Question about Hoover Washing Machines
The washing machine barrel fills up with water even after the wash has finished and all clothes removed, why?
  • 283 Answers
The water inlet valve is passing a little water through in the unenergized state. Turn the water supply valves off and wait. If the filling up stops replace the machine's inlet valve and if you can, flush your water pipes and water heater before hooking the washer back up
Posted on May 26, 2010
During filling reaches fL before finished filling and stops
Not sure if this was explained to u but these washers do not fill like the old top loads did... the machine uses very little water, the clothes are rolled over and over through the water as it cascades down and up through the agitator. If you look at the agitator you'll notice it does not have an elongated spindle, it's not required. Although the machine doesn't fill your clothes will be fully washed, this design was developed to conserve water...
Aug 19, 2013 | Kenmore Oasis Agitator 4.5 cu. ft....
I have a black hoover VHD 844 DB washing machine and recently after a wash has finished and ive the clothes removed water begins to very slowy fill the drum again. The water isnt smelly but looks dirty....
Your water valve is not closing all they way and either needs to be replaced or cleaned. Even though the video below is on a different washer, it gives you an idea on what is required to be done.
Nov 22, 2017 | Washing Machines
Hi,I have a Simpson eziset 450. The problem is that when we make it wash our clothes,when it finishes,the clothes came out all spotted!grey spots..like if they've been done by dirty water..what's the...
you have sportac build up in your pipes and barrel you need to run some dish washer cleaning solution through the machine on hot wash this will kill and remove all build up try using a liguid detergent not powder in the future
best of luck
please rank this advice thumbs up it it helped
Jan 18, 2011 | Washing Machines
Me and my kids are going nuts because everytime we wash something, it goes off balance the clothes are wet and it flashes ue ''uneven'' even if it is only 1 piece of clothing . I have adjusted all the legs...
if the cycle does not gets complete then its --
it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jul 25, 2009 | LG Washing Machines
Will fill and drain, not agitate or spin though
I am having the exact same problem with the same brand machine.  I put in a load of clothes to soak till the morning, but in the morning, the washing machine would only fill, spin, and drain.  The agitator would not wash the clothes, so they came out with the soap of course still crusted in.
Jan 22, 2009 | Roper Washing Machines
Smartdrive 703 Model Washing Machine Leaving brown stains in clothing after some wash cycles. Stains are small and seem to be something coming through to the clothess from the slits in the drum holes. ...
if you do cold washs all the time you get a build up of sludge between the drums you need to fill it with hot water and let it soak for a few hours and then put through a high wash to rinse out,no clothes.Or you can remove the drum and wash it .hope this helps
Mar 14, 2008 | Washing Machines
Washing Machines Logo
113 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
