Question about Euro-Pro Shark SC-505 Handheld Steam Vacuum
What do you do with the excess water in tank when finished mopping?
    Brigadier General:
  • 3,917 Answers
Hi
To insure continued operation of the steamer, never store without cleaning and removing all excess water from the water tank. Note: Water quality will vary in different areas.
Let us know if you want to know something else accept the suggestion.
Thanks for contacting fixya.com
Posted on May 26, 2010
Can I safely use the Shark pro Steam Pocket mop S3601 on dark hardwood floor?
You will not hurt your finish by using the steam mop...use it without any type of cleaner on the mop head and you should get a great streak free shine...
Jan 07, 2015 | Shark Vacuums
Shark Euro Pro Steamer
Hi, you could try the following steps, if you have not done so already. Some of these steps may seem like common sense, but it's for people to forget about checking the least expensive part to replace first, so if some of the steps are those that you have already tried, then feel free just to skip through to the ones you have not tried already.
  1. 1
    Make sure the power cord is plugged firmly into the outlet. The steam mop will not start if it the power cord is loose.
  2. 2
    Check the fuse box or circuit breaker connected to the outlet the steam mop is plugged in to. Replace any blown fuses. Reset any tripped breakers.
  3. 3
    Check the water tank if the Shark steam mop will not produce steam. Add water to the tank if it is empty. The mop will not make steam without water in the tank. To fill the tank, turn the tank cap counterclockwise and lift it up to remove it. Set the filling funnel into the tank opening. Pour water through the funnel into the tank until the water level reaches the "Max" fill line on the tank. Replace the cap.
  4. 4
    Inspect the microfiber cleaning pad if the steam mop is leaving water on the floor. If the microfiber pad is too wet, it will leave water on the floor. Unplug the mop from the wall outlet. Replace the microfiber cleaning pad. To replace the pad, move the latch strips out of the hooks on the mop head. Pull the pad off. Set the new cleaning pad on the mop head. Hook the latch strips onto the hooks on the mop head.
  5. 5
    Use distilled water if the steam mop is leaving white spots on the floor. Hard water may cause white spots to be left.
If none of the above work, then is it something that you purchased recently, and is new? If you did, then it could still be fixed under the manufacturer's warranty regardless of whether or not the original length of the warranty has expired. This could be due to the fact that you have received a product that has some sort of manufacturing fault, rather than it stop working through misuse by the user.
If it's a common problem, then you will more then likely be able to return it to the manufacturer and have it replaced for a new one, let alone repaired :-) - This only applies to whether or not the item is New though :-).
Hope this info helps
Apr 29, 2013 | Vacuums
Shark steam mop will not syeam grey pruple shark steam mop
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Nov 04, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
How much water do I put in my shark steam mop??? I got no cup or anything with mine
Just fill the tank...
heatman101
Aug 24, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steaming very little. The mop used to have strong bursts of steam, but now will steam very little. I use distilled water in the tank. Should I clean it with vinegar and water?
It will not hurt it to try and clean it...
heatman101
Dec 15, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop is spilling water out and not steaming.
Empty tank and fill with bottled spring water...
heatman101
Dec 05, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Have power and water in tank water gets warm but no steam not pluged
Hi,,
heatman101
Oct 08, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop model 3101
Here is the webite to purchase the carpet attachment for your steam mop.
http://www.fixya.com/support/t704954-shark_steam_mop_model_3101
Before you buy the carpet attachment, you might want to read this review. I found it very helpful because I couldn't find much on how it works on your carpet or any reviews on the attachment. Her comments were all positive.
here is the link:
http://www.epinions.com/content_425654455940
Jun 25, 2008 | Euro-Pro Shark Steam Mop - Gray/ Purple...
How do I change my kirby g4 to sweep/mop mode?
Turn the belt lifter to red arrows matching to sweep the kitchen floor. This stops the brushroll from turning and allows you to use straight suction. There is a hard floor pad available...see the link to my guide and you may find one for sale...
As for mopping...I just dump a small bit of soapy water on the floor and run my Kirby shampooer (with no solution in the tank) on the lowest setting to scrub, then I dry mop behind it to pick up the excess water. There really are no instructions in the manual for scrubbing linoleum, but I just improvised. It splashes a bit, but better than getting down on hands and knees. Here is a guide to hook up the shampooer...
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Hope this helps a bit...
Marci
Dec 12, 2007 | Kirby G4 Bagged Upright Vacuum
Euro-Pro Shark SC-505 Handheld Steam Vacuum Logo
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Greg Cann
Greg Cann
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
