Question about LG LWHD1500ER Wall/Window Air Conditioner
Do they have internat fuses? i cant start up the unit the control board its not on can i find free service manuals for it
  • 901 Answers
There is a fuse. If fuse is OK, you have to check the small power transformer. DC voltage for the logic board. Contact service center for assistance.
Posted on May 27, 2010
Smh9187 microwave stopped working. The units display works, light inside works, vent fan works, but when you put food in it doesnt make a sound.
On model SMH9187B and SMH9187ST, one likely cause is a defective bottom door switch (primary interlock) or that switch's mount is loose, misaligned, or broken. The service manuals for these models are at my site here:
SMH9187B service manual
SMH9187W service manual 1 ' service manual 2
SMH9187ST service manual
Also see my help file on door switches here.
You can order Samsung parts by part number from the Pros here.
If it's not a door switch issue, it may be a blown high voltage fuse not to be confused with the line fuse) or a relay issue on the board, which I can repair for you.
If you have other questions, feel free to contact me at my site below for more free help.
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 18, 2017 | In Microwave Ovens
Panosonic Microwave convection Model NN-8501V Touchpad appears dead
The unit has a fuse in the power board, but when the fuse is gone it does not even start up. If it starts it is not the fuse.
Look rather a problem with a faulty touchpad, or the magnetron that is not working and need to be changed.
Check also the door sensor.
Oct 03, 2008 | Microwave Ovens
The drum all of a sudden started making making grinding noises, took out several dollars of change and other stuff, now drum will will not turn, belt seems fine, heat fine
Make sure with a manual movement of the hand that the drum is rotating and the motor is free.
now when the drum was struck did it cause any errrors in the motor orr the control board or a fuse tobeblown.
so checkthis out if the drumis free and the motor is not getting supply from the control board.
Check the safetydoor switch to latch for the unit to work, check if any wires were pulled off while you repaired the drain to cleanup.
Sep 30, 2010 | Kenmore Dryers
My GE Advantium model SCA1000HBB01 was cooking on the oven setting and suddenly quit working. As if no power. The circuit is still good. I was advised it was possibly a blown fuse inside the MV on the...
When you take the top off and stare into the unit you will see a white fuse in a black plastic fuse holder. Look carefully. I had to replace the melted fuse holder as well. Radio shack has the fuses and holders.
Sep 14, 2010 | GE Advantium 120 Convection/Microwave Oven
Affinity washer displays ERR. PAU and 43
HI. This is a strong indication of Main control board failure. Essentially, the board is having problems communicating with the other corresponding units in the washer. The necessary actions will be to replace the Main Electronic control board. The part number for your new control will be 137007000. I have also included a service manual for this unit, which will guide you through the replacement procedure. Click here to access the service manual.
The removal process for the electronic control assembly will be located on page 74 of the manual provided. Start on page 73, under "RELEASING THE CONSOLE" and work your way through page 74. Those instructions will help with the removal process of the control board.
Aug 10, 2010 | Frigidaire Affinity ATF7000E Front Load...
Internat
you must go to the internet options and reset to default....somewhere you or an installation has changed settings disallowing a service that you need to run smoothly!! :D GOod Luck and pls rate this post!!!!
Oct 09, 2009 | Computers & Internet
GE Advantiumk 120 - Complete Blackout Model Number: SCA 1001 HSS 01 Brand: GE Age: 1 - 5 years Thanks a lot for your expertise. It's a total blackout mid cook cycle. The house breaker and...
the fuse is located on the control panel which is at the back of the base.and control panel, is located at the top.the fuse is not on the control panel its located on the control board.you will just have to remove the oven.this is the only procedure.but once the unit is removed then its not to tough.the sides are just fitted by screws.as replacing the fuse from control board also called main board is very simple.you just need to pull the fuse out by a plyer/clipper or with a thin knife.fitting is also easy there is a fuse holder.just keep the fuse on the holder and slowly press the fuse without applying force.it will fit easily.the cost of fuse is near to $3.you can get it from ------ www.radioshack.com ------ if the fuse is ok then its time for new main board. you can get the parts from www.partselect.com ------------------- this will help.please do rate the solution.thank you for using fixya.keep updated.
Oct 02, 2009 | GE Advantium SCA1001HSS Convection...
No power to control board
You replaced the control board?
Assuming the fuse & holder are good, then check the cavity thermal cutout and magnetron's temperature fuse.
If those and wiring are okay, the board's low voltage transformer should be getting power.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.)
We have the service / repair manuals for these models and have uploaded them to our site here and here for free download to help you.
They will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Let em know if I can help further, otherwise...
Jul 18, 2009 | Sharp Microwave Ovens
Electrolux washing machine EW1055F stopped working
It appears your controller/timer board has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 01, 2009 | Washing Machines
Error code on kyocera fs-3800 printer
E1: xxxxxxxx = Main motor error
Either the motor aint turning or it is being stopped from turning...Usally drum or developer units cant turn, or main motor or control board stuffed...
below is stuff from service manual and ....my comments
Suggested causes
The main motor is overloaded. Overcurrent in the main motor circuitry due to an excessive torque....... Check Drum, developer unit, toner cartridge and process units ensuring free movement
• Connector insertion error........check developer plug is secure (left top near toner cart little plug)
• Defective gate array U204 on the engine
board (KP-864). .......replace board
• Defective harness between engine board and
engine relay board (KP-760). .........secure replace cable
• Defective harness between engine relay board
(KP-760) and main motor.
Nov 26, 2007 | Kyocera Mita FS 3800 Laser Printer
LG LWHD1500ER Wall/Window Air Conditioner Logo
120 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
