Question about Kenmore 99123 Electric Kitchen Range
Electric Kenmore 790.9601 0405 Heating Element Issues Barely 4 yr. old unit starting to burn/overbake food at relatively low 350-400 settings. Now when set to Broil, Top element will NOT heat, but bottom element does... 13mths. into New unit (1 mth. past warranty) Bottom Element blew out, and had to be replaced, which Sears refused to cover... How can I troubleshoot Thermostats, Contol Panel, Elements, without calling out the Sears Boys, and/or spending a mint? Thanks,,,
fridgetech
  • 473 Answers
SOURCE: Electric Kitchen aid, model kerc607...broil elements
What is the complete model # from the sticker on the range? I will need that so I can look into this for you. I will say that I have seen, in several cases, where the oven control gets a surge and fries after an element has broken.
Posted on Nov 10, 2007
TheMobilian
  • 8220 Answers
SOURCE: Large Heating Element no longer heats
Is it the eye itself or the receptacle? solution: yank out the questionable eye and put another from the stove in that one. swap em around and determine if the eye is bad or the receptacle. The receptacle are around 10 bucks.
9f0ea2e.jpgpart number 330031
Posted on Mar 02, 2009
jharper501
  • 139 Answers
SOURCE: purchased a kenmore electric range around 1 and
check the circuit breaker for the house ..the breaker prob. blew ..if not ..unplug range ..remove the back panel to view all them wires an switches ..look at all of the wires an connections for burt or broken wires ..if all looks good ...their may be a thermal fuse located where the switches are .. look real good with a flash light ..you will find the problem ..you may need a volt/ohm meter to test voltage ..or thermal fuse ..let me know an good luck../joe/
Posted on Aug 29, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Kenmore 96412 electric range and the top
It sounds like you have done everything that you can do short of replacing the control board for the unit...
That is the next thing that I would do to try and fix your problem..
heatman101
Posted on Dec 11, 2010
wrightly
  • 140 Answers
SOURCE: Kenmore electric range 790.91011200 When set in
yes. you can do a simple continuity test to be sure (on the broil) element, but you're gonna spend at least 20 dollars on a volt/ohm meter. if you have one already, you're in luck. just remove the element and test the prongs for continuity (usually setting RX1). more than likely the element just needs to be replaced
Posted on Jul 07, 2011
Kenmore c970-440935. Why does one element overheat?
Kenmore Elite C970 440935 Replace heating element range
www.fixya.com > ... > Ovens > Kenmore > Kenmore Elite C970 440935
Kenmore Elite C970 440935, replace heating element range related issues. Get free help, solutions & advice from top Kenmore experts. ... Kenmore 40494 / 40495 / 40499 Electric Single Oven. 793 Questions ..
Aug 05, 2015 | Kitchen Ranges
Kenmore heating element problem
Thank you for contacting Fixya.com.
Sometimes dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Also check the bellow links related to your issue:-
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
http://www.ehow.com/how_5112087_replace-kenmore-elite-electric-dryer.html
Please get back to us if you have any further query.
Have a nice day.
Dec 02, 2010 | Kenmore Dryers
BOUGHT A HOME IN UNION NJ WITH THE GE DOUBLE WALL OVEN TOP PART DOES NOT WORK BOTTOM PART BURNS THE FOOD NEED REPAIR PLS CALL ME AT 908-391-8942
The heating element in top unit may be loose or burned out. Push the element toward the back and see if it engages. If it is already engaged, you'll need to replace it. It is simple to remove it.Just give a firm tug and it should come right out. To replace with a new element, simply push it in firmly.
With the bottom unit, are controls set for bake? If they are set for "broil" you are using direct heat and it will cook foods more quickly.Also, is bottom unit a convection oven? If so, foods will cook in 1/4 to 1/2 the time for a conventional oven, so you'll have to adjust your temperature down about 25-50 degrees and shorten your cooking time.
Nov 01, 2010 | GE Built-In 24" Double Electric Wall Oven
Kenmore 66722 electric dryer - barely started one day then stopped working. When start button is pressed, ticking noise is coming from cycle selector. Opened the control panel and noticed that the plastic...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 18, 2010 | Dryers
Large oven burning food on top shelf when in fan assisted mode
Always cook food in the middle of the oven. Assuming this is an electric oven, there is a heating element up there that will cause burning of food, much like a broiler works.
If you must cook that high up in the oven, then cover the food your cooking with foil.
Dec 16, 2009 | Kenmore Ovens
I have a 4 yr old kenmore glasstop electric range. Problem exists with the broiler as it comes on when I set the oven to bake.
this is normal
about 8 years ago manufactures started to include the broil element in the preheat cycle to heat the oven faster
it should cycle down once the set temp is reached
Sep 27, 2009 | Kenmore Kitchen Ranges
29'' Kenmore electric dryer series 110 not heating up
Check the following to address this issue.(Most common issue will be a burned out thermal fuse.)
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Aug 03, 2009 | Dryers
My dishwasher leaves dishes wet and with food particles on them.
The wet is from either a burned out heating element or an improper setting. The food part--clean the screen at the drain, inside the unit.
Jul 07, 2009 | Kenmore Dishwashers
Kenmore oven lower element sporadically heating.
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
5 yr old Jenn Air Electric oven won't maintain oven temperature
Technician just left our house with same issue. Jenn-Air had issued a technical bulletin as the temperature probe is mounted directly to the heating element, and measures the heat of the element, not the oven. Their fix is a revised temperature probe that goes at a 90 degree angle away from the heating element.
If your temperature is consistent, just off by a set amount of degrees, there is an adjustment you can make at the control panel.
Mar 09, 2009 | Jenn-Air JJW8130D Electric Single Oven
Kenmore 99123 Electric Kitchen Range Logo
575 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
