Question about MyMusix PD-6070 MP3 Player
Need drivers for XP. Just stopped working and now
Need drivers for XP. Just stopped working and now show esclamation point for drive.
  • 185 Answers
Yo can go here there you can get drivers for Win 98-Vista also get the also get the mtp file as it seems like non-detection is a common problem on this devices.
if it works for you, don't forget to rate me
thx
Posted on May 26, 2010
Testimonial: "Very helpful. I was actually in the process of connecting to this site when I received the email. There seems to be a problem with the site right now though. Thanks."
How do I install audio output device ie. speakers and head phone jack? I accidentally disabled both of them.
These are usually covered by the Plug&Play drivers and shouldn't need any installation. If you disabled the Audio Output, then
either uninstall your soundcard driver (Realtek), restart the pc and install it again.
If you disabled something, it might also show in the Device Manager (START-->RUN-->devmgmt.msc). If ther is anything with a yellow esclamation mark ( ! ), then try update the driver. If updating the driver doesn't work, then remove the hardware (NOT physically).
Sep 04, 2013 | Lenovo ThinkPad SL500 Notebook
Tip
How to install your monitor drivers in Windows 7 1. You will need to access your...
1. You will need to access your computers display settings. This link will show you how to access the display settings
http://www.fixya.com/support/r4290529-change_windows_7_display_settings
2. Click on "Advance Settings"
3. Click on the "Monitor" tab
Note here is where you will is if you have a generic drive installed or not. If it shows Generic or Plug & Play Monitor then you may not have the actual monitor drivers install.
4. Click on the "Properties" button and click on the "Driver" tab
5. Next you will want to click on Update Drive
At this point you will want to select "Browse my computer for the driver software". The reason you want to do this is because if you select "Search automatically for the updated driver software" you will most likely get the default Windows drivers that are already installed.
6. Next you will browse to the driver CD or the place you have the drivers saved on your computer. Note if you just upgraded from Windows XP your old drivers may not work and you will need to find Windows 7 versions of the drivers. However if you have a Windows Vista version of the driver this may work.
After you get the location set click Next
7. At this point you should get a message that states that the drives have been installed.
8. Click Close - Close - OK - OK and you should be back at screen resolution.
Other Helpful Links
How to change your Windows XP display settings
How to check and change you computer IP address in Windows 7
How to enable and disable printer and file sharing in Windows 7
How to take file ownership in Windows 7 and Windows Vista
How to change your drive letter in Windows Vista and Windows 7
on Mar 08, 2010 | Computers & Internet
I did new window xp in my computer and the drive is not working. i think the software is gone
If the drive shows up in Windows Explorer (My Computer) then it is being recognised by Windows XP. Put a CD or DVD in to see if works and you can see the files. If you want to burn DVDs then you need additional software to do this.
Mar 02, 2011 | NEC ND-2510A DVD±RW Dual Layer Burner
I had a compaq pesario cq40-421TU laptop .when i boot it with a windows xp cd the set up stop at the point of ''SATRTING WINDOWS'' and shows a blue screen and says some information like a number and the...
The stop error code is most likely STOP:0x0000007B because windows XP doesn't have the correct SATA controller driver to install without assistance.
Options:
If available, try setting the SATA controller in BIOS to ATA or Legacy Mode.
If not available, then you will need to download the SATA controller Driver and slipstream the driver into the XP version you are trying to install
http://www.fixya.com/support/r4439741-integrate_slipstream_sata_drivers_into
Jun 19, 2010 | HP Compaq Presario CQ50-110US Laptop
I want to reinstall my Y computer but the restore CD does not seem to work. So i tried a new XP cd, but that too could not work as it does not see the SATA hard disk installed. The Bios on the Tecra M9...
Hi, your Windows XP install CD doesn't have SATA drivers for the hard drive included, so it's not able to address your hard drive. You can't disable SATA in the BIOS to make it work since your hard drive is still SATA. You'll need to get a 3.5" floppy disk and drive if your laptop doesn't have one. They make external 3.5" USB floppy drives that will work.
1. download the SATA drivers for your laptop (iastor.sys and inf)
2. copy the drivers to your floppy disk (about 6-7 files)
3. plug the floppy drive into your laptop
4. boot to the Windows XP CD
5. as soon as the installation starts, it asks you to "Press F6 to specify RAID or controller drivers" - Press F6 now
6. When setup asks for it, point it to the floppy drive
7. Installation will continue and find your SATA hard drive
Ta-da! Rock on with your bad self.
May 18, 2009 | Toshiba Tecra M9-S5517X PC Notebook
Responding error of mouse or USB while using it?
This seems like a conflict in the drivers. Check the device manager for conflicts like a yellow esclamation mark. YOu can get to it by going to start /control panel /system icon / device manager
Mar 03, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Dell Latitude D620 Full System Recovery?
It's easy to miss the point at which you hit Ctrl + F11. You need to hit Ctrl + F11 at the point you see the blue bar across the top of the screen, it will display www.dell.com. If this is still not working you can use the XP operating system CD to reinstall XP and the Dell drivers CD to reinstall the sound, video, network and other drivers. If Dell didn't send you the operating system CD, you should contact them.
Jan 14, 2009 | Dell Latitude D620 Notebook
Card readers have stopped working on my HP pavilion desktop
There are 3 possible problems from my point of view.
1) The cardreader is not working so you need to change it.
2) The inside connections are not working proprietly or unplugged.
3) The operatin sistem has problems with this cardreader
Dec 26, 2008 | Computers & Internet
My dvd rw is not detected
Sounds like you need your manufacturer's SATA drivers.
This problem exists a lot when installing Windows from scratch on SATA hard disks. When you start the installation, Windows prompts you to "load additional drivers". It's at this point you put a floppy disk with the SATA drivers in.
If your install is already working, but just stopped as you say... then you could hunt around the BIOS for a SATA "compatibility" mode, which will get you booting straight away. Install the SATA drivers and you can then put the drive back into normal operation instead of compatibility mode.
This is also the reason why your other hard disk with Windows can see the SATA disk and optical drive... it probably has the SATA drivers installed.
Aug 20, 2008 | Microsoft Windows XP Professional With...
Sound card not detected
The yello esclamation mark signifys you need up dated drivers then it will go again.
Sep 14, 2007 | Ensoniq (6000708) Sound Card
MyMusix PD-6070 MP3 Player Logo
512 people viewed this question
Top MyMusix Audio Players & Recorders Experts
Greg Cann
Greg Cann
michael galang
Sandeep Shenoy
Are you a MyMusix Audio Player and Recorder Expert? Answer questions, earn points and help others
