Question about Samsung Cell Phones
How do I activate the speed dial and turn off the key pad volume/tone when entering information/numbers? Samsung S6703T mobile phone
  • 297 Answers
Go in to menu, reading your manual might brighten you up on this phone
Posted on May 26, 2010
I'm having problems with a Samsung KPDCS-12B LCD phone I've recently been given, I need to add myself to group 501 to take calls for my department (Plumbing) but my phone (Extension 250) is...
Hi you need to do this in 2 parts - firstly to add yourself to group 501 follow the step-by-step instructions which are on the video I have posted. Then follow this to add a mobile number to the directory;
Press the TSFR key
Enter 200
Enter code 1234
=/- key to enable
Speaker key
dial 705
I.e. once in 705
Type in speed number, the cursor will tab over to speed dial slot.
Enter 9 followed by the phone number.
Press 12th button down,
Enter name,
Press 12th button. (You will be back at the speed dial.)
Press tab, then enter the next speed dial slot you wish to program.
NB-
( 705 - Speed dial 12th Button down to toggle between)
( 706 - Speed Name the 2 MMC
Jun 08, 2011 | Samsung DCS 12 Corded Phone
Tip
HIDDEN NOKIA DETECTIVE TRICK
THE DETECTIVE TRICK (Mobile Spying)
Now you can spy on anyone using your cellphone. Just do the following.
1. Activate the "Automatic Answer" in the headset profile of your cellphone and set the ringing volume to "Mute"
2. Short-circuit the left middle and right pins on the bottom of the MOBILE PHONE with all connections touching each other this will activate profile "Headset". If you cant do this just keep your earphone connected to mobile.
3. Now place it under a table in a room and call it. Now you can useyour phone for checking out what people are talking about in a room.Just call on your phone.
4. The phone receives the call without ringing and you can listen to what people are saying.
SECRET PRANK
Change closed caller group (settings>security settings>user groups) to 00000 and your phone willsound the message tone when you are near a radar speed trap.
Setting it to 500 will cause your phone 2 set off security alarms at shop exits.
Try this secret trick if you can handle the unexpected.
Note: This secret trick wont work with all phones Models
To check Nokia mobile or cellphones IMEI (International Mobile Equipment Identity)
On the main screen type *#06#
Information you get from the IMEI (International Mobile Equipment Identity)
XXXXXX XX XXXXXX X
TAC FAC SNR SP
TAC = Type approval code of your nokia Mobile
FAC = Final assembly code of your cellphone
SNR = Serial number of your nokia Phone
SP = Spare
Other secret tricks for Nokia mobile or cellphone
To check the phones Software revision for Nokia Mobile.
On the main screen type *#0000#
To enter in the secret menu in Nokia Phone.
On the main screen type *#92702689# [*#war0anty#]
It will take you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
To restore Factory Settings for Nokia mobile
*#7780# reset to factory settings.
Taking picture without getting noticed.
Turn on/off the "click" sound made by the camera by selecting the 'Silent' profile or by turning warning tones on/off.
Hiding your Mobile/ Cellphone Number
Go to: Menu > Tools > Settings > Call > Send My Caller ID >
'Yes', 'No' or 'Set By Network' to follow the default settings of your home network.
It works only with very few network who provide you facility of “Private Number”
Speed Dialing From Simcard contact (not stored in mobile phonebook)
Type number followed by # then call.
Example: 1# or 2# or 21#
on Oct 05, 2009 | Samsung SGH-R225m Phone
Why does vtech not have a speed dial? my son is
Programming Speed Dial Numbers
The handset must be OFF.
1. Press PROG. The IN USE LED will blink to indicate that you are in the programming mode.
2. Press the number of the memory location you wish to store the number in (0-9).
3. Using the dial pad, dial the number you want to store. The number can be up to 16 digits long. The number can be entered manually or by using REDIAL.
4. Press MEM to store the phone number
to the key you selected.
The phone now exits PROG mode and emits a tone.
