Question about Kenmore 24032\24036 Top Load Washer
When washer is spinning it smells like something is burning
The washer didn't fully spin, put it back on the cycle and it worked but a burning smell started
  • 549 Answers
A burning smell means you have some slipping of the drive belt. I think your belt needs to be replaced. Another reason may be a binding in the tub. possibly a seized tub bearing. The only way to know is to take off the access cover at the back of the washer and visually inspect it first. you can spin the tub by hand from the back and this will give you an idea of what is binding.
Posted on May 26, 2010
Washer agitates but will not spin. Burning smell coming from motor
The water pump could be stuck, or broken so the pulley on the pump is not spinning, while the belt is, which gives you the burning smell. Could also mean the motor is overheating giving you the burning smell. You will have to open the back and observe whats happening while its running. Just keep your hands clear while its working.
Feb 16, 2015 | Kenmore 98702 Stacked Washer/Dryer
Washing machine has smell (burning) and doesnt spin or drain tub.
Sounds like the belt may need to be changed. it eh pulley are spinning but the belt is not, nothing will spin and the friction of the pulley against the belt will cause a burning rubber smell
Nov 27, 2013 | Washing Machines
Burning smell
There's a number of reasons to smell burning after a washing machine cycle. It's a 220V appliance, so if it short's out it will cause problems. It's more likely the motor being overloaded making it hot and causing the electrical burning smell, or a short that's overheating something electrical. Check to see if the belt that spins the whole barrel is melted or worn anywhere. Inspect the wiring that's attached to the system that engages spin, which is different from agitation by the big tower.
If these both check out, an trip to the Maytag Man might have to fix overloading motors or relays, or switches, if anything turns up in your search for the source of the electrical smoke. Ozone is what you are smelling, FYI.
May 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
I got an estate whirlpool washer and it wont spin and i smell a burning smell
YOU HAVE SOMETHING STUCK IN THE WATER PUMP OR YOUR MOTOR COUPLING IS BAD
Jan 15, 2010 | Estate TAWX700JQ Top Load Washer
GE Wizard Top-Load Washer - Burning Smell
sounds like an over heated motor. motors tend to do that before finially hitting a brick wall. please e-mail me for any other assistance. good luck :)
Jul 07, 2009 | Washing Machines
Washer stopped spin cycle smell like burning rubber
hello if the belt is broken quite easy to put back on .take the back off you should see the belt if it has snaped or just come off .at the bottom of the washer you should see the motor at the back of the motor you should see 2 nuts this holds the motor on get a felt tip pen and mark the 2 nuts where they are fixed so you know where to tighten back on . get spanner and loosen the 2 nuts the motor should drop down put the belt back on and tighten up good luck
shaun
Mar 31, 2009 | GE Washing Machines
Whirlpool top loader won't spin
If you are lucky you need a set of clutches about $45. If you are unlucky you would need a transmission.
Since it spins after you help it, I am guessing clutches.
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore Elite washer, model # 22942101 Spin cycle not working. The water drained out but the drum does not spin. It smells as if something burned out.
If the water drained out, then it sounds like the motor is still good.
I would check if the brake were failed in some manner since you smelled something, and if that is OK, then it's probably a failed gearbox.
Jan 27, 2009 | Kenmore 24032\24036 Top Load Washer
Washer smoke during spin cycle...
could be belts slipping or a bad motor going - what's it smell like - burning rubber or an electrical smell?
Aug 28, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 24032\24036 Top Load Washer Logo
285 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
