Question about Ovens
My oven stopped working after an electrical blackout and now the light showing the time is flickering and the oven doesnt response
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described the issue can be either with the clock and/or its control panel which has gone bad and needs to be replaced. When you press the touch pad and no buttons respond however, you are sure that the power is getting to the oven then it is the control panel that has gone bad and should be replaced. Please do accept the solution if the issue is resolved or post a comment with the manufacturers name and model no# for further assistance.
Thanks
Rylee
Posted on May 26, 2010
My bush oven and grill stopped working could it be the selector switch the fan works and if you slightly turn the know you can see a little flicker of light so I don't think its the elements
Sounds like you have answered your own question there. Best to get someone with electrical training to check it out though. It would be unusual for both elements to fail at the same time. Have all the details of the machine to hand when you go for parts though, there are so many models.
Jan 05, 2015 | Ovens
Model SA392EB
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Feb 15, 2013 | Smeg Ovens
Smeg oven UK80MFX1 troubleshooting
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Nov 30, 2011 | Smeg Ovens
Oven displays "Supply Open Neutral" What does
I got this problem on my GE Trivection oven after a 2 minute blackout. "Supply Open Neutral" showed up and no other buttons worked. I shut off the breaker to the oven from outside and it still didn't work. I then turned the breaker off of the other appliances in the kitchen and turned the Trivection oven breaker on first and then it worked. I don't know if it was the order or whether I just turned it off for a longer period of time, but the oven started working normal again.
Nov 29, 2010 | GE Monogram® ZET3038 Dual Single Oven
After a power blackout in our neighborhood the oven display showed a blinking clock time-still keeps time- which could not be reset. The soft panel does not respond to any setting to turn on the oven in...
Try turning the breaker to that unit off and keep it off for 20 minutes or overnight, if possible, then flip the breaker back on. If it still shows the PF code, call us and we can get the correct part to you. Hope this helps.
Aug 28, 2009 | GE JTP20 Electric Single Oven
Neff B1432 Oven Not Heating; oven light flickering
If the fan is working o/k then you need a new element fitting.
Remove the panel at the rear of the oven, there you will see the element, remove the fixing screws and ease the element forward,taking care not to lose the wires, disconnect the leads and fit new element.
The light flickering is probably the bulb not screwed in propely or a bad contact, nothing to worry about.
Plz rate my solution.
Thanks
Dec 19, 2008 | Neff B1432 Single circotherm plus Electric...
Built in Convection Microwave Oven KBHS109SSS
no reset buton persay but fuses and control boards. MICROWAVES emit and store HIGH VOLTAGE nad should only be access and repaired by trained proffessionals. NO JOKE HIGH VOLTAGE. like your DEAD VOLTAGE
Nov 20, 2008 | KitchenAid Architect Series KEMC308KSS...
Display on top electric oven
The oven is locked by childproof lock.
Rotate anticlockwise the function selector 3 times from the 0 position to the light bulb.
Oven light –5– goes out.
Jul 08, 2008 | Neff U1721 Double circotherm Electric Oven
Oven light flickers on and off rapidly
I have seen several problems with the touch pad (membrane switch assembly) causing weird problems with the lights. also something to check is the door hinges. I have seeen several cases where the door hinges wear out and the door does not close completely and doesnt quite push the door switch in. The easiest way to check this possibility is to push in on the door while the light is acting up and see if it quits. If it doesn't, the problem most likely lies in the mebrane switch (touch pad). Good Luck!
Oct 06, 2006 | Dacor ECS127 Epicure Stainless Steel...
Ovens Logo
24 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
