Question about Toshiba 55H70 55" Rear Projection Television
מסך ש×?×?ר dramatic theatre ×?ש ל×? שנש×?ר ל×? ×?מסך ×?×?×?צ×?× ×? א×?ך מ×?ל×?פ×?ם ×?מ×? ×?מ×?×?ר
    President:
  • Toshiba Master
  • 1,779 Answers
Replace the Micro!
Posted on May 26, 2010
DAV-DZ777 no longer plays TV sound through home theatre. DVD, radio etc still works...
The hdmi needs to be ARC compatible and connected to the HDMI connected labled Arc.
Sep 10, 2016 | Sony Home Theater: DAV-DZ777 CODE FREE...
I have a toshiba dramatic theatre tv that is on wheels that i received from someone, but the remote is lost and the convergence settings is out. where can i buy a remote for this tv in cape town as th
Hi Carmen.
I also had one of theses rear projection Toshibas. Tedelex are the agents for Toshiba in SA, however they aren't very helpful. Your best bet is to buy a one 4all remote and go through the Toshiba codes. This is what I did when I lost my original remote. It worked fine for me. I have since given this TV away so I can't give you the exact code, but those in the instruction manual do work.
Jan 07, 2015 | Toshiba Televison & Video
Looking for an insrtruction manual for Dramatic Theatre CT 9969
Found a manual on the net under manuals-in-pdf.com thank you problem solved
Dec 14, 2009 | Toshiba Televison & Video
Connect home theatre to ps3 to 32" lcd tv
if your tv and home theatre system as all hdmi or component hook ups then follow these steps but only use all one or the other cables.
1. hook the cable from the ps3 to the home theatre "imput slot" (you choose which one you want to use)
2. hook a cable to the output slot on the home theatre system to your imput slot on your tv.
3. turn on all three systems, put your home theatre system on the correct function (which ever slots you decided to put the cables in to the input slots) then turn your tv to the correct AV channel
Apr 05, 2009 | Vizio L32 32 in. LCD HDTV
Hi can i connect my transcend mp3 player directly to my home theatre so that i can get the music output in my home theatre speakers , if i can please suggest how?
easy, just find the AUX port on the home theatre system then turn the system to AUX and hook a cable that has 2 male ends (the ends that go into your mp3 players headphone jack) to your ipod and to your home theatre, you will have to buy this cable seperatly
Jan 03, 2009 | Transcend T-Sonic 840 MP3 Player
Sound goes off
You probably have too much power running to your power strip that you probably have your xbox, playstation, tv and home theatre system plugged into, try using seperate wall outlets for your tv and home theatre system
Dec 20, 2008 | LG LHT854 Theater System
Bad picturre on toshiba tv
Good Day, pieps57;
Corrective Action: Remove the MVUP13 Hyper Module from the TV chassis, remove the top shield and replace the 10uf, 16v capacitors using Part Number 24619040. It’s recommended that all of the capacitors identified be replaced (Note: These capacitors are low impedance surface mounted aluminum electrolytic capacitors. Care should be taken to avoid damaging the PCB while replacing these capacitors.) CAPS: cx178, cx221, cx230, cx241, cx250, cx261, cx270, cx541, cx670 & c514, c5030.
Good Luck, Big Irish.
Jul 07, 2008 | Toshiba 42H81 42" Rear Projection...
Home theatre but TV without audio outlet
I would suggest that you smash
Philips HTS w/a hammer!
I had better sound from TV alone! Only 2 speakers put out sound from TV. Recordings from DVR can not be heard very well w/all volumes at max. System sucks! You get what you pay for! $2500 LCD TV sounds worse w/Philips HTS than my son's $300 TV! ALL cables hooked up as instucted!!!!
Dec 17, 2007 | Audio Players & Recorders
Toshiba 55H70 55" Rear Projection Television Logo
123 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
