Question about Brother HL 5140 Laser Printer
Loud clunking, then stopping altogether
Loud clunking
    Problem Solver:
  • 14 Answers
Is the Paper feeding thru if not it could be the paper loader in the paper tray which you can fix by finding a object that will sit in there you could also tape it down this sound like it is the paper loader try this and if not Post back
Posted on May 26, 2010
  • ocvieve Oct 05, 2013
    Great advice... work for me, thank you!
Loud grinding/clunking noise when driving, lessens when I press the brake
Loud Noise Unknown Origin - Ask the GM Technician - GM-Trucks.com
www.gm-trucks.com > ... > Ask the GM Technician
Jun 30, 2006 - 7 posts - ‎3 authors
I get a loud clunking, grinding noise while turning to the right only, and ... I moved the passenger side tire to the rear driver side just in case it ...
can bad wheel bearing/hub cause loud clunking noises?
www.jeepsunlimited.com/.../showthread.php?...loud-clunking-noises
Nov 12, 2009 - 14 posts - ‎6 authors
driving home, i noticed some metal clunking sounds coming from the front driversside. at ... hmmmm....if it's grinding, then probably a bearing.
Front Clunking sound when driving straight. - TDIClub Forums
forums.tdiclub.com > ... > VW MKIII-A3/B4 TDIs
Dec 21, 2011 - I have a sporadic clunking noise from the drivers side front end. '98 jetta ... If I try to coast it gets really louder and more pronounced. ... whirring orgrinding could be several things: wheel bearing, brake pads due to a caliper ...
Quick Guide to Diagnosing Differential & Driveline Noises ...
Dec 26, 2015 | Cars & Trucks
Whirlpool wtw5100sq0 clunks when put on spin cycle
Does the washer currently work fine aside from the loud clunking noise? Does the clunking noise continue or is it just one loud clunk when it starts to spin? If its just one loud clunk then that is not a problem just ignore it as that is the clutch spring releasing, it probably starting making noise from the grease getting washed off when the washer over filled.
However how did the washer overfill? That issue should be addressed too. Sometimes though, if the tub is not centered from a heavy load the water will spill over the back but its not really an overfill.
Mar 25, 2013 | Washing Machines
Why does my transmission in my 1994 GMC Sierra make a loud "clunk" sound when shifting in to drive? also the service engine light is on
Service engine light could be something else altogether...I'd have it checked at your nearest Auto Zone or parts store. Most times they will do this free.
Now for the "clunk"...I'd suspect "U-Joints" in the drive shaft are going out.
An easy test is to drive and look at mirror mounted on the front window area.
Does the reflection have a vibration in it ? Does it "clunk" when placed in reverse as well ?
U-Joints are an easy fix...and given the model of truck I'd suspect a "U-Joint Clunk"...
Hope this helps...
Aug 27, 2011 | GMC Sierra 1500 Cars & Trucks
Machine made loud 'clunking sound' and stopped. Notice appeared to switch off and try again. Notice then said cannot cut paper.
Check that your cutting module has not fallen out of it's holder. I had this issue the other day and the cutting module had just fallen off the printhead.
May 20, 2010 | Canon iPF700 InkJet Printer
Just started to pull away from a stop in 1st and
sounds as though your input shaft broke, this would cause a loud clunk, cause it to feel as though in gear, and cause no pull.
Oct 26, 2009 | 1988 Nissan Maxima
1990 Yamaha Warrior Has a loud engine clunk when I shut it off.
that clunk is your compress release vavle you may need to adjust your vavles
Jun 22, 2009 | 1986 Yamaha RD 350
2003 Honda Pilot clunking and squealing down highway
check your axle, it sound like a bad axle.
May 05, 2009 | 2003 Honda Pilot
1998 FORD ESCORT SEDAN
This noise is caused by the bushings in the brake calipers being worn out
Nov 05, 2008 | 1998 Ford Escort
Loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Jan 11, 2008 | GE WJSE3110A Top Load Washer
Brother HL 5140 Laser Printer Logo
204 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
