Hi, my Onkyo TX8522 just clicks. Tried unplugging for a few hours and power on again but still clicks. Think it night be power supply fuse but have no directions.
    President:
  • 1,194 Answers
Try resetting your device.
To reset the receiver to its factory defaults, turn it on and, while holding down the [VIDEO] button, press the [STANDBY/ON] button.
If resetting your device does not solve your problem, you may need to contact Onkyo service center for repair.
Thanks for using Fixya.
Good Luck and have a nice day.
Posted on May 26, 2010
Tr-nr616 will not power up what do you think it might be like 20+ years ago i had onkyo amp and pre amp it was a fuse but
Hi Kevin, I am sorry that you are having an issue. Please try removing all of your speakers and unplugging the receiver for at least on hour. Plug in and turn on. If the receiver does not power up it would need to be serviced. Thank you, Onkyo USA
Oct 17, 2016 | Onkyo Audio Players & Recorders
65h84 toshiba wont power up after 30 min power outage.
hi Aaron,
please check power button,
bridge rectifire,
bleeder resistor or big cement resistor closed to power input area,
smoothing cap charged to 300v (i assume your power grid is 220v),
when you plugged in and it is not discharging for few min.that means power supply not starting up.
check the power supply bord for any phisical damage burn marks etc...please do the check and come back.
regards,
nuwan
Jan 08, 2014 | Televison & Video
ONKYO TX8522; Using it as a 2nd receiver to push zone 2 (4 speakers) in basement. When TV, LG BluRay, iPod, or radio selected for receiver 2 zone 2, it works great! When I select Padora thru the same...
I've seen some posts that talk about an incorrect or too high digital audio bit rate causing this. If it's only digital sources I'd look at that.
Feb 04, 2011 | Onkyo TX-8522 Receiver
Onkyo tx8522 it works but no sound
Hi...
Is the tape monitor turned off?
Try playing a CD thru it and listen on headphones
Let me know how that turns out
Jan 21, 2010 | Audio Players & Recorders
Yamaha RX-V750 wont power up
Check the fuse. You might have had a power surge which blew a fuse. If not, check the fuse for the socket. Reset the fuses for that socket. If it still doesn't work, it sounds like the internal boards got fried, or the power supply got fried. The power supply is replaceable, but we don't know if it is the power supply. To check, connect a voltage meter to the power supply.
Something like this happened to me. I found a new kenwood stereo next to the dumpsters, stickers and all still on it, plugged it in, it worked, shut it off to plug in a speaker, didn't turn back on, months later after leaving it plugged in, turned on, I used it, then shut it off for the night, in the morning the standby light was still on, tried turning it on, but it wouldn't for some reason, unplugged it, then the light wouldn't come on, it was once again sitting on a shelf as a paperweight, one day it randomly came on again, and now it 100% works, and I use it as an amp for my RE audio subwoofer, and its worked great since! The reason this kinda applies to you is because its kinda simmilar what happened to you. Just leave it plugged in, and maybe sometime you will walk by it noticing it works.
Oct 10, 2009 | Yamaha RX-V750 Receiver
SR1000T won't power on
The click sound is the relay clicking when the power on. The power supply has something wrong so the protection relay is triggered and cut off power to main board. Test fans see if they are stucked and spinning smouthly. Smell if anything burn from the power supply box. Most likely, you need to change the power sup. Good luck
Aug 11, 2009 | Compaq Presario SR1000T (568657) PC...
Onkyo HT-SR800 won't turn on
If you call Onkyo directly, 201-785-2600, there is a procedure to "reset" the system, something like holding the power button on and holding down another button for a few seconds. Can't remember which, so I can't be sure, but try giving them a call.
Jan 02, 2009 | Onkyo HT-SR800 System
Onkyo receiver (HT-R430) cutting out after a few seconds
This problem is related totally to the remote control.Pres the CRL button rapidly during that 3 sec interval and get the nunmber down
Nov 12, 2007 | Onkyo HT-S680 System
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
47 people viewed this question
 Grubhead
Grubhead
