Question about LG WM-1832C Front Load Washer
Sounds like the inside is a jet plane while in spin cycle very lose inside like something is loose ore broken like a belt
  • 552 Answers
If the washer is vibrating a lot, then you could have a bad drum bearing. There are also counter weights and shock absorbers that could be bad. The best thing to do is take off the back panel and look inside. many times the problem can be clearly seen. Usually a loud noise like a jet plane on spin cycle means a bad bearing. This can be costly unless you can do the work yourself. The parts are readily available.
Posted on May 26, 2010
SOUNDS LIKE JET PLANE WHEN IT GETS BY RINSE AN SPIN TIME
I assume you mean it sounds like a jet plane when it spins, if so, I suspect a bad tub bearing. Depending on age of the machine, probably too expensive to repair.
Mar 07, 2015 | Maytag Neptune Washing Machines
Need to know what the error codes mean on a whirlpool cabrio model wtw6400sw3 F54,F82,F83,F84. Please help.
you may have something between the tubs or your bearing is going bad . does it sound like a jet plane in spin cycle?
Feb 20, 2013 | Whirlpool Washing Machines
Jet Plane noise in spin cycle
The bearing in the outer tub assembly is going out and you will need to replace it. Here is the part if you want to order it but you might want to look into buying another machine.
Nov 20, 2012 | Washing Machines
Model FWT449GFS1 Frigidaire Gallery problems: roaring during spin cycle, worsening drum won't turn manually and this last run, was making sounds like slipping belt. During drain time, can hear coin in...
most likely transmission bearings are worn out (sounds like a jet plane taking off) unfortunately this requires replacing the transmission which is a costly job.
Sep 07, 2009 | Frigidaire ATF6000ES Front Load Washer
Magic chef cav2000aww no spin. Is there a clutch ajustment from under the machine on pully,
I would request you to please do the following steps to verify why it’s not spinning.
If when the spin cycle is turned on and there is a humming sound but there is no movement the belt is the problem.
Sounds like you have a broken belt or a bad motor. The easiest way to tell if the belt is bad is to reach inside the drum and turn it. If it turns very easily, you probably have a bad belt or something has caused the belt to jump off, such as a loose pulley or bad bearing. If it feels like there is a good amount of resistance, or a kind of "winding up" noise, then the belt is still on and you likely have a bad motor. Also, you could just scoot the machine out, unplug it, and remove the back cover a look inside to see if the belt is still on the pulleys
Thank You for using Fixya.com
Jul 31, 2009 | Magic Chef CAV2000AWW Top Load Washer
Extremely loud spin cycle after belt replacement
It sounds like the belt is the wrong size meaning that it is to tight or to lose. Check to also make sure that the brake is disengaging and not rubbing on the drum
Apr 18, 2009 | Amana ALW480DA Top Load Washer
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
Squeaking during spin cycle
check the pump there is something in it, it cam be disassembled mark the metal to the plastic with a line across the metal and plastic so you dont have to guess how to realign
Apr 30, 2008 | Maytag PAV2300 Top Load Washer
LG WM-1832C Front Load Washer Logo
370 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
