Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Sony 50 inch Vega L C D
A blueish cloud started appearing around the border and slowly closed in to the center, leaving a black spot about 10 inches in diameter.
  • 2 more comments
  • foldeupfast Apr 22, 2008
    i have a 60in wega i have the same problem , the blue shadow has moved around the whole outside of the screen and now working its way to the middle .help
  • Anonymous Oct 04, 2008
    I have the same problem! I thought it was the bulb- changed it, the problem is still there.
    Some please help!
  • terryh01 Oct 14, 2008
    Right now I have a blue line appearing @ the bottom of the screen, and a small blue dot in the very center.
  • toflam Nov 02, 2008
    I to have the blue shadow forming at the top of the screen and a bigger light blue circle in the middle of the screen. One person said they replaced the lamp and it did not fix the problem, has anybody figured out what this is and what to do? I was going to buy a lamp but I guess I will wait to see more postings.
welcomejee
  • 10594 Answers
SOURCE: blue cloud
That's OK, I been provided you technical info about TV problem.
Posted on Feb 03, 2009
  • 1779 Answers
SOURCE: Sony 60" LCD projection TV has yellow screen discoloration
It sounds like you have a bad Blue Polarizer in the light path. I'm sorry but that is something you will have to contact a service center for. It's not something you'll be able to do yourself, I'm sorry, but that's the best advice I can give you.
Posted on Feb 17, 2009
  • 80 Answers
SOURCE: Sony Wega - Pink Spots On Screen
You have a defective optical block. Contact Sony support and have your model and serial numbers handy. Sometimes they will warratny these even after the 1yr warranty has expired.
Posted on May 21, 2009
  • 197 Answers
SOURCE: i have 50 inch sony tv, red light flashes and it has not picture
bad lamp
Posted on Jun 09, 2009
  • 668 Answers
SOURCE: Blue cloud on the bottom center of the screen Sony xbr 70
If this is a KDSR50XBR1 or a KDSR60XBR1,
It is a bad Optical Block and you need to call Sony at 1-800-222-SONY asap to get a exstended warrenty repair. If it is not, and it is out of warrenty I would still call to see what they will do. In either case, it is a Optical Block causing the problem.
Hope this Helps,
Skyassoc
Posted on Jun 29, 2009
Hi guys, I have got a spot on my Sony 40" LCD TV which i got when one of my cat urinated on the TV. its about 4 inch in diameter and is on the bottom right corner of the screen. Now my quest
moisture and electrics dont agree with one another. Could try
isolating from the mains and spraying lightly with car windscreen
de-icer (isopropanol) wipe off any excess and leave in a warm spot for
a few days....Might work if you are lucky
Oct 27, 2014 | Sony "BRAVIA EX 400 Series 40-Inch LCD TV,...
Model Le46M51B samsung flat screen TV clouding
sounds like your screen is separating. If you tv is less than $1,000 prob not worth fixing
Nov 15, 2013 | Samsung LE46M51B 46 in. LCD Television
I have a plasma lg 50 inch. Model 50px5d. The picture is extremely dim. Little black spots appear then fade away I am wondering what the cause would be and if it's able to be fixed pretty cheap. I...
If the picture looks like a dim swirling cloud etc it is likely the display panel (front screen unit) which is sealed and has an inert gas inside has ruptured.
It is the end of the set if this as I suspect is the case--Panel for a 1,000 dollar set will cost over 1200 dollars if even available.
May 26, 2012 | LG Televison & Video
Black box in center of TV
Sounds like close caption is on. Go into menu and turn it off.
Jan 04, 2010 | Vizio Televison & Video
TV SCREEN
Can you post the model number and also does it appear to be a blueish color that you are seeing? A picture would be great if you can?
Nov 17, 2009 | Televison & Video
Black box showing up in center of tv
your closed caption feature is turn on and in the text mode. either turn off the closed captions or change it from text to cc1
Jan 08, 2009 | Toshiba 32A33 32" TV
Black lines on sony plasma tv
go here, it will work.  follow closely and read entirely!  it worked for me on a gateway plasma!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
Oct 27, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Green Cloud show close to mid lower left center on most black screen
you will need the optical unit cleaned, if that does not resolve then the optic unit needs replacing
Jun 18, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
Hitachi ultravision 50 inch lcd 50v500a
A BIG RED SPOT APPEARS ON THE SCREEN WHEN U TURN IT ON WHEN IT IS STILL BLACK. THEN ARED HAZE IS VISABLE IN ABOUT I 6 INCH AREA WHEN VIEWING THE TV.
Nov 25, 2007 | Televison & Video
Black screen keeps popping up
If a black box appears on the screen, and a small amount of the picture is visible around the border, it means that your closed captions are on and set to TEXT. Go back into the menu, navigate to the closed captions page and set the captions to OFF.
Sep 02, 2007 | Toshiba 50A50 50" Rear Projection...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
47 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
