Question about Kenwood KDC-319 CD Player
Memory erases everytime the ignition is turned
I have a 1980 malibu I pulled the original tape cassett out and installed a kenwood cd player I cut the old harness out and did it wire to wire but my only problem is the memory wont stay set can any one help me out with this problem
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
Sounds like you don't have power to the head unit constently. You can run the yellow wire to a main power supply like your battery or the fuse box the radio or clock. Or you can twist the red and yellow together to a main power supply, but when you turn the key off it will still stay on. Have to always turn it off manually Hope this was helpful
Posted on May 26, 2010
    President:
  • 676 Answers
Be sure that the yellow wire from the cd player is connected to a +12 volt source. ONe god source is the orange wire from the cigarette lighter if the cigarette lighter is working fine. If not run a wire from the yellow wire of the cd player to the fuse block in one of the pins marked "bat". Good luck. Please rate.
On a kenwood KR597 reciever, where do i hook up my KE597 graphics equalizer. Also must i remove my DP-R797 cd player to hook up my Maeantz PMD520 Cassette deck? Finally divorced
If you only have one set of tape in/out connectors, then hooking up two tape decks and an equalizer is going to be difficult. You could hook the "tape out" to one tape deck, that tape's output to the second tape, and the second tape's out to the equalizer, connecting the output of the eq back to your receiver....
Nov 01, 2014 | Audio Players & Recorders
Kenwood KDC-319 CD Player Logo Problem with KDC-319 CD Player installed a kenwood kdc 319 in a 04 chevy malibu when i have car off i turn deck on an my cars dash board lights turn on Posted by A
I would start by disconnecting the radio and hooking it up right,the power should go through the ignition switch.So that when you turn the car off the radio will go off and to hear it on again you have to turn the key to accessory or start it.That might take care of a few of your problems.
Jun 25, 2012 | Kenwood KDC-319 CD Player
I have a 1985 chevy monte carlo and I have ran a wire from my fuse box for a constant n my cd player will not keep memory and my memory is fine on the cd player.iv had several cd players in this car and...
You must have tied into an Accessory fuse and not a constant. Typically Cd player/radios etc will need both an Accessory tap as well as a constant tap.
Test the voltage on the wire and if it's constant you will have 12VDC without the key in the ignition You will also need a tap where there is 12VDC ONLY when the key is in ACC mode (or ignition on)
I do not have specific details on your CD Player but consult the manual on adding both of these connections,
I hope this helps
Magoo
Mar 11, 2011 | Kenwood KDC-X794 Car CD / USB/ MP3 Player
Copy audio tapes to CD's
Hello Trevor,
Easiest way I can think of is as follows:
1. Connect the "phones" of your cassette player to the "Line in" of your PC. Line In is coloured blue, you will need a a 3.5" to 3.5" male audio cable.
2. Next, install some sound capturing program on your computer. I can recommend Audacity: http://audacity.sourceforge.net/
3. Start the cassette player, check the volume levels, do some short test records. Once you are satisfied with the result, rewind and record side A of the cassette, then side B. Using again Audacity, you can cut the desired parts of the record and save them in the format and quality you like, I guess *.mp3.
4. Burn the files to a CD. You can use CD Burner XP Pro: http://cdburnerxp.se/
I hope that I have been very helpful. :)
Nov 13, 2009 | Audio Players & Recorders
Reorded tapes only play out one speaker
check your cables to the units channel that doesn't work, for breaks. Does the cassette player play back a pre-recorded tape okay? if it doesn't there might be a internal fault.
Check the wires to the tape head to see if one is off.
Jun 06, 2009 | Kenwood CT-201 Cassette Player Single Dual...
Installing kenwood cd player in EF ford falcon
this is not a sales pitch but i purchased the correct patch harnass from pmr, it should be available at any good sterio store for about $10
Mar 17, 2009 | Kenwood KDC-MP4028 CD Player
Ipod to Kenwood 208 S
Get a cassette to ipod hook up. They are just black cassette tapes with a cord coming out that plugs into your ipods earphone jack. They're usually around $20.00
Jan 16, 2009 | Kenwood KRC-208s Cassette Player
Kenwood KA-72B Stereo Receiver HELP NEEDED.
Why not plug the cassette directly into the CD recorder? Are they trying to achieve some eqalization change? If not, then this should work. It's all analog at tape level.
Mar 02, 2008 | Audio Players & Recorders
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
