Question about RIM BlackBerry Curve 8520 Smartphone
Change from orange to vodaphone on blackberry curve 8520
My blackberry 8520 won't connect to internet. I had no problems when I was on Vodafone network but I have changed over to Orange network
The settings is different for each service provider.Hence contact Orange customer care and set the internet settings accordingly. Afterwhich you can connect to internet.You can get the speed of your internet using ScanmySpeed.com
Nov 05, 2014 | RIM Blackberry Curve 8520
Hi i have a curve 8520 on orange im after the unlock code my imei is 354908048165456 please help andrewjohnhatton@hotmail.co.uk
Hi whether you want to unlock your blackberry curve 8520 mobile from orange network then visit onlinegsmunlock.com here they ask you the imei number of your mobile .finally they send you codes to unlock your mobile.
Aug 18, 2012 | RIM BlackBerry Curve 8520 Smartphone
Mep code for blackberry curve 8520
you can Unlock your Blackberry curve 8520 with imei unlock code. it is very simple and eaisiat way to unlock your Blackberry curve 8520. get your Blackberry curve 8520 Imei Unlock Code . and use any gsm sim card.
i hope this will help you .
Dec 28, 2011 | RIM BlackBerry Curve 8520 Smartphone
Blackberry 8520 curve network solution
You can easily unlock your Blackberry cell phone,Simply enter unlock code through mobile keypad,You can get unlock code by BLACKBERRY CURVE 8520 UNLOCK CODE provider with Instructions.
THANKS ! ! !
Nov 23, 2011 | RIM BlackBerry Curve 8520 Smartphone
I have a blackberry curve 8520 imei no 359428038022273 Many Thanks
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
Aug 01, 2011 | RIM BlackBerry Pearl 8100
Blackberry Curve 8520 Signal problems
I don't think this is a phone problem.Bad signals is caused by network provider or probably you are in an area where signals is poor. But i don't think its a phone problem. Try leaving your area and go to another area and see if the problem still persists. Then you could see a Blackberry technician.
Best regards
Feb 06, 2010 | RIM BlackBerry Curve 8520 Smartphone
Please with the code to unlock blackberry 8520
It's a clear and fully detailed guide on how to unlock a BlackBerry 8520 (Curve) :
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keyboard (if your BlackBerry have touchscreen)
7. Type MEPD ( you will not be able to see what you are typing )
8. Type MEP2 or MEP4 ( you will not be able to see what you are typing )
9. Now the phone will prompt you to enter the mep code
10. if you not already have the code, then i suggest BlackBerryMEP.COM to get it from .
11. Enter the mep code ( you should see "code accepted" )
12. Restart your BlackBerry .
All done.
SOURCE :
BLACKBERRYMEP.COM
Oct 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
RIM BlackBerry Curve 8520 Smartphone Logo
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
