Question about RIM BlackBerry Pearl 8100
My hp ipaq voice messenger 500 series wants to format my storage card on start up
I have the same problem with my hp ipaq voice messenger 500 series wants to format my storage card on start up.
Posted on Jun 10, 2008
SOURCE:
Hard reset of my hp ipaq 510 i forgot my password
s.gifs.gifHP iPAQ 500 Voice Messenger Series - Resetting the Device
Sometimes you need to reset your iPAQ if, for example, it is not responding to your pressing a button or your tapping the screen.There are two types of resets.
  • Soft Reset - A soft reset stops all running applications, but does not erase any programs or saved data.
  • Factory or Hard Reset - A factory or hard reset clears all user-installed settings, programs, and data, and restores your iPAQ to factory settings.
Performing a Soft ResetPerform a normal or soft reset to stop all running applications, to restart the iPAQ after installing a new application, or if the iPAQ locks up.CAUTION:Make sure to close all running applications before performing a soft reset, since a soft reset erases all unsaved data in such applications.Perform a soft reset using one of these two options.
  • Turn off the iPAQ by holding down the End key.c01118005.jpg1 - End Key
  • Remove the battery of your iPAQ.
Performing a Factory or Hard ResetPerform a factory or hard reset when there is a need to clear all settings, programs, and data from the RAM.CAUTION:Performing a hard reset will return the iPAQ to its default settings and it loses all information (files and settings, among others) that is not recorded in the ROM. Back up all important information or data before performing a hard reset.Follow these steps to perform a hard reset and return your iPAQ to factory settings.
  1. Turn off your iPAQ by holding down the End key.
  2. Then hold down the center of the 4-Way Navigation key and turn on the iPAQ again while continuing to do so.c01118006.jpg1 - 4-Way Navigation Key2 - End Key
  3. A confirmation screen opens asking whether you want to perform a hard reset or not. SelectYes . The iPAQ will reboot with its original factory settings.
NOTE:The applications and data present on your iPAQ before performing the hard reset can be reinstalled by synchronizing your iPAQ with a computer using ActiveSync/WMDC (Windows Mobile Device Center).NOTE:If you don't want the iPAQ playing a tune after you turn it on, create a new text document and save the document as StartUp.wav. Replace this new document with the file on your device.
Jun 20, 2012 | HP iPAQ 510 Voice Messenger Smartphone
How to unloked my cellphone hp ipaq 510 voice messenger?!
any mobile & memory card and other many devises unloke code
simply connect it to the pc and open its file in note pad and
FIND YOUR PASSWORD
Jul 26, 2010 | HP iPAQ 510 Voice Messenger Smartphone
Hp ipaq 500 series voice messenger. it suddenly shows a black screen with a white writing. it only goes off when the battery is removed
Is there any instance that the phone was dropped or exposed to any form of moisture? There might be a problem with the LCD of the phone, you need to have it checked with a technician.
Jul 06, 2009 | Cell Phones
Backup and restore
you can format your phone without taking the card out from your phone...because when you format your phone...it does not format your storage card...
go ahead and format your phone...
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Dec 17, 2007 | HP iPAQ h6315/h6365 Pocket PC
How to format storage card?
You don't need to format it if it doesn't ask you to. You can do it from your PC or a camera. If neither of these are possible then you can get Pocket Mechanic on your IPAQ which will do it..
Sep 07, 2005 | HP iPAQ H3950 Pocket PC
Failure to recognize storage card
Do you have somewhere else that you could format the card - camera, PC ??? Also you could try Pocket Mechanic which has a free 7 day trial... http://www.pocketgear.com/software_detail.asp?id=12178&associateid=373.
Sep 07, 2005 | HP FA162A for iPAQ 2215/4155 Keyboard
RIM BlackBerry  Pearl  8100 Logo
96 people viewed this question
Top RIM Computers & Internet Experts
Ekse
Vincent G
Vincent G
ChrisChris70
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
