Question about Honda Plumbing
Honda Water pump WP20X take pump a part Casing crack
How do I take the Propeller out of My Honda Water pump WP20X
Thank you
4 Suggested Answers
  • 366 Answers
SOURCE: one of the pool pipes broke and the water froze in
you should just have to replace the casing.
Posted on Feb 03, 2010
johnamyx
  • 108 Answers
SOURCE: Hi name is Dan.
That is a 64000 dollar question. It depends on your mechanical ability, the pump isnt that hard to install if that is all it is.. The big question still lies in is that all the damage and you will not know that until you get into it. My suggestion is find a mechanic to look at it for you and see how much damage there is .
Posted on Nov 03, 2010
  • 17115 Answers
SOURCE: I have a Shur-Dri 1 HP above ground pump, Model No. SD-100-01. The propeller is cracked and needs to be replaced. I cannot find anyone who sells just the propeller. They say I have to get a new pum
There is a possibility that this model is not supported any longer. What you are needing is an IMPELLOR. The company that makes sure dry has a lot of information here: http://www.pumpproducts.com/myers-m-39.html
Posted on Jan 23, 2015
I was running in a tank my new 5 HP honda 4 stroke and it quit pumping water...and the water is well above the cavitation plate.There was a stream coming out higher up when I started it.
Many manufacturers recommend removing the propeller to tank test small motors the small stream above is what is called a tell tale so you know the pump is working .
Aug 13, 2017 | Honda Boating
I have a Shur-Dri 1 HP above ground pump, Model No. SD-100-01. The propeller is cracked and needs to be replaced. I cannot find anyone who sells just the propeller. They say I have to get a new pump. ...
Jan 23, 2015 | Pool & Spa
How do I test the float switch and the pressure switch in an Asko D1976 dishwasher? Getting F2 with no water in the pan or in the machine.
i would assume be n/o.
if have VOM put on OHMS setting. touch ur leads together listen for tone. once verified it works. put on the terminals on switch. and manully switch it, to see if makes or breaks the contact
Nov 22, 2014 | Asko D1976 Built-in Dishwasher
Propeller pump
HAVE TO REPLACE PUMP
Dec 26, 2013 | Asko Washing Machines
The pump is not pushing water through. Wat is the
ure the propeller and shaft turn, but I woulsd dare to say that they are actually turning independant of each other. Sort of like a stripped nut on a bolt. They both look like they are in place and working, but when you add any sort of pressure they just don work the way that they are supposed to. I bet the shaft is actually spinning inside of the propeller, as soon as the water pressure is built up, it fails. Spinning it with your fingers will not imitate the real life pressures exerted on the propeller and shaft, that the water pressure exerts under load (in operation). I would either rebuild it with new parts (new shaft and Propeller) or just go out and buy a new one with a warranty. There is no other reason why this pump will jnot throw water through your system... NO REASON, unless you have the thing hooked up wrong, but I think that would be impossible, wouldn't it?
Apr 24, 2010 | Intex 2500 Gal Easy Set Swimming Pool...
My fuel pump on my cbr600fw is leaking. what could be the problem
Possibilities are: mount screws need to be tightened, tank is rusted through, cracked pump casing and bad fuel line connection.
Jan 17, 2010 | 1998 Honda CBR 600 F(3)W
Yamaha R6 2003, water pump leaks antifreezer solution, drips every 5 seconds or so, please help. thank you
You can do a free download of a service manual and a parts fitch manual at the site below. At the bottom of the Yamaha section you will find 6 R6 manuals. Yours is in there.
http://www.carlsalter.com/motorcycle-manuals.asp
What you will be doing is replacing gaskets/seals. If you find the water pump casing is cracked or corroded away, check the cost of a new casing at the dealership then Google " motorcycle salvage yamaha " and you can probably get a replacement there for less than at a dealership.
Please rate this solution. Thanks Red!
Apr 23, 2009 | 2003 Yamaha YZF-R6
Hi , my Karcher water blaster makes a horrible repetitive surging noise when its powered on but not when its actualy blasting. I suspect its the pump bypassing. Pressure is also down on what it used to...
Is there dribbling water coming out of the casing if you plug in the incoming hose but don't switch it on? This is usually the case. Either the seals have worn on the pistons (usually 3) or you have a cracked pump casing.
Jul 30, 2008 | Washing Machines
My washer is leaking...
Open the rear panel on the washer. Check the 3 rubber hoses connected to the pump. Make sure there are no splits, or a **** in any of them. Also look at the pump and make sure the casing is not cracked and dripping (if coins enter the pump they can crack the casing, causing a leak). If there is a leak in a hose, replace that particular hose. If the pump casing is cracked, replace the pump.
Apr 11, 2008 | GE Spacemaker WSLP1100D Top Load Washer
Plumbing Logo
158 people viewed this question
Top Honda Plumbing Experts
rlev_7
Level 1 Expert
Matt Olenzek
Matt Olenzek
Tony Crow
Are you a Honda Plumbing Expert? Answer questions, earn points and help others
