Question about Hitachi VH650 2 1/2" Full Head Fencing Coil Nailer
I am using 2-1/2" nails thin ribbed coated common nails. The nails go in about 1-7/8" and bend over always in the same direction. I recieved this gun from a friend and am not sure it is working properly. Before I buy other nails I want ot be sure it is.
    President:
  • Hitachi Master
  • 1,388 Answers
More than likely your piston/driver is broken at the tip. Remove the head and push the piston all the way down. It should extend out the bottom about a quarter of an inch. If you need a replacement go to www.toolpartsdirect.com. If the driver is just worn at the tip, grind off just a small amount to make it square and install a new piston seal. Good luck and post again is you have more questions.
Posted on May 28, 2010
Bought hitachi nr90ad nail gun and it isn't firing right..what exact size nails should i get ( as in 35,33,or 30 degree nails)
Use 34 degree, paper collated, clipped head nails. They were always the most common strip nails years ago as Senco, Paslode, and a number of other nailers used them.
Jul 25, 2011 | Hitachi NR90AD 3 - 1/2'' Clipped Head...
Brad nail only goes 1/2" into wood. there is no
You might get better penetration if you use your other hand to press the gun down firmly onto the surface before you pull the trigger. (This will help if the gun tends to jump a little when you fire it.) Or, if the surface you are firing into might not be rigid enough (like a thin board that is not supported) - in that case you might improve the penetration by better supporting the surface you are nailing into, perhaps by placing it on the floor. On the other hand, this may simply be a case that the gun is not powerful enough to do what you want it to do. To test that theory, try it into a piece of soft wood (like a 2X4) or find a soft thick material as a first layer over the wood you are using. Perhaps you can use shorter nails - thin brads in wood don't gain much strength beyond 1/2 inch penetration anyway. The length of the brad only needs to be about 1/2 inch longer than the thickness of the first layer of material. I hope this helps, good luck Al K
Feb 24, 2011 | Arrow ET200 Electric Brad Nail Gun
Gun fires, leaves good indentation, no nail. WCE working properly, took head apart to look for jam but nothing in there and am using compatible nails. Also oiled it but no luck. Was working fine doing...
Remove nails and use thin tool to push driver all the way up to top of cylinder. If the gun fires one nail then skips, the driver is not returning to top of cylinder. If no nails fire, then nails are not feeding into proper position. Driver must return to top to allow nails to feed into position. Most common problems are bent driver, worn piston oring and bad batch of nails(head too large). Good luck
Jan 14, 2011 | Campbell Hausfeld 2-in 18 Gauge Brad...
Can i use full round head 3-1/2 passlode nail in this nailer
The FC350A uses a 30- to 34-degree collated clipped head nail which is very similar to the Paslode 34-degree round head nail. Paslode's nails are unique because the round head nails collated very close together and the head of the nail is offset to the shaft unlike Porter Cable full round head are further apart and the head is centered on the nail. What does all this mean? The Paslode round head nail may work however the driver will deliver the blow off center to the shaft of the nail, This could cause the nail to bend as it enters hard wood and possibly jamb the gun. You should be able to exchange the nails (with small restock fee) at a major fastener store (not Lowes or etc. ) with out having purchased them at location because the Paslode nails are very popular and with todays economy the store will gain a new customer. If however you would like to try using the nails, try the following. Remove the head of the gun to expose the driver. Install the nails as usual and with **** of small hammer quickly and firmly push driver all the way down the cylinder to see if nail is easily pushed out of bottom of nose. (You can push driver back up with long thin screwdriver or allen) If successful, replace head and connect to air however lower pressure to 40-50 psi and nail into soft wood increassing the pressure little at a time with each test untill full pressure around 90-100psi. Good luck
Jul 19, 2010 | Porter Cable Cable No. FC350A Clipped Head...
Strike Element on nail gun does not retreat back int gun
may be gummed up try spraying with a carburetor cleaner and let it soak than spray with a penetrating oil and try a couple of nails sometimes the gun gets gummed up by the plastic or glue holding the nails together if it still is stuck possible slight burr or bend in rod
Feb 10, 2010 | Porter Cable-Cable FN250C 1-inch...
Shooting 2 nails at a time and then jams
make sure you are using 18 gauge brads in the gun. also if the brads have gotten wet or are old, the paper or wax coating on the becomes weak and it will release more than one nail at a time. try different brads in it.
Dec 15, 2009 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Can i use any brand coil nailes in my nv 45ab2 coil nailer
Yes. Roofing nailers all use about the same size and spacing on coil nails. You will find that Harbor Freight is about 1/2 the price of Home Depot or Lowes for those nails.
-Jim
Oct 17, 2009 | Hitachi NV45AB2 Roofing Coil Nailer
Bostich gun problem
If the piston/driver is broken, the gun will fire however nailing will not take place because the piston will jam in the cylinder. Sometimes the cylinder will also crack when the driver goes. If the piston is not broken but stays down, then check the cylinder check valve, worn lower bumper, bent driver or cracked cylinder. 18 guage nailer has a very thin driver which will easily bend or break. Parts however are not expensive.
Nov 18, 2008 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Staple Gun Troubleshooting
Most of the staple gun models lack an "anvil" — the metal plate with curved slots that office staplers use to bend the legs of the staple inwards and flattens them against the paper. Staples set with a staple gun retain their straight legs, and are held in place only by static friction of the legs against the compressed surrounding material, much like common nails. Indeed, some staple gun models can handle brads and nails as well as staples. Some staple guns also use divergent point staples where the legs twist as the staple drives into the surface providing superior holding power.
Aug 27, 2008 | Arrow T59 Wire & cable staple gun
Nail Guns Safety problem
Professional-grade varieties are automatic, and fire a nail directly upon pulling the trigger. A semi-automatic nail gun is more appropriate for beginners, since it requires a two step process: pull the trigger and then tap the barrel against the wood. This safety feature protects the user from accidentally firing a nail gun and injuring himself or others.
Aug 27, 2008 | Arrow No.ETF50PBN Extra Heavy Duty...
Hitachi VH650 2 1/2" Full Head Fencing Coil Nailer Logo
66 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
