Question about ComponentOne True DBGrid Pro 8.0 for PC
The click event in truedb grid is not invoking the rowcolchange event for the first time the grid is clicked. Why is this? IS there a fix for this?
Error code 3 4
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
Right click on the error message select properties you will see all details about the error
or click start type in event viewer press ENTER
this should give you some sort of understanding of the error and
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
Nov 04, 2013 | Dell Precision Computers & Internet
How to fix E004
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem
Feb 11, 2013 | Computers & Internet
How to fix error 80244019
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem if you need more help with this post a reply with the error message details Hope it helps.
Jan 11, 2013 | Microsoft Windows XP Home Edition
Error no. 302?
Control Panel / Administrative Tools / Event Manager
Windows 10 in startup apps go to Administrative Tools / Event Manager
Right Click start menu click event Viewer
once there look to left and expand WIndows Logs Click on Applications and wait for them to load See my pictures i found an error then I clicked on it and it told me what app.
If you don't have event viewer turned on you won't get anything. Then just google turn on event viewer your OS = (winodws 10, Windows 8 etc. turn it on reboot once the error occurs it is recorded go to event viewer and see results.
Dec 30, 2017 | Toshiba Satellite M45-S331 Notebook
Jit debugging problem. I have tried disabling the script debugging on internet and other. This didn't solve the problem. Any other suggestions ?
I was just reading the thread! Kinda hilarious though.
JIT is used to catch real time errors especially run-time. It is very useful for developers. To catch un handled exceptions.
Jit comes as a part of Visual Studio. If you do not know how to manage Jit its better not to install Visual Studio (no skills to manage it will give you lots of trouble). Just the programing skills does not make a good developer. Well its not a fault of VS developer team or Bill Gates. Doh!
Jit will be invoked if enabled by Visual studio, instead of Dr Watson. If programs crash the crash handlers will be invoked and you will see Dr.Watson process running in the background. It will call dumprep and will create error logs; Errors will be logged in Event Viewers as well. Even a simple failure will be handled and Jit will be invoked. So programs will begin to crash while they run or install.
Some developers set programs to use Jit and Jit will be enabled instead of Dr.Watson. Dr.Watson will be invoked in serious errors however. Its obvious. But specially if you have installed Visual Studio, you will be using JIT as well. JiT overrides the Dr.Watson Program. But you can reverse it back using two methods.
Its a third party piece however. I wonder why these MSDN people do not know how to provide a complete answer. Each and every person does not understand Administration of programs. So its their responsibility. That is a laughing matter though. But people will be pissed off. Can't blame them either. Some of them are not familiar with regedit tools. So the answers have to be flexible and complete.
The bad behavior of JIT is it will suspend the program an once when an error occur. You will never be allowed to run further. So its kinda piece of ****. It also has security issues with it.
Unfortunately if a program Invokes JIT intensionally its not possible to reverse the process.
Stop JIT while you have Visual Studio installed (Its a stupid thing to uninstall it without removing JIT. No way!)
How this thing will be enabled?
  1. Open VS:
  2. Go to Tools and then Options.
  3. In the Options Dialog box Double click Debugging and then click JIT
  4. Enabling options:
  • Manage
  • Native
  • Script
Click on OK.
This sets the Registry key and will start JIT. So do the Revers to Disable it.
You have to Disable the Keys. Method one:
  1. Click on Start Menu and Type Run (for P Hit Run box)
  2. Type in regedit and hit Enter
  3. Expand the Keys to located the place
  4. HKLM\Software\Microsoft\Windows NT\CurrentVersion\AeDebug\Debugger is one location.
  5. HKLM\Software\Microsoft\.NETFramework\DbgManagedDebugger
  6. Delete these keys. Or set the Auto key's value to 1.
  7. On a 64bit system the paths will be: HKLM\Software\Wow6432Node\Microsoft\...
  8. You may need to reboot the system as well.
Method two: Enable Dr.Watson using an alternative method:
  • Get a Command Window (Command Prompt)
  • Type drwtsn -i and
  • Hit enter
If you were using a third party debugger read this Microsoft Support
Next step
Open Start>Control Panels>Internet Options: Advanced and activate (check box)
  • Disable Script Debugging (Internet Explorer)
  • Disable Script Debuggung (Other)
If you have enabled Server Side Script Debugging the pages will freeze if an error occurs. Read the enabling procedure. Steps to enable debugging portion. Do the Reverse to disable it.
For Script Debuggers: Here is how you enable the JIT:
  • Click on Options then Tools
  • Click on Debugger
  • Select JIT debugger and attach to programs running on this machine
  • So now you know how it happened. Do the reverse to disable it!
Using third party tools and software may enable this tool. If you detect one you have to avoid using it. Just posted this in the MSDN thread as well.
Please rate the answer as well! Feel free to contact if you have further issues.
Thanks for using Fixya! -Lasitha
Jul 09, 2010 | Computers & Internet
Wireless Lan on HP Pavilion M1000
Surely you can find out if you have a wireless network card installed . For this you can goto device manager and under network adapters look for any wireless adapter.
Heres How you check device manager.
  • Right-click My Computer then select Properties
  • Select the Hardware tab
  • Click the Device Manager button
  • Alternative solution: invoke devmgmt.msc
  • Alternative solution #2: Device Manager is part of the Computer Management, which also includes Event Viewer, Services Manager, Disk Management, as well as many other things. Right-Click My Computer then select Manage to start Computer Management, or invoke compmgmt.msc.
Picture of device manager and random wireless adapter
http://www.cisco.com/warp/public/102/wlan/xpleap_02.gif
Also I am not too sure about what system you are using and whats the operating system you are using.
Dec 20, 2007 | Computers & Internet
Corrupt Date Book Fixed
Updated Instructions Simple fix for a corrupted Date Book sync error (at least it worked for me on my Treo 650). 1). Turn off 'Show Calendar Event' in the Phones 'Options - General Preferences' menu. 2). Turn off phone. 3). Set the Date/Time to the maximum limits (12/31/31) in Preferences. 4). Open the Calendar and view the maximum day 12/31/31. 5). Select 'Purge - (Delete events older then 1 week)' in the Calendars Options menu. 6). Reset the Date/Time to the current day in Preferences. 7). Hotsync (Desktop Calendar overwrites handheld). 8). Hotsync again to make sure you don’t get the error (Synchronize the files). That’s it. =============================== Outlook Calendar The attempt to open the database failed. Date Book application database is not found. Please invoke the Date Book application on the handheld once and re-synchronize. OLERR:05-0001 OLERR:0D-0004 OLERR:0D-0001 - Not Synchronized Outlook Calendar synchronization failed OLERR:15-0002 OLERR:06-0001 ===============================
Sep 07, 2005 | Palm Treo 650 Handheld
Computers & Internet Logo
60 people viewed this question
Top ComponentOne Computers & Internet Experts
David Payne
David Payne
Are you a ComponentOne Computer and Internet Expert? Answer questions, earn points and help others
