Logic 54cm Coulor Television
Hi there
I have a Logic 54cm Coulor Television. And we have been experiencing power cuts very often lately. After the last power cut, my tv won't switch on, it looks like the power is off even though its on. I have tried to change the fuse (2.5 which is exactly the same as the old one) but it blows as soon as we switch on the power. do you possibly have any suggestions???
Thanks
SOURCE: fuse blows.
Please check for shorted diode or condenser at power section.
Posted on May 29, 2006
MARR
  • 49 Answers
SOURCE: T.V. turns itself off
before any attempt to deep cause of problem, unsolder first all the tack switches in the front panel of tv.then turn on the tv using remote control observe? cuz maybe one of the switches is stock.if not,proceed to eeprom servicing which is u have to look for service mode of ur tv model to unlock it and reset it to factory value.
Posted on Sep 13, 2006
snakehead
  • 1074 Answers
SOURCE: tv will not cut on
there is no recall on sharp tv that i know about if your tv is still on warranty take it back to the supplier.if the warranty is finish call a tech the tv has a problem in the power supply and related circuit.good luck.
Posted on Apr 14, 2007
  • 11 Answers
SOURCE: TELEVISION HAS MIND OF ITS OWN
It's possessed just like mine! ;) So I have no idea besides a basic check:
Does the tv do this even when you take the batteries out of the remote, and block the sensor in the tv with tape or something to make sure its not someones remote doing it?
- Dave
Posted on Dec 28, 2007
  • 2326 Answers
SOURCE: Main fuse blown on CT-32G11 32" Panasonic TV, Replacement fuses continue to blow.
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Posted on Jan 16, 2008
My hisense tv is saying eeprom error
Main system control memory IC [EEPROM] fault. Contact any service technician.
Electro help
Aug 18, 2014 | Televison & Video
A/c on 94 jeep cherokee kicks on and off, is it due to bad cutout switch
Could be low freon or excess pressure caused by bad orifice tube.
Jul 05, 2014 | 1998 Jeep Cherokee
My tv cuts off then it won't come back on when powered on the power button light just keeps flashing. After unplugging tv for 20-25 mins it will come back on
CRT screens use a vacuum tubes for displaying purposes. These tubes warn off through time and use, with symptoms like colours fading out, late responce on start and even quit doing what they suppose to do.
My solution is to replace the warn tube with a new one,if you really want to keep this screen properly functional, but this could get to much trouble and cost maybe.
Feb 20, 2013 | Televison & Video
Tv cuts off and won't come back on unless we use a blow dryer to heat up the bulbs in the back of tv
Hello
Will you please give me some more details about the fault with your Samsung TV? Will it stop working while going on; of will it won't switch ON on cold coditions. Please clarify more. OK.
Nov 01, 2011 | Samsung PCL545R 54" Rear Projection...
I've had several power cuts lately , now my tv is
Hello rogerstanila,
if you have tried unplugging it for a while and if there is still no change then it could be your main board. Unfortunately to fix this could be costly. See if you can find a repair tech that will do a diagnosis for free. But there has quite a bit of problem LG tv's being stuck on standby especially the LCD tv's, Other than this there is not much you can, maybe changing the battery of the remote and just keep trying to click on and off. If it is plugged into a cable box, try unplugging all of that for a while. Leaving it unplugged for a day won't hurt. If nothing else then it could be your main board. You could replace it but as I said before it could you couple hundred dollars. Hope this some what helps.
-Joe
Aug 30, 2011 | LG Televison & Video
TV powers on, then cuts off by itself. After many on-off tries, tv goes to menu and through it, then cuts off.
TV powers on, then cuts off by itself.  I have no picture, and will not let me control the tv. with remote, or manual.
Jul 20, 2008 | Philips 60PP9202 60" Rear Projection...
Tv will not cut on
Apr 13, 2007 | Sharp 32C241 TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
