Question about Acer NSK8458AN Keyboard
Where is the scroll lock button on the acer 5517
Where is the scroll lock button on the acer aspire 5517 laptop? I am needing a scroll lock or hot key to switch a USB 2.0 4-Port Manual Share Switch to my laptop use?
Subrat20
  • 21 Answers
SOURCE: fn key combo for acer aspire 3680 wlan when wireless switch broke
on pressing  fn+F1 will give you the details of all the combo keys that you can select find out your one
Posted on Jun 21, 2009
Gort007
  • 1187 Answers
SOURCE: Just bought Acer laptop (series 5517) and the
DOES THE MOUSE WORK OK?
If not, re-boot and press the [F8] key to get into the "Safe Mode" screen. See if the keyboard works in Safe Mode.
If so, go tothe Control Panel and select "keyboard" and update the drivers.
If not, then re-boot and select the [F8} key again, but choose "Start computer in last known good configuration"
If it still doesn't work, but the mouse does, then the keyboard is disconnected or the connector is loose; open 'er up and connect it.
Posted on Sep 28, 2009
pumpkinman
  • 1147 Answers
SOURCE: wireless switch is broken on my acer aspire 3680.
No you need switch,if you use a tiny screw driver you can turn it on with that if its just the plastic peice thats broke.use the screw driver to slide the mechanisam
Posted on Oct 05, 2009
SOURCE: acer aspire 5517 touchpad doesn't work. We have
On my Acer Aspire 5534, up above the keys there are 2 buttons that are side by side. one is to turn the wireless off and on and the other one is to turn the mouse pad off and on.
Posted on Dec 21, 2009
SOURCE: acer aspire 6530 wireless switch is off, how can I turn it on ?
press the button that looks like a satellite dish on the right of the fast forward button above the Num Lock button.. it should start flashing orange
Posted on Jan 27, 2010
My acer aspire 5517 laptop green blank screen and changes to red every 4 second!
More than likely the screen Inverter, Anowarul.
http://www.amazon.com/Acer-Aspire-Series-Inverter-Board/dp/B006BHRG9E
However the problem should be diagnosed.
Problem can be;
1) Graphics chipset
2) Video Cable
3) screen Inverter
4) LCD screen
I have a diagnostic flowchart you can follow, if you wish.
Post back in a Comment.
The plastic frame in front the LCD screen is the Display Bezel.
(Acer? LCD Bezel)
Once removed the screen Inverter is right there in front.
Mounted to the bottom of the LCD screen's Screen Frame.
Service Manual, (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Go to where it states - Aspire 1200 (1200 in Blue)
Drop down to the 7th line. (5310G)
Scroll across, and click on 5517.
http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Regards,
joecoolvette
Mar 19, 2013 | Acer Aspire Computers & Internet
Hi, I can't remember what buttons to push on my keyboard to switch from one computer to the other with my belkin 2 port kvm switck? can you help me, Ive just set up the system in another office. Thanks...
Short answer:
There are two ways to switch from one machine to the other with the keyboard
1. Press Scroll Lock key twice, then the Up or Down arrow key.
2. Press Scroll Lock key twice, then enter 01 or 02.
Long answer (from the manual posted at www.belkin.com):
You can select which computer to operate by either the front-panel push button
located on the top of the Switch or through hot key commands. Note that it will
take 1-2 seconds for the video to display after switching. This is due to the
refresh of the video signal. A re-synchronization of the mouse and keyboard
signal also takes place. This is normal operation and ensures that proper
synchronization is established.
You can conveniently change ports on the Switch through a keyboard command
sequence using the "SCROLL LOCK" key and up and down arrow keys. To send
commands to the Switch, press the "SCROLL LOCK" key twice within two seconds.
You will hear a beep for confirmation. Then you can press the up or down arrow
keys to switch between ports.
You can switch directly to any port by entering the Switch port number you wish
to use. For example, if you press "SCROLL LOCK", "SCROLL LOCK", "2", the
computer on port 2 will be selected.
AutoScan Mode
In AutoScan mode, the Switch remains on one port for eight seconds before
switching to the next. This time interval cannot be changed.
To enable AutoScan mode, press "SCROLL LOCK", "SCROLL LOCK", "S".
Note: There is no mouse or keyboard control in this mode by design, in order to
prevent errors. If it were enabled, the user could move the mouse or use the
keyboard while the KVM Switch is switching to the next port. This could interrupt
communication between the computer and Switch that might cause erratic mouse
movement, or result in errant display of characters when using the keyboard.
To disable AutoScan mode, press the space bar.
Feb 05, 2011 | Computers & Internet
Does my acer aspire 5517 have a built in microphone for the webcam?
Sorry your laptop doesnt have a microphone only a webcam here are the specs for that laptop http://www.geekwithlaptop.com/acer-aspire-5517-notebook
Jun 04, 2010 | Acer Computers & Internet
ACER ASPIRE 5517 Notebook computer. Erratic cursor
i have seen this problem in other laptops and the mousepad had to be replaced.
Apr 27, 2010 | Acer Aspire One PC Notebook
How do i unlock the scroll feature for my acer aspire 5517 laptop?
press Fn key and F12 at the same time.......(note Scr lk is written below F12 key)
Mar 05, 2010 | Acer Computers & Internet
Acer NSK8458AN Keyboard Logo
431 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
