Question about SkyScan 86709 Atomic Wall Clock
The outside temperature is not being transmitted to the clock after I changed the batteries. What can I do?
    Genius:
  • 1,400 Answers
Hello
Have you configured the clock to see the temp?
Some models can take 6 to 24 hours before they get a ping from the atomic clock,before working properly.
Posted on May 26, 2010
  • 2 more comments
  • auntlulu7 May 26, 2010
    How do I configure the clock to see the outside temp?
    How do I configure the clock to show the outside temperature?
  • mpcheesman1
    mpcheesman1 May 26, 2010
    Im not sure, so im going to unlock this question to another expert.You do not need to accept my answer.
    Sorry i couldnt be more helpful
  • mpcheesman1
    mpcheesman1 May 27, 2010
    I found a link to skyscan.
    http://skyscan.info/content/home.html
I have the Atomic Clock model W86111. I had to change the batteries on the outside device. The clock outside temp just flashes 63.5 all the time. How do I make it sync to the device outside?
Remove all batteries from outdoor sensor and weather station.
Press one of the buttons on the weather station at least 20 times to clear all memory.
Verify that the weather station is blank before proceeding (there may be lines painted on
the screen that will show when power is removed).
Leave both units without power for 15 minutes (very important).
Insert fresh batteries into the clock.
Insert fresh batteries into the outdoor sensor.
Press the TX button on the outdoor sensor to transmit RF signal.
Keep the outdoor sensor 5-10 feet from the forecast station.
When RF connection is established, the temperature will appear on the station. Allow the
outdoor sensor and weather station to sit together for 15 minutes to establish a strong
connection.
Oct 14, 2017 | Home
Can reset everything on my SkyScan Atomic Clock except for the outside temp. Have new batteries in both units. Main clock and outside remote thermostate..Any suggestions??
I expect that since the unit reads the outside temperature from the remote thermostat, there is no need to "reset" the displayed number since this data is obtained live from the thermostat.
Nov 04, 2015 | Home
Do you have to change batteries on clock inside house along with outside batteries to get correct outside temperature
My most consistent (best, repeatable) results with this process are to replace both sets of batteries, both in the clock and in the outside temperature sensing unit. Start by removing all batteries out of everything. Now replace the batteries in the outdoor unit, then (within 30 seconds) replace the clock batteries. The temp unit should begin communicating normally within 5 minutes (or less) and yes, you will have to reset the clock,
Nov 01, 2014 | Lacrosse La Crosse Technology Wt-5220u-it...
I changed outside batteries; will not transmit out side temperature? need help
You may need to reset you inside unit by removing the batteries and restarting it. the outside unit should then be able to sycn to the base unit.
Dec 05, 2011 | SkyScan Audio Players & Recorders
My clock is nort showing up the outside tempertute
Seems to be a consistent problem with Skyscan. I have the 88800 model and my outdoor transmitter isn't transmitting the temperature either. We've replaced the batteries in both the transmitter and clock and nothing for outdoor temp. It's only been used for 9 months.
Nov 16, 2009 | SkyScan 86709 Atomic Wall Clock
Outdoor temperature doesn't transmit below about 32 degrees.
I have one of these, and below freezing, the sensor is frozen.
Apr 18, 2009 | SkyScan 86742 Digital Atomic Wall Clock
Outdoor transmitting
These devices have a limited range, normally 20-30' (~6-9m) and that range is influenced by the material that separates them. Any metal structures in their path can shorten the useful range. Also, I think all of these transmit only a second or two every few minutes to conserve battery power.
Mar 03, 2009 | SkyScan 86742 Digital Atomic Wall Clock
Outside temperature won't work
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
Nov 27, 2008 | SkyScan 86709 Atomic Wall Clock
OUTDOOR TEMPERATURE
Also,
Sep 03, 2008 | SkyScan 86709 Atomic Wall Clock
Remote Sensor
make sure your time is set and the atomic clock time is recieved, then leaving the rear cover off of the transmitter, push the "tx" button not the "c/f" that is just for centegrade or ferenhight. you will see the red light on the front of reciever flash in a few seconds. The temp should display on your clock screen. If not, did the red l.e.d. light on transmitter flash. If not, its not sending data to clock. I have to reset and hit transmit every time I replace batteries on transmitter. Had no problems for over 2 years of using outside. If your not getting a reading with transmitter sitting next to clock after hitting "tx" button you may have defective transmitter.
Jan 13, 2008 | Homedics Sound Spa Premier SS-5000 Clock...
SkyScan 86709 Atomic Wall Clock Logo
184 people viewed this question
Top SkyScan Home Experts
Jerry Greenberg
Jerry Greenberg
Rick Goldsmith
Rick Goldsmith
Level 1 Expert
Are you a SkyScan Home Expert? Answer questions, earn points and help others
