Question about Hotpoint Kitchen Ranges
I have a hotpoint HE63X extractor...i turned on the light the other week and the blub blew and triped out my main fuse box....i changed the blub reset the fuse box and went to turn the light back on...but nothing happens when i push the light button now...but the fan works fine...is there a fuse sumwhere inside it that i have to change or has the button blown or something? Thanks
  • 1462 Answers
SOURCE: Light blown then fan doesn't work!
take out switch assemby and check if the track of the pcb is blown - caused by the bulb goiung. you can often repair by soldering in wire links. bet you have 12a fuse in system - should be 3a. track has blown instead of the fuse
Posted on Mar 31, 2007
SOURCE: fan oven not working
Hi, did you ever get this sorted, as i think the same thing has happened to my oven.
Posted on Oct 31, 2007
MicrowaveSvc
  • 9085 Answers
SOURCE: After changing a blown oven light, the clock works but nothing else turns on, including the fan, light, microwave
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
http://tinyurl.com/yzjozk
Posted on Nov 28, 2007
SOURCE: Fan and light not working where is fuse box?
Hi - I have a neff extractor fan and have the same problem. The light and fan have both stopped working. Does anybody know where I can find the fuse as I suspect that this may be the problem too?
Posted on Feb 16, 2008
  • 49 Answers
SOURCE: suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
Posted on Feb 19, 2008
Lights and fan simply won't work, how do fix it?
if it is a fuse your fuse box will be located under hood and sometimes you may also have two fuse boxes , one under hood in a black box in plan view that says fuse and relays. remove the cover and look under the lid. you will find descriptions and placement labels under cap. find your fan and lighting fuse if blown replace with recommended fuse. same goes for other fuse box under dash or located on driver side or passenger side of dash in between door and dash. must open door to view fuse box.
May 21, 2015 | Cars & Trucks
Keeps triping my fuse box
Your circuit breaker is bad,can't tell by looking,remove and take to lowes and match up and install and see if it trips again.
Oct 10, 2012 | Hotpoint Aquarius WD63 Front Load...
Where is the fuse box loacted on a 2005 toyota corolla.... my two back license plate blubs blew and I want to replace them but cant find the fuses.
The fuse box should be located by your right leg near the bottom of the dashboard. There should be an access panel that un clips and allows you to access all the fuses for the interior and exterior lighting.
Mar 22, 2011 | 2005 Toyota Corolla
I can turn on the oven the fan works the light comes on the thermastat light comes on but the oven does not heat up i have changed the the thermostat cut off but no change and after a while of it being on...
Generally when the oven indicator light is on and the fan forced fan is working it will be a faulty oven element.Check the terminals of the element and if the connections are okay put a set of test lamps or a meter across both terminals. If there is 240 volts across the terminals then this means that the element is faulty.
Feb 05, 2011 | Electrolux Ovens
I have a Hotpoint HE63X extractor hood and the bulb blew yesterday when I pressed the button to switch it on. This has also stopped the extractor from working. All other appliances are operational and...
I've got the bloody thing in bits as I write - I had the same problem as you - and it's the switch itself that has blown! From al the carbon in the swithc unit I would say we were luck the thing did not catch fire!
I'm looking for spare parts now to see if I can get a new switch or a complete unit of switches. The problem will be, it is one new switch, or a new board it all requires soldering.
Just to confimr, there is not a seperate fuse for the lights - perhaps there should be.
Nov 01, 2010 | Microwave Ovens
2005 altima Tried to replace dome light blub and fuse blew cannot find fuse also shifter will not go into gear after car is started.
Most often the battery cables as they connect to the battery get dirty and they can look clean and not make it so clean them anyway. If the car was jumped started wrong the main fuse can be blown and no power gets to the dash. Test light at the big power wire on the back of the altenator if its dead it's not going to start or light any of the dash lights either.
Please I will advice you take this vehicle for a scan and not to do a guess work on it.
Cheers.
Mar 23, 2010 | 2005 Nissan Altima
Hotpoint Dishwasher BF1620 blew the main fuse circuit in fuse box during mid cycle wash? Re-set main power fuse circuit but now as soon as Dishwasher switched on immediately blows main kitchen power fuse...
This is happening because you have a very bad fault, a Phase to Earth short, problem. Leave machine UNPLUGGED, Breaker/Fuses OUT. do NOT use it, nor Touch it, It is possible to get severe electric shock. PLEASE get a registered serviceman to inspect this unit.
Feb 07, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Wash cycle will not start door locked led flashes
sound like water has been splashed over circuit
board. dry out and replace any damaged components.
Mar 15, 2009 | Hotpoint WMA31 Front Load Washer
Fuse blew in plug
your main moter as a fault in its winding making it have a short which blows fuse
Jul 28, 2006 | Hotpoint WMA44 Front Load Washer
Kitchen Ranges Logo
80 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
