Question about Mitsubishi VS-50707 50" Rear Projection Television
Power Off Hello Whenever I turn on my tv the green power light shows but usually within 15 seconds it powers off. Very rarely I get a picture for a few seconds but the power still turns off within that time. I am trying to find out the error code I get from the menu input buttons being held It appears after I let go of the buttons the green lights blinks in increments of 2 10 times I cannot find anything that says this is error 2 or error 20 etc. What can I do next? Thanks
  • bigdog08 Aug 12, 2008
    mit vs-50607 tv cuts off by it self had it repair and the same thing happen again what can i do.
My tv looks 3D it shows double of everything and the double is red....can my tv be fixed?
Posted on May 06, 2008
    President:
  • 4,402 Answers
Mitsubishi > VS XXXX
this model is famous for fluid leaks. each projector True True (``````````` (``````````` 0 95250 95250 Power Off - clip_image002.png tube has a reservoir on the front of it with a fluid in it. this keeps the face of the tube cool.
this depends on how bad the damage is in the tv. in most cases we can reseal the tube and clean up the fluid 400-600.
Once you
take the tube out you will see where it leaked. The problem is that the
frame on the CRT that the heavy screws with springs are mounted on (that
hold the lens coupled to the CRT) is weak and they can bend. We have seen
several that have leaked after the customer moved the set. You can only
tighten them down so much because the frame bends. It is just stamped metal
and not welded at the corners to support the bend.
We remove the CRT, clean it all up, add a very small amount of RTV sealer to
the gasket, reassemble, let the RTV cure thoroughly and refill with coolant.
The extra sealer should prevent future leaks. Haven't had a recall yet.
Mits says replace the CRT...too costly.
You msut check the yokes carefully as well. If any coolant gets into them
you can end up with shorts there and a mess.
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Posted on Apr 08, 2008
SOURCE:
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
II get sound for about 15 sec. but no picture and then shuts off
kp57ws50_57_in_rear_projection_hd_228277.jpg Problem with Sony KP-57WS520 57 in. Rear Projection
This model is really prone to one problem in particular--screen even briefly comes up bright red, green or blue and set shuts down.
15 seconds from turn on front power light should blink as set checks several things internally---if something wrong it does not let picture show.
Usually after shut down or failure power light will blink a sequence of blinks but not always depending on problem.
Did you see the screen at all go red, green, or blue before?
the more you tell me the better I can help
Mar 28, 2012 | Sony KP-57WS520 57" Rear Projection...
I am currently working on a Sharp Lc37sb24u. I was originally thinking it had a bad inverter board but now I am not so sure. When I turn the tv on the picture comes up with audio for about 2 seconds the...
Did you check the service manual troubleshooting guide yet. You can try disconnecting the power to the inverter board and see if it will stay on and have sound.
Service manuals:
http://elektrotanya.com/?q=showresult&what=Sharp%20LC37SB24U&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 27, 2011 | Sharp LC37SB24U 37 in. LCD TV
The TV turns on and shows a picture that you can watch and within 10 minutes the TV loses its picture, however, the light is still green. If you turn the TV off you can get the picture to come back after...
The issue here could be a capacitor within the power circuit. Also could be a power transistor that is faulty. On the easy part it could be a matter of reprogramming the unit but I doubt it.
Dec 18, 2017 | Hitachi 42HDT52 42 in. Plasma HDTV
Just got a 46hm95 toshiba for free cause the screen wont show anything. i can hear the fan come on. i am very mechanicly and electricaly inclined and have all things needed to test equipment short of an...
hello When the TV has been powered on long enough for the lamp unit to get hot, it may take several minutes for
the picture to appear on-screen. See "IMPORTANT NOTICE ABOUT HOT LAMP R
When the TV has been powered on long enough for the lamp unit to get hot, it may take several minutes for the picture to appear on-screen
in the following situations:
• When the Quick Restart™ feature is set to OFF and you turn the TV off and then on again within a few minutes.
• If the TV is on when a short-term power failure, power surge, or other similar power failure occurs, such that the TV loses and regains
power within a few minutes.
This is a property of DLP TV lamp technology and is NOT a sign of malfunction.
If this occurs, the green LED on the TV front panel will blink (and the red LED will be lit solid) until the TV is finished restarting the lamp
and the normal picture appears. If BOTH green and red LEDs are blinking at a one-second rate, you will need to turn the TV off and then
on again to restart the lamp.
ESTART" on page 8. if this no good check the lamp in side to see if it's not burn't out good luck
regards
shaun
Jun 01, 2010 | Toshiba 46HM95 46" HDTV
It is charged but I can't figure out what to do next. Instructions were thrown out. It doesn't turn on for more than a second.
plug into usb. Let charge for 2 hours.
Press power button for two seconds to turn on/off
Press button that looks like clock face to cycle between 1 5 15 minutes (small lcd will show)
Then pre power button once.
Green light shows is on, LCD shows how
many pictures taken.
Once you have taken pictures you have 15 hours to plug it into a pc and download them,
shows up like a memory stick. After 15 hours it loses memory and pictures.
If device is non-funtional, press recessed reset button in back. Then charge as above
- Ron S
Jul 12, 2009 | Uncle Milton Pet Eye View Camera
Have a Sanyo Plasma TV DP50747 and both picture and sound all of a suden went. I turned it on from the remote and the green power light goes on, but no picture or sound and the power light goes off again...
Yep. The power supply in Sanyo Plasmas are generally prone to failures. It could be a failure in the panel not priming, but I doubt it. Turn the lights off in the room, then try to turn it on. If you see the screen faintly flash, the panel is priming, but it is not coming on. If the screen is lit, but is still "black," then it is a control or digital board. If it is totally black with no light at all, then it doesn't entirely rule out the first two, but makes a power supply failure more likely.
They usually have a lot of heat damage to them. If you have tried unplugging it for 15 minutes, then plugging it back in and it still doesn't work, the it is most likely a secondary in the power supply.
I hope this helps you...
Jan 10, 2009 | Sanyo PDP-42H2A 42 in. Plasma Television
Tv wont power up makes a noise but no picture
Your power transformer is likely shot. It'll cost at least $200 to have it replaced. Someone can come to your house to diagnose it. Usually costs around $65.
Nov 03, 2007 | JVC AV-56WP74 56" Rear Projection...
Mitsubishi VS-50707 50" Rear Projection Television Logo
178 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