Speed Number Dialing
1. Press PHONE to get a dial tone.
2. Press MEM and the memory location number key (0-9). For example, to dial the number you assigned to key '8', you would press PHONE, MEM, 8
May 27, 2011 | Vtech 9009111 Cordless Phone
Samsung J700i mobile phone instruction book
go to phone pofiles in normal profile select edit then select key pad tone and pop-up alert tone turn both off
Aug 08, 2009 | Samsung Cell Phones
Forgot how to add new phone numbers and names to my phone
Creating Phonebook Entries To store names and numbers in your Phonebook, please follow these steps: When the phone is in standby mode, press [phonebook icon] (on the left side of the four-way key). To create a new phonebook entry, press the NEW soft key. Edit Name appears. Enter the name for this entry (Edit Name). Use the keypad to enter a name for this entry; the name can contain up to 1 6 characters. (See page 1 1 for instructions on entering text.) If you do not want to enter a name for this entry, your phone will store this entry as No Name. Press the OK soft key when you are finished. Enter the number for this entry (Edit Number 1). Once you have stored a name, EDIT NUMBER1 appears next. Use the number keypad, [right] or [left] on the four-way function key, or the DELETE soft key to enter the phone number 1 ; the phone number can contain up to 32 digits. If you need the phone to pause between digits when it’s dialing (for example, to enter an extension or an access code), press [redial/pause] to insert a two-second pause. You will see a P in the display. You can also use more than one pause together if two seconds is not long enough. Each pause counts as one digit. Press the OK soft key when you are finished. EDIT NUMBER 2 appears next. Use the same procedure when entering the phone number 1 to enter the phone number 2. Press the OK soft key when you are finished. Assign a personal ring tone for this entry (Personal Ring). You can attach a personalized ring tone to each phonebook entry; the phone will use this ring tone when this person calls. Move the cursor to highlight one of the 20 different ring tone options. As you highlight each ring tone, you will hear a sample of that tone. When you hear the ring tone you want to use, press the OK soft key. If you do not want to use a personal ring tone for this phonebook entry, select the NO SELECTION option, and the phone will use your standard ring tone setting. Assign this entry to a Speed Dial number (Speed Dial). Your phone has 1 0 speed dial numbers, 0 to 9. Move the cursor to select the speed dial number you want to assign to this phonebook entry, and press the OK soft key. Select NO SELECTION if you do not want to assign this entry to a speed dial number. Press the OK soft key. You will hear a tone confirming that the new phonebook entry has been stored, and DONE! appears in the display. Note: When the shared memory is full, the oldest Caller ID message is overwritten.
Jul 19, 2009 | Uniden 5.8GHz Dual Cordless Phone
Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed.
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
Nov 28, 2008 | Panasonic KX-T7730 Corded Phone
GE28112 Dect phone
Here are the instructions and a link to the manual :
Key Tone
From the Handset Setup Menu:
1. Press the caller ID-volume ( 6 or 5) button to scroll to the KEY TONE sub-menu.
2. Press mute/program button to enter the menu. SET KEY TONE 41ON 2 OFF shows in the display. The default setting is 1ON.
3. Use the touch tone pad on the handset to select 1 or 2, or use the caller ID-volume ( 6 or 5) button to scroll to your selection.
Here is a link to the manual for you :
http://telecom.hellodirect.com/eBiz/pdf/phones/GE_28111_Manual.pdf
Jan 05, 2008 | GE 28111 Cordless Phone
Uniden 900MHz phone model EX17960A
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers in the speed dial memory.
1) When the phone is in standby mode, press the memory key. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number; each number can be up to 20 digits.
7
3) If you need the phone to pause during the dialing sequence, press
the redial/p key to insert a two-second delay between the
numbers. You can enter multiple pauses to increase the delay.
Each pause counts as a digit.
4) Press the memory key again.
5) To store this number as one of the ten speed dial numbers, enter a
digit from 0 to 9. If there is already a number in that speed dial
setting, it will overwrite the previously stored number without
warning. You will hear a confirmation tone indicating that the
number has been stored.
NOTE: When storing numbers into memory, if the handset is idle
(i.e., no key is pressed) for more than 30 seconds, it will beep rapidly, and the phone
will return to standby mode.
Dialing a Stored Number
1) When the phone is in standby mode, press the talk key, and listen for a dial tone.
2) Press the memory key and enter the speed dial entry (0-9) that has the stored number you
want to dial. (If you enter a digit that does not contain a stored number, the handset will
beep rapidly, and the phone will not dial.)
Nov 13, 2007 | Lands Phones
Tone volume on tough tone dialing pad
Instr man is here:
http://www.home-electronics.net/ge/pc/IB/27957GE1_IB.pdf
Jun 25, 2007 | GE 27957GE1 Phone
Cell Phones Logo
121 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
