Re:XP Screen resolution settings
Both HD are IDE. I have already change the one which was not booting for another from my dell WinMe. XP was updated successfully but Screen resolution problems. 640 x 480 color lowest (4bit).
Where and how do I get device drivers from to solve this problem?
  • 1 more comment
  • odai Apr 07, 2008
    I cannot get to the internet...Network connections does not have the LAN icon..I tried creating a new connection but nothing is happening....stuck again!
  • odai Apr 08, 2008
    Another thing...After installing XP, I am noticing that all the previous program from WinMe is still on the drive. Somethinf must be wrong because that should not be. I know that I have xp because the bootup procuss is showing Windows xp.
    Help me out?
  • odai Apr 12, 2008
    Thats because I never got any response from my last posting on 08 Apr and problem has not been solve as yet. may have to go to a repair shop.
  • 13,434 Answers
  • 1 more comment
  • Ekse Apr 12, 2008
    if you installed xp over me, you will see me and xp in the boot menu.
  • Ekse Apr 12, 2008
    im disapointed by the rateing why thanks for trying?
  • Ekse Apr 12, 2008
    oh you need the video drivers.
    did you find them from the ibm site i gave you earlyer?
SOURCE:
Sata Hard drive errors and Raid errors
See this answer
Reboot your system and hit F2 as soon as you see the Dell startup screen (the options are F2 for setup, F12 for boot sequence).
In the System Setup screen, do these steps.
Select Drives:
Make sure your Diskette Drive (3.5 floppy) is set properly (Usually set to Internal)
Make sure that "Drive 0: SATA-0" drive is set to "ON"
Go to "SATA Operation":
Your system proabaly came set to "RAID Autodetect / AHCI" - THIS SETTING CAUSES YOUR SYSTEM TO GO INTO AN IDE LOOP AND DOESN'T ALLOW IT TO FIND YOUR FACTORY INSTALLED SATA DRIVE.
CHANGE THE SATA OPERATION SETTING TO "COMBINATION"
Reboot - make sure that the boot sequence is set to CD rom before HD and make sure that the reinstall CD is in the drive. Setup will load, hit enter to reinstall XP. Your HD should now be detected and you should see the licensing agreement.
If you have your files backed up I reccommend deleting the partition and reformatting prior to installing XP, it will give you that option after the license agreement.
Once you have successfully reinstalled the OS, Dell reccommends that you change the SATA Operation setting back to RAID AUTODETECT / AHCI (or back to whatever your factory setting was) to avoid any problems with other IDE devices installed on your system.
Source
Restore Complete but Stuck on DRMK
Sep 03, 2012 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Dell Dimension 3000 Video problem
There may be a problem with your windows installation. Search Google for Hirens boot CD, it is a free download and should contain a live XP installation. When you turn on the computer tap the appropriate button to reach the boot menu, then insert the CD and select your CD drive. Once booted it should display a live XP.
Alternatively you may have your monitor set to an incompatible resolution. If tapping F8 won't display the advanced boot menu then try finding an auto setup on your monitor or change the resolution using the monitors controls. If the advanced boot menu does display then select low resolution mode.
Hope this helps,
www.PuterCare.com
Jul 02, 2010 | Dell Dimension 3000 PC Desktop
Gateway E3600 (Intel D845PT MB) won't boot after MS Update
This error comes when your motherbord not read properly harddrive.
for that first reconnect both connection to harddisk.Power cable and ide or sata cable.
Change SATA or IDE cable then check.
Pull cmos cell from motherbord for 10 minutes so all settings are factory defaults.
Then when you power up the computer press F1 or F2 or "del" key then you can see bios screen.
Make sure hardddrive detect in bios.
Set first boot device as harddrive.
Then check.
Let me know if you need further assistance.
Thanks.
Nov 06, 2009 | Intel Desktop Board D845PT Motherboard
HP Pavillion dv9000 will not boot up in normal mode, only safe.
Have you tried an XP repair?
Then you can save your data .
XP repair
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 18, 2009 | HP Pavilion dv6208nr Notebook
Does not show up in my computer but does in bios
Can you boot the computer from a boot floppy?
If so, try and partition and format the drive with fdisk and format.
May 20, 2009 | Maxtor DiamondMax D540X (4D060H3) 60 GB...
Non allocatable error message on a cd made under winME trying to read in xp help please
When i turn on of my pc. then bios screen msg reboot and select proper boot device or insert boot media in the selected boot device. How to solve of this problem. pls .............solve tips for give me.
Apr 09, 2009 | Dell Computers & Internet
Dell dimension E310 wont boot
Go in bios and change the SATA mode to IDE or compaitibilty then check whether it is working or not
Feb 17, 2009 | Dell Dimension E310 PC Desktop
Dell Latitude D600 with new Hitachi 30GB Drive Not Recognizing
XP install is not detecting any hard disk.
No jumpers are required for laptops, can only have one hard drive in a laptop.
Check the BIOS for the hard disk configuration, make sure that it is set on Auto (detect).
You may have a faulty hard disk, you can check it by booting up with a floppy DOS boot disk, run fdisk to see if it detects the hard disk, OR connect this hard drive to a USB hard disk adapter and connect it to a working computer's USB port and if it detects it as an external drive the it is OK.
Nov 30, 2008 | Dell Latitude D600 Notebook
Dell C400 Resolution Problem
Boot into BIOS and go to the Video card setting, that sould fix it
Jan 26, 2008 | Dell Latitude C400 Notebook
Open Questions:
Computers & Internet Logo
64 people viewed this question
Ekse
Alun Cox
