Question about Hotpoint Ariston AS66VXNA1 Electric Dryer
Problem with hotpoint as66vvxna1 dryer
My hotpoint dryer is not heating up, please advise, thanks
  • 552 Answers
There are a couple of things that you can check. FIRST go to the electrical box where the circuit breaker or fuse for the dryer is. Sometimes on half of the circuit breaker is tripped allowing the controls of the dryer to work, but not the heating element. Turn off the breaker and turn back on. Or replace the fusees. If this does not work, then you may have a loos wire or a burned out heating element. Sometimes there is a bad high temperature switch. Do the circuit breaker or fuse first. If the washer did not spin out the water well enough, the water can short the element to trip the circuit breaker or blow a fuse.
Posted on May 26, 2010
When i set my drier to dry on high heat it keeps tripping the electric with error code f-13 please could you advise me on why this is thanks
Indesit (Hotpoint, Ariston) 'F13's refer to 'thermistor circuit fault', 'dryer fan not working', 'dryer NTC (thermostat) fault' and other similar things! There CAN be problems with poor connectivity between cables and plugs/ sockets which could cause similar symptoms. It realy needs a service call to identify/cure, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
May 16, 2011 | Hotpoint Aquarius WD640 Front Load...
Ctd80 hotpoint condenser dryer not heating up at all showing error message f 14 think its thermastat
Error code 14 indicates dryer element fault.
Checkelement-connections-and control module.
Please leave feedback.
Thanks.
Nov 15, 2009 | Hotpoint Dryers
Hotpoint aquarious vented tumble dryer no longer heats up can you just replace the heating element
Yes you can, but I would test it first to make sure it is faulty, as quite often it is a thermostat prob.
Please rate my solution.
thanks.
Nov 11, 2009 | Hotpoint Dryers
I have a heavy duty Hotpoint electric dryer and it doesn't not have heat anymore, will fluff clothes and goes through the cycle but there is no heat
This means that your heating element is no longer working, they are easy to replace if you have some basic handyman knowledge. If not I advise that you take it to an authorised service technician. I hope this helps.
Nov 02, 2009 | Hotpoint Dryers
Hotpoint Utima WD860
The error code F13 is indicating dryer thermistor open or short circuit.
This is located in the top of m/c, and it looks something like a thermostat wired in series with the element, if there is more than one, then it is advisable to replace both..
Plz rate my solution.
Thanks.
Jan 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wd440 heating but not drying
yes, the dryer is pants im afraid. weve had ours going on 4 years & it has broke down every 6-10months - seriously! the dryer will leave clothes hot & steamy but when hung up for 1/4hr they r dry! _ Hotpoint advised us that he machine is esigned his way - but dont believe a word from their corporate b***hit mouths!
Aug 11, 2008 | Hotpoint Aquarius WD640 Front Load...
Dryer cutting main power off after acouple of seconds
your heating element is the most likely cause of this. will need replacing
Nov 18, 2007 | Hotpoint TDC32 Electric Dryer
Open Questions:
See all Hotpoint Ariston AS66VXNA1 Electric Dryer Questions
Hotpoint Ariston AS66VXNA1 Electric Dryer Logo
152 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
