Question about HP Pavilion dv6000z Notebook
My laptops dvd drive is not responding or working proper;y when I go to device manager and click on the dvd drive it gives me this message: Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19) Click 'Check for solutions' to send data about this device to Microsoft and sto see if there is a solution available.... I pressed the check for solutions tab and nothing happened please help or give me a way to fix this registry error. Thanking you in advance purplejaze
  • 1 more comment
  • Jason r. Hicks May 26, 2010
    thnak you im working on it now did you mean device manager
    IOKTAY- I had to try your 2nd suggestion and it worked beautifully! I thank you so much for your help!!!!! this is my second time using this site one for my car and this one AGAIN I TRULLY APREECIATE YOUR HELP!!!!!
    Sincerely,
    JAY a.k.a purplejaze
  • 493 Answers
Please do the followings:
- From control panel,... devices find your device ( your dvd drive)
- Click Uninstall, and then click Scan for hardware changes to load a usable driver.
- Restart the computer in Safe Mode, and then select Last Known Good Configuration. This rolls back to the most recent successful registry configuration.
The name and version of your operating system is not mentioned in your message. That's why if you don't know how to get into windows safe mode, to see all the versions of windows please click this link.
If it doesn't solve:
You may try to Remove/Delete the lowerfilter and/or upperfilter (you might have only one of these) entries from this registry area:
For example: If your operating system is Microsoft Windows Vista ,
Please be careful not to delete other entries.
- Go to Start > All Programs > Accessories, and then click Run.
- Type regedit, and then click OK.
In the navigation pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
-In the right pane, click lowerfilter.
-On the Edit menu, click Delete.
-When you are prompted to confirm the deletion, click Yes.
(If you can't see lowerfilter registry entry, find upperfilter and delete that as described above.)
-Exit Registry Editor.
-Restart the computer.
Hope this helps.
Waiting your comments.
Posted on May 26, 2010
  • 4 more comments
    thank you and my operating system is Vista. if I uninstall i wont lose the sfotware for the drive will I? ill see if those things work
  • Ibrahim OKTAY
    Ibrahim OKTAY May 26, 2010
    Sorry, in the second solution, in Windows Vista to get to get to DOS prompt:
    -Click Start.
    -Type cmd and press enter.
    - Type regedit and then click OK.
    .......do as described above.
  • Ibrahim OKTAY
    We can reinstall the driver from internet.
    But it should recover itself.
  • Ibrahim OKTAY
    Yes
  • Ibrahim OKTAY
    If it doesn't work please send me your comments, I will write the other solutions.
    Thanks
  • Ibrahim OKTAY
    Dear JAY a.k.a purplejaze,
    You're welcome.
    Thank you very much.
    Welcome to FixYa. We're here to solve your problems.
    Best wishes.
    Ibrahim oktay
    FixYa Premium Expert
    Computer and Software
My dell inspiron 1525 dvd drive not working. support centr guys told me, it was lens problem. Plz tell is there any to fix the lens. And, how much it would be for replaceing lens.
Open Device Manager from Control Panel for any error messages related to the device.
Now double-click on the "System" icon then click on the "Hardware" tab and click the "Device Manager" button. A new window appears, and displays whether the device is working properly. If there are any errors, click the "Troubleshoot" button and follow the given onscreen instructions.
uninstall any drivers that may be on your computer from previous DVD drives and download the latest driver updates for your DVD drive model from Dell website & install it.
Also check on Dell website that your machine has the minimum requirements to operate the drive.
Sep 05, 2012 | Dell Inspiron 1525 Laptop
The dvd drive not work model satellite L355-s7902
Check in device manager to see if the computer can detect it or if it shows a yellow ! or ? To get to device manager
  • Right Click on Computer and click Properties
  • Select Device Manager on the left, or in Win Xp click hardware tab and then device manager
If it doesn't show up at all I would say the drive is bad and needs to be replaced. Type your exact model number into ebay plus dvd drive and you should be able to find one cheap.
Let me know what you find out and if you need help replacing the drive, just comment back and I will walk you through it. Usually it will just be held on with one screen located on the back close to the DVD drive door but about 3-4" toward the middle.
Aug 08, 2011 | Toshiba Satellite L355-S7902 Notebook
Dvd drive wont work
Hi
try the following
Right click My Computer / Manage / Storage / Storage Management. can you see on the right in the graphical display the DVD drive? if yes, does it have a drive letter? if no, right click on it and assign any unused drive letter. after this assignment the drive should show up again in My Computer.
If this doesn't work go in the device manager. is there a yellow exclamation mark or even a red sign beside the DVD/CD drive? if yes double click this entry. on the new window click on the "Driver" tab. click on "driver update", then follow the instructions on the screen
If still facing the issue means
Open the below site and download the driver.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INS_PNT_PM_1521&os=WLH&osl=en&catid=&impid=
Dec 17, 2010 | Dell Inspiron 1521 Laptop
My cd drive not responding
change your SATA cable or IDE cable and change it into a new one bro. because it occurred that your cable have experience an electrical shock when you plug it into its socket while in on line mode.
Aug 13, 2010 | HP Pavilion a1220n (A1220NED904AA) PC...
My dvd/cd rom is not working and is not displaying on my computer folder/dialogue box of hp pavilion dv6000 laptop it is not displayed wen i click on my computer to check it. Others; local disk, recovery...
click on the start button>in the start
search box type in regedit>now you will
see the regedit option listed there>click
on it and click on continue>now you will
have the registory editor window
open>here on the left hand side double
click on HKEY_LOCAL_MACHINE>under
that double click on SYSTEM>under that
double click on Current Control Set>now
double click on Control>now double
click on Class>now look for 4D36E965-
E325-11CE-BFC108002BE10318.click once
on this option.>now on the right hand
side look for "upperfilters" &
"lowerfilters".you may have both of
them or any one of them.just right click
and delete any such file.after this close
all the windows and restart the
system.if everything goes fine your dvd
drive should work fine.
Jan 20, 2010 | HP Pavilion dv6000z Notebook
My Laptop no longer recognizes that it has a DVD/CD drive
If you can, remove unit from laptop and start laptop without CD/DVD. It is usually fairly simple to remove. Maybe a few screws in bottom of laptop. Cut off laptop and reinstall. Restart and windows should find it.
Jun 28, 2009 | Acer Aspire 9300-5349 Notebook
DVD RAM not reading the DVD on a Toshiba Satellite A105 laptop
did you try to insert other DVDs? if it works then the DVD that you are trying to play is faulty. But if all CDs cannot be read i suspected it's a dvd-rom drive faulty. you need to replace it.
May 28, 2009 | Toshiba Satellite A105 Notebook
Cd/dvd driver can't read Cd and some DVD
Im having the same problem with my acer. although i can play all cds, just not some dvds. Ive already had a suggestion, heres the link.
Apr 10, 2009 | Computers & Internet
Acer aspire 5315 laptop cd/dvd drive stop working like there was none
This will be one of two things, 1- a driver glitch, you will need to uninstall the drivers for the cd/dvd drive from the device manager, then reboot. The machine will find the drive and reinstall the drivers automatically. This will fix it if it's a driver problem. You can also try any updated driver utilities, or patches for the drive from Acer's support site. 2- the cd/dvd drive has failed and needs replaced. These are basically plug and play devices, they either work or they don't, so a majority of the time when the machine stops recognizing the drive, it's because the drive has malfunctioned. Unfortunately, these drives are considered sealed units and replacement parts aren't available.
Aug 30, 2008 | Acer Aspire 5315 Notebook
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
