Question about Maytag SDG3606A Gas Dryer
Flame wont stay on
Flame comes on from igniter and then goes out. I've already change both coils
  • Maytag Master
  • 43,501 Answers
Hi, If you have a gas dryerflame wont stay on - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryflame wont stay on - 2_bing.gif="http://i.fixya.net/uploads/images/2_bing.gif" alt="2_bing.gif" class="h_mi" /> is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gifDryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 27, 2010
Why wont my oven stay lit
is the flame sensor positioned in the flame where it changes to bright blue near the flame tip
Aug 21, 2014 | American Range Ovens
Gas dryer does not heat igniter glows red gas valve clicks but no flame
Since the igniter glows i am wondering if within 1 minutes does it go off??or does the igniter just stay on??
If the igniter just stays on and doesnt go off the problem is going to the FLAME SENSOR
if the igniter goes off but no flame the problem will be the GAS VALVE COILS
GENE
Oct 12, 2011 | Dryers
Ignitor is lighting but silinoid is not opening to let gas through.Roper model # RGS7646KQ3
Your have one of two problem causing the gas to not come on on your dryer.
1) the flame sensor is bad...if the igniter comes on and stays on and doesn't go off...usually within 1 minute the flame sensor isn't working as its supposed to
2) the coils on the gas valve could be the problem...if the igniter does indeed go off within 1 minutes and as soon as the igniter goes off if their is no flame the coils on the gas valve is what would need to be replaced
here is what each part looks like
I hope i have been able to help you fix your dryer,
GENE
Sep 17, 2011 | Dryers
Igniter comes on will not let the gas in. The gas burner does not come on Maytag model dg882s
FLAME SENSOR
Sep 14, 2011 | Maytag Dryers
Everything works but the gas dont kick on when the pilet comes on what can i do
Hello Anthony,
Thier is one of two things causing the dryer to not heat depending on what you see happening will determine what the exact problem is;
The gas valve coils are bad...if the igniter comes on and goes off but no flame the coils on the gas valve will be whats bad
The flame sensor is whats wrong... if the igniter comes on AND STAYS ON and does not go off (usually within 1 minute) the flame sensor is going to be what the problem is
GENE
Sep 10, 2011 | Maytag Dryers
HI I HAVE A MAYTAG DRYER AND I HAVE CHANGED THE COILS AND THE THERMALFUSE AND STILL THE IGNITOR IS GLOWING BUT STILL NO FLAME ALSO BEFORE I CHANGED THE THERMAL FUSE I HAD A FLAME BUT NO HEAT IN THE DRUM...
Is the igniter coming on,staying on for 30-45 seconds then goes off? or does it not go off at all?
i am going to assume that it does not go off.the problem when it never goes off followed by a flame is because the flame switch/also called the radient sensor is bad.
If that is what your experiencing replacing the flame switch will fix that dryer. The part# for that is 338906
Gene...OldTech2332
Aug 23, 2011 | Maytag MDG3500BWQ Dryer
My gas dryer will not get warm
Can you hear the flame come on at all? If you can hear the flame come on in the beginning but then as time goes on it doesn't, you need to replace both coils (solenoids) on the gas valve.
Take the front panel off and watch the operation of the dryer. You should see the glow from the ignitor come on and get very hot, then hear the click of the coil releasing the gas, which will allow the flame to ignite. If you see the flame come on, stay there and keep an eye on the time.
After about 5 minutes if the coils click but the flame doesn't come on, you've just proved you need the coils.
If you have a meter you can check for continuity or ohm out the ignitor to see if that is your culprit. A less likely repair would be to replace the flame sensor.
Feb 19, 2011 | Kenmore Dryers
Kitchen aid dryer / heat flame not staying on after 20 secs
Sounds like your gas valve is fine, if it comes on at all, its good. A air flow restriction would cause a overheat condition and shut down the burner. Once it cools back down the burner would re-ignite and repeat the cycle. The sensor on the left of the burner is the flame sensor and the flame wouldn't come on at all if it was bad. You've already changed the coil kit so the valve is fine, disconnect the vent from the back of the dryer and see if the problem goes away. If the problem stays, I would suspect the thermostat. Good luck.
Mar 16, 2010 | KitchenAid Dryers
My gas dryer starts fine than the flame goes out
replace the coils. i promise you. and here is a guide to most gas dryer problems that even a kid can see.
starts fine, cycles off, igniter comes on, hear a click, and no flame.-coils.
(can also be intermintent)
igniter stays on, no flame.-flame sensor
no glow from igniter.-igniter
remember, always allow about one minute for ignition.
Oct 06, 2009 | Frigidaire GLGR331A Gas Dryer
Pilot wont stay lit
Check the thermocouple,Its is a flame senser.It will not stay lit if it is bad.
Oct 04, 2009 | Water Heaters
Maytag SDG3606A Gas Dryer Logo
91 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
