Question about Philips 42 in. Plasma TV
I have Philips 42 inch plasma tv and have the same problem as Peter Seagge bbc 1 and bbc 2 sticks only happened after digital changeover. HELP
  • 1 more comment
  • astrid prieto May 26, 2010
    Beg your pardon? Explain how you acquire BBC 1 and 2 signal I watch that for free FTA by satelite set top box not even from Sky. What complicating setup you have?
  • shazzadaws May 26, 2010
    sorry havent got a answer but have exactly the same tv and same problem as you.
  • shazzadaws May 27, 2010
    Its has integrated freeview teletext is missing too, since digital changeover, bbc 1 and 2 signal sticks when you try to turn to another channel and then the tv switches itself off.
  • 297 Answers
I have no problem.
you have a problem.
so how you receive BBC
my TV is very OK and i see all free on AStra2/Eurobird no problem.
Posted on May 26, 2010
  • astrid prieto May 27, 2010
    freeview is this strange UK system. next time get an ordinary lose satelite set top box and a dish, far better (100 euros deal)
    can you rescan system to sse the channels correct
    you must have an instruction manual
    in the UK retuning was made widely public
    I quote a case:
    Also have a Philips LCD TV with inbuilt Freeview. Used the Reinstallation option which worked......until next time I switched on - Ch5 and ITV3 gone. Ran reinstallation option again and they came back. Then, next time swtiched on, gone again. Seems I have to reinstall each time I switch the set on. Oh, the 21st century.....we can map the human genome but we can't organise a p*** up in a brewery.
    What goes wrong here, after retuning please make sure you SAVE the new scan results, exiting from retuning without SAVING wuill leave you with this case.
    Please read your manuals
    Here a good guide:
    http://www.ukfree.tv/retune/Philips_PFL7...
    And I really do deserve a 4 star rating for my solution.
I have a 42 inch philips plasma tv with a broken screen, could i replace it with a screen from a panasonic 42 inch tv
No--this is called a PDP or plasma display panel and no two (even same brand) can be interchanged.
The cost of a Panel exceeds the cost of a new set--broken screen=fatal issue.
Mar 31, 2012 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Menu pop up
there may be an issue with the push button on the side flaking out check and see if it is sticking on the cover if not I would replace that board
May 27, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
42'plasma phillips tv
I had the same problem and fixed with a great online tutorial. Just replace 3 capacitors available at Radioshack onthe the board. 2662, 2663, 2664 1 is a 1000uf the others are 100uf. Max Volts need to be over 25. It worked great, check http://dynamicorange.com/2008/06/25/fixing-a-plasma-tv/
for more detail.
Jan 06, 2009 | Philips 42FD9932 42 in. Plasma Television
My philips 42 inch plasma model # 42PF9966/37 wont turn on. Red standby light is not on
Hi. Try, in back yours tv on left side of the power corde connector have on hole, inside of this hole have one main switch, using one insulated stick and sheck if this switch is off ( may be not ) but try. If you heva esperience take out the back cover and check the fuse on power board. Good lock
Jan 03, 2009 | Philips 42FD9932 42 in. Plasma Television
Philips 42 inch plasma 42pf7320a/37
My TV this with this . What can be ?
philips-42-inch-plasma-42pf7320a-37-nhe5gy2xupfnvv1disgbrgaq-1-2.jpg Help me please
Nov 13, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
42 inch philips plasma HDTV vertical bar on screen
does the vertical lines appear like solid vertical bard infront of the pictire??
Jul 08, 2008 | Televison & Video
Philips ambilight 42inch plasma
You can fix this yourself with a software upgrade - get the upgrade from Philips website - go to www.usasupport.philips.com, enter your model number, click on the verison of your model ending in /37, and click on "Software & Drivers"; click on the link that says "Firmware Upgrade - Software". Instructions are on the same page - make sure you only transfer the .upg file, not the entire zip file to a portable memory stick.
Jun 08, 2008 | Philips 42PF9630A 42 in. Plasma Television
Resetting philips 42pf9730a/37 remote
Most of the problems with the Philps 42" plasma (other than fuses) can be fixed with a firmware update.
If you have a PC and internet connection you can download the firmware and tranferit to a 1 gig USB memory stick. turn off the TV insert the Memory st, turn on the TV and it automatically recognises the stick will go into upodate mode with on screen instructions for the user.
They have had problems in the past with HDMI and volume, HD pixel problems, all of which got fixed in these updates.
It is very intuitive and if you have the slightest PC savy, anyone can do it.
44hink
May 31, 2008 | Philips 42PF9630A 42 in. Plasma Television
New tv
You can go into the menu and adjust the picture setting. If that does not fix the iss and the set is under a year old then it will still be in warranty. Contact Philips at 1-88- 744-5477 and have them do the repairs under warranty. Don't do it your self because that will void your warranty.
Dec 16, 2007 | Philips 42PFP5332D 42 in. Plasma...
Philips  42 in. Plasma TV Logo
361 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
