Trying to remove the finisher so i can fix it or at least look at it.
  • 1,326 Answers
It may be easy or hard???? It all depends on what make & model copier you have???? I can think of about 12 different makers and all there models have a different finisher on them.....
Posted on May 27, 2010
How can i fix the error E000505-0001
web search canon printers/copiers error codes for a full list and fixes
Sep 13, 2015 | Canon Office Equipment & Supplies
Sharp code f1-87
This was a common problem with these finishers. It has to do with the stapler unit rotation binding up as it moves into the stapler compiler. Even if you don't use the stapler, it still does a diagnostic test at power on. Here is a cheap easy fix that usually works. First you need to open the finisher front door where the staple unit is located. Remove the white inner cover of the finisher that you gain access to the stapler through-about 5 screws. You will see a blue solonoid in the upper right hand corner. There are tick marks etched into the metal frame, take note of the position of the solonoid to these marks. To adjust the solonoid, open the door on the right side the paper exits and look at the back of the frame where the solonoid sits. You should see two small phillips screws about 2 to 3 inches apart. Loosen them and change the position of the solonoid referencing the tick marks. This will change the angle the guide hits the stapler compiler, which is usually the cause of these error codes. I would not recommend spending 700 dollars to try and have this problem fixed, because after some time it will come back. You can also try opening the right finisher door and look down into the finisher. You will see two belts and two plastic fingers about 4 inches long with a point on the end. Take some fine sand paper or a small file and file down the back bottom side of those fingers. It is a tight fit to get back behind them. You want to remove any small nicks in the plastic that have formed by the stapler guide hitting them. Good Luck
Jul 25, 2012 | Sharp AR-M455N Copier
Trying to fix drip on cold water. Removed screw
I don't know what type of faucet you have. If you try to pry start from the back of the faucet. That way if you mess up the chrome (or other finish) it won't be so obvious. And make sure the water is turned off.
Mar 10, 2010 | Plumbing
I have a problem about autorun virus and if it is connected to pc it is hard to eject when i try to safe remove.how can i fix it,my phone is k810i
leave it for scan moment it finishes the scan sudden remove it it wont cause any problem to ur system and first thing u have do scan ur computer
Feb 24, 2009 | Network Associates VirusScan ASaP Silver...
Plz help
Did you try to diconnect the finisher or sotor from the copier? Is the error code a E 900. You may have a problem with your finisher. It can also be the hard drive on the back of the copier, it is used with the finisher. Try to unplug the finisher with the power off and tur it back on.Will that fix the problem for now.... Get back to us
Jan 24, 2009 | Gestetner DSm645 Digital Imaging System
How can i find out my parking brake adjustments on my 2003 ford escape?
Parking Brake Cable Adjustment Vehicle with low series floor console
  1. Remove the floor console front finish panel.
    1. If equipped, remove the manual transmission shift knob by turning counterclockwise.
  1. Remove the floor console rear finish panel.
    1. Apply the parking brake.
Vehicle with high series floor console
  1. Remove the floor console finish panel.
All vehicles
  1. Remove the adjustment nut clip.
  1. Turn the parking brake control adjustment nut so that the parking brake control stroke is three to five notches when pulled.
  1. Confirm the parking brake is applied.
  1. Install the adjustment nut clip.
  1. Install the floor console rear finish panel.
  1. Install the floor console front finish panel.
    • If equipped, install the manual transmission shifter knob by turning clockwise.
Jan 21, 2009 | 2003 Ford Escape
K JAM
that happend to me once, i totally freaked out.... try turning it completely off, remove the sd card, then turn it back on.
once your phone has finished booting up (and all programs have finished loading), put in your SD card.
If that doesn't work you could always hard reset the phone (sometimes that fixes it)
Jun 25, 2008 | i-mate K-jam Smartphone
Internet explorer will not open any web sight
go to the control panell..
select add/remove prog..
select add/remove windows component
and tick internet explorr..
just foolow up the finish..
it will be can fix it..
thanks for using fixya..
good luck
Apr 21, 2008 | Computers & Internet
F-1 finisher not stapleing
Have you tried the staple setup procedure, or maybe swap the Finisher DC Controller off the Finisher that the known-good stapler carraige came from? I think DC Controller.
Nov 16, 2007 | Canon imageRUNNER 5000 Copier
jasbo
jasbo
