Question about Siemens Computers & Internet
POST and BIOS Question: Dead laptop I`ve been given a Fufitsu Amilo L6825 laptop which is faulty.( It fails to get by the POST test so doesn`t even reach the BIOS option.(It switches ON, fans run but black screen with no BIOS beeps. The only light lit is the ON light ) Using substitution and known working spares, (I have the same model of laptop) I have deduced that the original problem was possibly due to a faulty harddrive .(does not work in my laptop) However, even with a known working harddrive, it still does not boot up (no display , no beeps) I`ve gone through the usual method of faulting by disconnecting the CD Drive , HDD , memory : stick removal + slot swops ,battery removal , screen swop , power unit swop etc. and still no joy...plus a visual check of the circuit board for damage or overheating or blown capacitors etc ) plus a ''Default Reset'' by pressing ON button for 30 seconds To me , this now looks as though the problem might be on the motherboard. As it does not seem to go through the initial POST or BIOS checks I wondered whether it might be the BIOS. Fortunately it is a removable chip so I swopped it...Still fails as before. The only other option available to me now was to try and swop the CPU................Swopped and Still fails (note both CPU and BIOS chip still work OK as fitted back OK into my own laptop ) Anyone any idea what to do next? I assumed that the BIOS chip controlled the POST test...but does it? If not what does? Any suggestions most welcome
  • xxxxxx xxx May 29, 2010
    Judging by what is said on here and elsewhere, it looks as though everyone gives up at the point where it points to the motherboard.
    I was hoping that someone on here had the actual experience of faulting a motherboard down to an area or component or giving a few pointers as to what problems are actually found ...or nowadays do computer technicians (both amateur and professional ) just throw a complete motherboard away and replace it with a substitute ?
    I understand that a common point is the power supply ,(eg the 1.8v rail ) but something within the power supply circuit has to have failed and could possibly be tested or have some visible sign of failure.
    Genius:
  • 1,027 Answers
Since you swapped everything, the last option will be the on-board power supply. If it has failed, then nothing will work. As a guess, I would assume the 1.8v power supply for the CPU has quit.
Posted on May 27, 2010
Reboot and select proper boot device, pxe e61 media test failure check cable
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Nov 04, 2012 | MSI L1350D-1672US Netbook
New memory, the board just beeps
First of all that board supports DDR400 (PC3200) so why did you get PC2100 chips?
Anyway, do a bare minimum test (only MB, CPU, RAM & PSU connected, nothing else). Remove all the RAM and test each one individually. Properly insert one into the first RAM slot and test by booting until the POST RAM test is finished. Shutdown and repeat the test with the same RAM module in slot 2 and keep repeating this for every slot. If successful in every slot, mark that module as working then try the other RAM modules using the same procedure.
  • As soon as you find one that doesn't fully pass the POST test, mark it as faulty.
  • If some pass in one slot but not another, then mark it as faulty.
  • If they all fail to pass on a specific slot, mark that slot as faulty and don't use it (you can use electrical tape to cover the slot for future reference).
Once you've finished the bare minimum test, try 2 RAM modules this time (use only the modules that you found to be working from the above tests). Mix and match the RAM modules & then try 3 together and even 4 (if you found all of them to be working fine).
Finally once you're satisfied you've found the modules that work properly, boot with memtest and test the RAM for any problems. If they all seem to work fine individually, boot them individually and test with memtest to determine which ones are actually faulty.
Jul 13, 2012 | HP Compaq Presario SR1610NX (ED865AA) PC...
PXE-61: Media Test failure, check cable
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Mar 11, 2012 | Toshiba Satellite M45-S269 Notebook
Dv6000 black screen
WOW NO OS STATED why even post?
the black screens of *****, know them well , i do these only.
mostly...
or found on road dead, found this in and attic, or in a dumpster
well it can be any thing right, 3billion transistors and GB of of windows files endless ,to fail. yah or the HDD dead or 1/2 dead.
but windoz is last. always.
first is BIOS, screens,
i presume BIOS never ever shows text or the HP logo
so that means what the CCFL is dead, as most are now this old
dead as a brick the black light see here. see the flash light
trick test, this always test 1, on any of the below listed LT (yours)
http://pcdied.com/monitors.html#Laptop
check out the CCFL Laptop and monitor lest there, hard to get that.
Jul 28, 2017 | HEWLETT-PACKARD HP DV6000 Laptop...
My Fujitsu AMILO M3438G will not startup. I,ve changed the cmos battery but it still says that the bios is wrong. I've tried pressing the F2 key but then the monitor displays a "wait" page...
The lines on the screen point to a failing graphics chip, faulty VGA lead or more probably, the screen itself beginning to fail.
The bios problem is most likely due to a damaged bios chip, this is usually caused by attempting to upgrade the bios by flashing and the flash process going wrong, resulting in a series of instructions on the bios chip being incorrect. Changing the Cmos battery will have no effect.
You need to reflash the bios with a stable version, this can be done via floppy drive or USB stick, but you will need to obtain a usb floppy drive (I THINK the bios on the laptop supports this). On the floppy drive, you will need to install a windows 98 type boot disc
http://www.bootdisk.com/
and obtain the bios and flash file for this laptop
http://ts.fujitsu.com/support/downloads.html ( dos version)
On another computer, copy both to separate floppies, boot to the floppy drive, let it load the OS then swap floppies and load the bios flash from floppy
I believe that you can also get the ISO (cd image) which, as long as the laptop can read the cd drive, will be a better option.
If you cannot even get the bios to recognise the floppy or cd, then the problem will need a replacement bios chip installing to sort it out
Jul 18, 2011 | Fujitsu Siemens AMILO Pro V2000 Notebook
Display of amilo L6825 has no brightness
please try increasing your display brightness by using the fucntion + brightness keys on your keypad several times
try replacing the battery for the battery problem
if u dont want to replace the battery then get the cells changed from an elec. shop
hope this solves your problem
Jul 10, 2009 | Computers & Internet
My laptop HP Pavilion dv1000 is not working so I pressed F10 for the Bios Setup Utility went to tools to do a Hard Drive Self Test and the Test Status is #1-07 Fail. What does that mean?
Hi there.
The error code means the drive has failed or that Self-Monitoring, Analysis, and Reporting Technology, or S.M.A.R.T is faulty.
Go back into the bios and disable the
S.M.A.R.T, hit F10, save the changes and try to boot again.
Please post back with the results.
Good luck
Jun 08, 2009 | HP Pavilion dv1000 Notebook
BIOS CMOS battery dead
You just have to go to the nearest computer store and purchase the battery you needed.
May 01, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
D7830 Amilo
There can be a number of reasons for this, Check out these options;
Switch Memory over, failing that test one at a time. Plug in an external monitor. Check the Bios Settings and Bios Battery. You can find other tips at: www.powerjackrepair.com
Nov 28, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Computers & Internet Logo
371 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
