Question about Dual Car Audio & Video
I need the 9 pin S video cable for the #k715-D Digital Lab auto DVD player.
2 Suggested Answers
SOURCE: I have a Digital Labs portable dvd player for my
Hi, I have been looking for this same cable for over a year! Finally found it at www.stockcable.com for like $13.00. Got it yesterday and it's the right one. Don't know if you're still looking for it but if so, hope this helps!
Posted on May 27, 2010
I plug the white, yellow and red cables from the dvd player into the back of the tv but it says "no signal". I changed the input to Component 1 then I tried the other plugs too but still get the...
Hello
If you have connected the red, white, and yello video cable connection right correct to the respective pins; both at DVD and TV end, by selecting the input to Video-1 or Video-2, you must get the logo of the DVD player on the TV screen. Please not that whether you have 'Power ON' the DVD player. If the connections are good, the logo must be ther. Otherwise check the continuity of the RCA cable, of it may have damaged[shorted]. Try replace with an other cable. OK.
Aug 15, 2011 | Apex Digital LD4088 LCD TV
Hello, I recently bought an Onkyo HT-S9300 home theater system. I am trying to get it to work with my DVD player using optical cable for the sound, since the DVD player does not have HDMI output, but I...
In your DVD player audio setup change the digital output to bitstream. You have not mentioned which DVD player you are using.
Some players it will be given
Digital Out - Off/ On select On
Dolby Digital - Dolby / PCM select Dolby
DTS - On/Off select ON
Jun 19, 2011 | Audio Players & Recorders
Where can i get a cable to link my mv890 to laptop so i can put my films on to dvd
Firewire is what you require. Most computer shops will sell firewire cables.
You will need to find out what type of socket goes to the computer. The camera uses a 4 pin socket and most computers use a six pin. Generally a 4 to 6 pin cable is used for Desktop Top computers. Laptops usually use 4 pin, so a 4 to 4 pin cable would be that option. Newer computers use 800 firewire ports that have a 9 pin port, 4 to 9 pin in this case.
There are 3 options, so check the camera and computer to make sure you get the correct cable.
Firewire is also called iLink or IEEE1394a for 400 and IEEE1394b for 800.
May 23, 2011 | Canon MVX150i Mini DV Digital Camcorder
I have a digital labs model K715 dvd player. when i put a disc in, it spins, screen say its loading but will spin, stop, spin and stop again. Wont play the disc.
Try doing the following...
Making sure the "line select" has been switched from "in" instead of "out". Once you switch it back to "out", the player should work normally.
Mar 05, 2011 | Insignia NS-PDVD8 Portable DVD Player
Connection to my old TV
your tv do not have an audio/video input...what you need is a device called RF modulator, it converts the audio/video signal from your dvd player into RF signal similar to the signal from the cable operator.it has an audio/video input and a coaxial cable output..
Jul 18, 2009 | Curtis DVD1047 DVD Player
I have a Digital Labs portable dvd player for my automobile. My problem is I need the S video cables (9 pin) for model#K715=D, serial#L06A01355.
Jul 10, 2009 | Car Audio & Video
I do not know how to hook up my goldstar to my TV. My daughter gave me the dvd/vhs that was hers. Are there instructions?
The power cord of the DVD to be connected to the power supply.
the audio cable goes from the audio pin from the DVD player to the TV audio pin.
The video cable goes from the video pin from the DVD player to the TV video pin.
Jul 05, 2009 | Goldstar GBV241 DVD Player/VCR
Connecting to front inputs of a Toshiba tv
As a replacement for "Dolby Digital DT3 AV cable" can be used a " 3.5mm (mono) to RCA(or coaxal)" Cable.
Just make sure that DVD Player set for "SPDIF/RAW" or "SPDIF/PCM" output
Oct 12, 2007 | GPX PDL805 Portable DVD Player
QK-DVDM1 need mini din 9 pin monitor only
i just happen to own a monitor for a qwestar dvd player. for more info contact me at www.wattderek@gmail.com
Apr 12, 2007 | Qwestar MVP360 Car DVD Player
Car Audio & Video Logo
24 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
