Question about Amana AFD2535FES Stainless Steel Bottom Freezer French Door Refrigerator
Our Amana French door ice maker is clogged with ice chunk about 2-in x 6-in and we can't pull it out. The area is too small to pour hot water in onto the ice. Any suggestions?
    President:
  • 1,218 Answers
Good day,
What you have described sounds like a defective water valve on the back bottom rear of the machine. It will need to be replaced.
Although awkward, the best way is to remove the ice maker completely and let it air dry, while the valve gets changed.
The above diagnosis is based on the fact the freezer is maintaining it's normal temperature. If for some reason the freezer thaws and then refreezes that problem would need to be addressed first.
Posted on May 26, 2010
My refrigerator stopped making ice and pouring water.I wanted to open the draw to the ice maker to see if there is chunks of ice inside but, it seems to be stuck it will not budge. Any suggestions?
put all your frozen stud in a cooler with a bag of ice then open your freezer door wide and lay a hair dryer inside and turn it on ....put a towel inside yto soak all the melted ice and be sure not to let the hair dryer get wet...put it on a shelf in the freezer and let it run till the freezer is warm and dry they your freezer will work again
Oct 04, 2016 | Samsung RFG298HDRS 28.5 cu. ft. French...
I have an LG french door bottom freezer refrigerator. Water is coming out of the back freezer vents and then pooling and freezing on the freezer floor. If we don't remove it periodically it leaks onto the...
This has nothing to do with the ice maker. The defrost drain has frozen over. Inside the freezer you will see that the whole back is a panel. Unplug the unit and gently pry at the top of this panel. It will come forward and then you can lift it out. unplug the fans and take the panel out. You will see the coils. and underneath the coils, the drain pan. Mine was completely filled with ice. I used a hair dryer to melt it and remove the large chunks. Be gentle. Use a turkey baster to remove excess water. Then pour some very hot water in to clear the drain itself.
Sep 04, 2013 | LG LFX28968ST Refrigeration : Refrigerator...
Amana fridge. french door ice maker now seems to freeze overflow of water so i'm using hair dryer frequently to remove the clog. why is this starting
Your defrost assembly has probably stopped working, which means that you are probably also building up ice in between the panels.
Jun 06, 2011 | Amana AFI2538A Bottom Freezer French Door...
My ice maker is not working. I live alone and cannot do the above suggestions - who can I call to do this? I live in Peru, Indiana. Thank you.
Sometimes they just get clogged up. I've been able to get mine working again by pouring hot water into it. No harm in trying.
Dec 29, 2010 | Amana AFI2538A Bottom Freezer French Door...
I have a LG 3-door french refrigerator that will not dispense the ice. It makes the ice just fine and it dispenses the water just fine. PLEASE HELP!
the most be a chunk of ice stuck since this refrigerator cool way much it freezes the water in the dispenser area i have cleared wit a bit of hot water and emtying the ice bucket
Oct 05, 2009 | LG LFX25960ST Stainless Steel French Door...
I get a buzzig sound from the bottom of the
Does it have an ice maker that is not working? The only thing I can imagine it could be is the start relay, condenser fan blades hitting something in its way or the water control valve trying to open because the ice maker is telling the water valve to open. Double check the model number above your post so I will pull up the correct manual for your refrigerator. Thanks, Sea Breeze
Apr 21, 2009 | Amana AFD2535DES French Door Refrigerator
Water does not reach ice tray, ice maker appears to be cycling
Pull the filltube from out of the back check for ice inside, use warm water to melt.
Mar 12, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Amana French Door Bottom Freezer
see if there is any ice caught within the ice maker itself preventing proper cycling of the ice maker. if not pop off the white cover to the ice maker(theres small **** in the cover on bottom right corner of white cover to insert a ***** driver and twist the cover will pop off. look into the center of the main plastic gear, there should be 2 "tabs" holding that gear in place . as if you were to push gear on and the tabs would keep it in place.( reason i mention that it is/was a problem with the ice makers hat the gear would break and it was very noticeable looking into the center gear).if not, theres a detailed trouble shooter for the ice maker behind the kickplate(maybe taped up under front corner under cabinet) it will tell you points to check for power and jump out if necessary
Mar 12, 2008 | Amana AFD2535DES French Door Refrigerator
Amana AFD2535FES Stainless Steel Bottom Freezer French Door Refrigerator Logo
228 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
