Question about Maytag MZD2766GES Side by Side Refrigerator
Maytag MSD2354FR Side by side dispenser won't work
Yesterday we had a power outage and when it came back on nothing will work on the front of the fridge.  The light won't work, the indicator lights won't work and the dispenser doesn't work either.  I''m not sure if the ice maker works or not.  The freezer still works fine and the fridge works fine.  I tried unplugging it for a couple of minutes to maybe reset it but that didn't help.  Ideas?
    Genius:
  • 1,073 Answers
Freezer display board took the hit
Posted on Apr 10, 2008
Cube is dispensing crushed ice instead
Check selection on door front. Also you can try to unplug and let it reset for a couple of minutes then plug back in
Sep 02, 2014 | Maytag Refrigerators
Dispenser stopped working
Hello...yes there is a kit you can buy that has the solenoid, and other parts ...door flapper....you have to pull the front off the freezer section where you change from water to ice.....
Nov 11, 2013 | Maytag MSD2756G Side by Side Refrigerator
GE Refrigerator Ice and Water dispenser stopped working after power outage
More than likely the user interface board that controls that portion of the machine is probably bad, or, worse case scenario the main control board which has the overall say so for the machine has gone out which isn't uncommon either. My best advice is if your going to do it yourself buy your parts from www.repairclinic.com because of their return policy which you can return any part you bought even if installed/
May 19, 2012 | GE GSH25SGRSS Stainless Steel Side by Side...
The ice maker makes ice and dispense water, but won't dispense ice. Cleaned out ice tray, not ice blocking any discharge area. When you try you can hear the ice dispenser door open, but the motor to...
i have the same fridge... same problem, except not only does it not dispense ice, it also dosent dispense the water too. i recently had a power outage, and when the fridge was turned back on the digital warmer and colder setting have been flashing 0 non stop making it unable to set temps... any suggestions?
Aug 22, 2011 | General Electric GSH25JSXSS Stainless...
My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Jun 10, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Samsung side by side water dispenser not working since power out
Does the solenoid click on the back? This would be better as a chat as there are several things to check. If you find this helpful, please rate as such or email me
Jan 10, 2009 | Refrigerators
Psd262lhez performa side by side
I got one of these in my shop. I am tech, call me for info. steve 320.963.3580 MN
Sep 28, 2008 | Maytag MZD2766GES Side by Side...
Dispenser Panel is not working
coundnt bring up anything on the model # Try Takeing cap hedge off freezer side unplug door power plug for 20 minutes see if that will reset dispence board .... works on ge... havnt tryed it with a maytag
Sep 07, 2007 | Maytag MSD2756G Side by Side Refrigerator
Problem after power outage
yes it is but is a solder one and has to be open by a skill person to check for shorts most times the spike protector is short..good luck
Jul 27, 2006 | Maytag MSD2754G Side by Side Refrigerator
Maytag MZD2766GES Side by Side Refrigerator Logo
293 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
