Question about HP PSC 1315 All-In-One InkJet Printer
First time , my printer is autometic inserting papar then half its stop
I power on printer. then paper is autometic inserting to inside( its not align paper) , then it stop at half of the paper ,, some one can help me~>>??
    Problem Solver:
  • 17 Answers
Clear the paper jam load paper straight before you turn it on because when you turn it on whith out paper in it it automatically starts aligning the paper thats why make sure paper is straight load it in before you turn it on some printers are like that espicaially the new ones
Posted on Apr 14, 2008
Prints an alignment page when switched on every time
For most HP all-in-ones, the alignment page will print until you complete the alignment process. This will be done whenever a new cartridge is inserted (among other times).
In that case:
If the alignment page was printed on plain white letter- (or A4) sized paper, place the alignment page face down on the scanner with the top right corner on the right, front corner of the scanner glass. Press the Start Scan button and wait until the Power light stops blinking.
Other issues that cause the symptom:
A cartridge that isn't properly seated or is damaged/dirty. Remove the cartridges one at a time and inspect them. Check the contacts for dirt and any tape remaining over the nozzles. If they are good, return them to the printer making sure that they click into place. Otherwise, replace them.
The contacts are dirty. Get some distilled or bottled water and cotton swabs or lint free cloths (coffee filters will work). Remove the cartridges and place them on a clean piece of paper with the contacts up. Unplug the printer while you are working (but after the cartridges are at the replacement position). Dip a swab in the water and squeeze out the excess water. Hold the cartidge by the sides. Wipe the copper contacts (do not touch the nozzles). Do this for all of the cartridges. Then wipe the contacts inside the printer with another damp swab.Allow the contacts 10 minutes to dry before reinstalling the cartridges, closing the access door and plugging in the power cord. Turn on the printer and then scan the alignment page.
The cartridges could be bad. Install new ones. Make sure to remove all of the protective tape. Then insert the cartridges (HP new cartridges) into the correct slot and make sure they click into place. Again scan the alignment page when it prints.
If the problem persists, try a power reset. Turn off the printer with the power button. Unplug all of the cords (electrical and data). Relocate the printer to another outlet; preferably the outlet should be on a different circuit. Plug the power cord into the wall outlet. Load the printer with A4 or letter-sized white paper. Now plug the power cord into the printer and turn it on. Do the complete alignment.
If the problem still persists, the unit needs service.
For details and pictures, see: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01336348&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=428800 .
I hope this helps.
Dec 06, 2010 | HP PSC 1510 All-In-One InkJet Printer
Papar jam
Hello sir; Wherever you clean up the paper jam, right over there have a paper senser ,check that senser is moving freely or out of track, just put it back to right possition.
Sep 25, 2009 | Sharp Office Equipment & Supplies
The copy paper when inserted on the feeder tray is okay until I try to print. A page inserts into the printer and abrubtly stops making a stuttering sound and does not process through the printer. The...
Your gears are out of alignment or they are stripped out . Check to see if anything is inside to stop paper and create jam. It is a hardware problem and if you can find it by checking its not worth fixing.Cheap printer and it causes a lot of problems. not worth spending a lot of time on.
Sep 08, 2009 | Lexmark X73 All-In-One InkJet Printer
Paper catch rollers out of alignment
Hi.
Try this
1.take a sheet of paper ,,fold it length wise 2-3 times to make it thick.insert this into the paper feed tray...move it left and right a couple of times..this clears the obstruction if any..
if this does not work..call lexmark tech support,,,your printer would be replaced if in warranty..
good luck
Jan 25, 2009 | Lexmark X5470 All-In-One InkJet Printer
Dell 810 all-in-one printer.
Your drive rollers are losing their grip.
This sometimes works: use pure alcohol, not rubbing achohol which contains water, wet the lower half of a sheet of quality, heavier paper (the cheap stuff may lose too many fibers), place the wet end in the manual feed, do a form-feed (normally rejects a sheet) and intermittently stop it from passing through several times while the printer is trying to transport it.
This may help to remove accumulated paper fibers and air-borne contaminents from the drive rollers.
Otherwise, you will have to do some disassembly to access them for more thorough cleaning.
Aug 27, 2008 | Dell 810 All-In-One InkJet Printer
Printer won't stop printing alignment sheet, following changing of ink cart.
my printer only printed 1 page out of 3 so now it wont stop. it pulls the paper in and comes out blank. this will keep going unless i turn it off. how do i reset my printer?
Aug 20, 2008 | Office Equipment & Supplies
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
41 people viewed this question
Ben Johnson
