Question about Poulan Garden
Weedeater TE 400 CXL will not start. Can the
Weedeater TE 400 CXL will not start. Can the carburator be fixed?
3 Suggested Answers
rycgl
  • 1545 Answers
SOURCE: My te 400 cxl weedeater
People replace fuel lines all the time as they deteriorate over time. This is a fuel delivery problem most likely and will require installing some new parts in the carburetor to fix. You can go with the cheaper diaghram kit or a full rebuild kit (includes the parts in the diaghram kit). This is a very, very common problem with these machines. If you feel you have to clean the carb at any time, only use non-flammable brake cleaner spray on it. Stronger cleaners and carb sprays can damage very sensitive internal parts. Don't use any high PSI air on it either as this has the same result as the strong cleaners. As far as an air line goes, these machines probably don't have one but they do have an air filter that needs to be checked or cleaned or replaced. They also have a fuel filter that is located on the end of the fuel supply line inside the fuel tank. Check that also.
Posted on Aug 15, 2010
  • 57 Answers
SOURCE: how to install the Speed Spool Bump Knob Assembly
Do you have an owners manual? If not, try poulan.com
Posted on May 19, 2009
How do I fix a echo srm 210 weedeater that starts but will only run a few seconds?
Try calling echo and ask for tech support or go online to get the phone # or check you tube to see if they have a video on it
Apr 05, 2016 | Echo Garden
Poulan weedeater will start but dies when switched to run
Clean the Carburator, Clean out the Carburator Bowl and Float, Change the Spark Plug
Apr 07, 2013 | Craftsman 25cc Gas Line Trimmer
Poulan pro weedeater will not start without starting fluid and wont accelerate after starting Once started the first time it is easy to restart and idles fine, just cant accelerate the motor without it...
Your carburator is clogged.
1st make sure you have FRESH gas.
Empty and clean the fuel tank
Remove and disassemble the carburator and soak it in fresh gas for about 15 minutes to disolve any gunk.
Using a can of small carburator cleaner ( available at Lowes, Home Depot etc.) blow out all the ports.
reassemble and refuel with clean fresh gas
The little carbs clog easily
May 19, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I have a Weedeater brand weedeater that needs the carburator adjusted. I am not sure how far the adjustment screws need to be turned out. Can you help?
Start with about 1 1/2 turns. Then, when you get the motor started, hold the throttle to full and adjust the screw until the motor revs up and evens out. Likewise for the low speed. If you give it the gas and it dies or stutters, turn the other screw slightly 'til it revs up without hesitation.
Aug 15, 2010 | Garden
My te 400 cxl weedeater starts but won't continue to run. can I replace the fuel or air line?
Aug 14, 2010 | Garden
My weed eater wont start.
One of the problem could be is you have one of the line in this case top line in the carburator clog. For clean the carburator You need to remove first the cover for the filter 2 screws on front of the carburator remove lines mark the lines top and bottom remove slowly the carburator be careful with the gasket. The carburator have 4 little screws removed and remove the black gasket (diaphragm) clean with carburator cleaner and air, blow air thru the top line tube, now on the otherside remove the screw and clean the gasket and the carburator inside do the same step. Make sure you clean the fuel filter inside the tank with carburator cleaner.
Apr 05, 2010 | Troy Bilt Tb70ss Gas Trimmer
Weedeater carburator setting on bolens 31cc
initial setting is 1and1/4 turns out for walbro carb.
1 turn out zama carb.
May 26, 2009 | Garden
I replaced both broked fuel lines and it still doesn't start.
Make sure the line is connected to the fuel cap if it has a pump ball.
Apr 24, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
New carburator doesn't passed fuel
Are you sure that that the replacement is the correct one. Also, why did you have to replace the carburetor . Did you verify that the carburetor was the problem? Did the weedeater run by priming? Did you check the pump and lines? If these methods were tried and did not reveal the problem, then I suggest that you get professional help.
Oct 23, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
264 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
