Question about Sony Car Audio & Video
How do you reset a sony CDXGT23W Car Radio/CD player? Sony Corp. says that what I should try, but I can't get a response from them about how to it. It's not in the user manual. BTW, the basic problem is that after playing a CD the radio will not function. Radio works fine otherwise. Eject the CD, or try to switch function from CD to Radio, and the radio is just dead.
SOURCE: No response from the KDC-519
I once had the same problem and took it in to have it looked at! The guy simply pushed in the small black button to the left of the ATT button and it reset!
Hope that helps!
Posted on Nov 21, 2007
Eagleeyes
  • 199 Answers
SOURCE: Cd stuck in my Dual XD5120 cd player in my car.
Hi these rados are madeby alpine, a manual reste of the cd player normally fixes the problem.
but its not easy and is best done by a service Centre
Regards
Mark
www.blueice-electronics.co.uk
Posted on Jun 23, 2008
  • 4 Answers
SOURCE: Kenwood KDC-119 car stereo problem
There is a small hole at the bottom of the stereo face that will reset the system. I pushed a pen tip into the hole and it turned the stereo off. When I removed the pen, the system turned on and the CD ejected. Problem solved.
Posted on Jul 03, 2008
nuwan chinth
  • 111 Answers
SOURCE: LG car CD, MP3, WMA Receiver wont play or eject CD's??
please observe when you push the eject button display applys the open or eject cd?.if yes something wrong with your mechanisum.it has several microswitches and bad contact of them occur this type problem.sometime loading mechanisum stuck because of loose belts.open the cover of your cd player and check cairfully.
come back with results.
nuwan
Posted on Jan 09, 2009
SOURCE: BLAUPUNKT GMDAT CDP 3 (E) - CAR RADIO CD HOW TO EJECT CD?
Hi graz,
If your unit has a SRC button to the right of the CD clot, try holding this down for a few seconds - works on mine!
Posted on Feb 28, 2009
On sony car radio, soldered connection of red and white wires for audio cable are broken.How and to which connections(there are 3 choices) do I resolder red and white wires?
without a schematic that's hard to answer. I suggest opening the unit and tracing on the board to find the output configuration (use your manual to help guide you) . there's not enough info on your Q to give a better response.....
Apr 13, 2013 | Sony CDX-GT220 Car radio CD/MP3 Car CD...
Sony xplod am/fm cd model cdx-m610 will play cds but the radio want play. i have tried to reset radio still will not play
Make sure that you have the antenna plugged in and if you have a power antenna make sure that you hook up the solid blue antenna wire behind on the radio harness to the power antenna wire from the car plug.
May 21, 2010 | Sony CDX-M610 CD Player
Sony CDX-M600R car radio CD: Radio does not work, CD player OK and all other funtions OK. When in radio mode can hear white noise but no transmitions.
I had this before with my unit, I did a system reset by holding down the reset button for about 5 seconds - all back to normal then.
Apr 15, 2009 | Sony Car Audio & Video
Car Radio
I have the same head unit and disconnected from the battery. There was no input code required when reconnecting the battery You should be ok! I can't help with your Tuner problem though! Good Luck!
Aug 20, 2008 | Sony CDX-L580X CD Player
In car sony radio cd player
Connect the permanent power line that goes directly from the battery to the "Back up" wire of the CD Player.
Mar 05, 2008 | Sony CDX-M610 CD Player
Sony compact disc player initializing
Have you tried pressing hte RESET switch?? It's behind the removeable front of the stereo, use a biro or something and hold it in for a bit.
Failing that, check that there isn't a CD already in it, could be a dodgy CD?
Dec 26, 2007 | Sony CDX-SW200 AM/FM Compact Disc...
Sony cd car radio
if you got the radio password or radio code..try to reconnect the battery of your car..turn on your radio,then enter the radio code you hav...:)
Oct 30, 2007 | Sony CDX-M610 CD Player
Car Audio & Video Logo
202 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
