grease, or it's rusty, it will need to be replaced.
If it has a broken lead, it cannot be repaired unless you spot weld or braze it, and if you get it too hot, it will be destroyed.
To find the thermistors, you can visit Sharp's Australian support site and click on the "Spareparts Outlets" link under "Frequented Resources".
(If you're not in Australia, please write back and let me know where you are!)
Dec 13, 2008 | Sharp R-1870 Convection/Microwave Oven
Microwave shut-off within 2-3 minutes
Why don't you return it? I think this is a common problem. We returned ours to Home Depot with no questions asked.
Nov 12, 2008 | Magic Chef CMV1000B Microwave Oven
Maytag,model mmv1153bab,serial #10001847ja,output 1000w
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If you still have trouble, since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can find your nearest Maytag-authorized servicer here.
Aug 10, 2008 | Maytag MMV1153A Microwave Oven
MICROWAVE WILL ONLY HEAT ON CERTAIN SETTINGS. how do i set the heating instructions?
I have a Magic Chef model MC0160UQ. Within 2-3 minutes of heating food it shuts off completely for about 5min. Also, when I select the low fan it does not work, however the high fan works. Please assist with these issues if possible. Am I able to fix or adjust the magnetron myself since it may be overheating? or what should i do?????
Jul 18, 2008 | Magic Chef CMV1000B Microwave Oven
Microwave troubleshooting
I found the fix to the F3H error on another site. Just turn the power to the microwave off for ~2 minutes at the circuit breaker, and then turn it back on. Microwave will start working again then.
Feb 23, 2008 | Whirlpool GH5184XPQ Microwave Oven
Amana RFS12MPS Microwave Oven Logo
141 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
