Question about Tools & Hardware - Others
Wagner has a 'v'shaped viscosity stick that has time elements associated with it. Does anyone know what these time elements are? DJS
2 Suggested Answers
  • 623 Answers
SOURCE: I want to test paint viscosity and want to know
Usually paint viscosity is tested by a special cup. The paint is put into the cup and how fast it comes out determines viscosity. Here's a good link explaining further.
http://www.finishwiz.com/viscosityandwetmils.htm
Posted on Jun 21, 2010
My Wagner sprayer Is load and won't spray never used it before but it been sitting in box for long time
Try running it with "cleaner" first. In the case of Latex paint, use water. In the case of oil based paint, use Mineral Spirits. Make sure tip is clean (without sticking anything into it). Lastly (or "firstly") read the manual for info on initial setup.
Oct 16, 2015 | Wagner Air Tools & Compressors
Sticking clutch plates
Be sure you are using the correct weight of engine oil. Too heavy a viscosity will cause the problem you mention. In addition, it could be the clutch cable sticking rather than the plates. Have you lubricated that cable lately? Does anyone even do that any more?
Mar 31, 2014 | Laverda 1000 Jota Motorcycles
Will not prime
Most of the time when a unit will not prime it is because of a stuck inlet ball, I would put the intake in water turn the machine on to bleed. Then tap the machine where the paint comes in. 90% of the time this will get it going. Sometime you can stick a screw driver into the inlet ball and free it up. If this doe not work you need to take the machine apart and cleanor you have worn out packing.
Joe
Jan 23, 2014 | Wagner SprayTech Wagner Airless Paint...
I want to test paint viscosity and want to know more about a viscosity stick and how to use it.
Jun 21, 2010 | Air Tools & Compressors
Grill trips my electrics on Stoves 720EF
I had problems with tripping and it was a faulty RCB on the consumer unit. But it wasn't just one appliance causing the problem.
Have you isolated it to the top or bottom oven. If it is the main oven, then it could be anything associated with the operation of that component, i.e. the oven control knob,the oven thermostat, the element, the element fan, the overheat thermostat all could have insulation that is breaking down that could cause this problem.
Before you go and buy anything and if you have the time and patience and confident enough and know what you are doing, I would remove the oven from the cupboard, take off the top and back covers, note the wiring for the element, take the leads off the element and run the oven with the element disconnected and see what happens. That should prove whether it is the element or anything else.
BE CAREFUL.
Jun 06, 2010 | Stoves 720EF Electric Double Oven
I have just purchase a Wagner W550 electrical spray gun. Not having used one before I need to know how do I know if the coating mayterial need to be diluted and if so by adding how much solvent. I intend...
Have a look at the instruction manual. It should state the viscosity that the paint should have. Use a viscosity cup to measure the time the paint takes to drain from the viscosity cup. Dilute the paint if it takes too long.
Nov 24, 2009 | Wagner Air Tools & Compressors
How do i jumper out the start enable switch associated with the clutch pedal?
fold out a paper clip into a U shape and stick it in the back of the switch then if it starts you know that's the problem, then replace it.
Nov 24, 2009 | 2004 Hyundai Elantra
My LGQ9508PV dryer operates (drum spins) but there is no heat generated. The flame does not come on at all. Can anyone tell me the most common cause before I purchase a lot of parts and work by trial and...
Check the wires at the Element. Wire sometimes blows off of one side of the Element.
Chech with an ohm meter to see if the Element has opened
See if there is 240Vac at the terminal leads at the Element, If not, there is a round thermal cut off that one of the Element wire goes to first, then to the Element.
These are the most common thing's that I have found in these machines.
Best!
Robert Wagner
Oct 02, 2009 | Whirlpool Dryers
CBR 1000 MECHANICAL PROBLEM
First you must check if your oil lamp is working. Normally after you start your machine and it reaches the minimum pressure above 1 psi, the oil lamp Will light off.
So if you had a problem with your oil pump and it burned you’ll not have information about your lubrication system.
I think you have a problem with your oil pump.
When you open your motor check the color of the pieces when they are blue means that they work with high temperature.
This machine is a good one and if you drive normally it won’t fail.
Please check this and let me know.
My e-mail wagner.mta@gmail.com
Thanks,
Wagner
Nov 10, 2008 | 1988 Honda CBR 1000 F
Tools & Hardware - Others Logo
164 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
