Question about Black & Decker Garden
Our 2 in 1black and decker hog edge/trencher just quit working
Our 2 in 1 hog edge/trencher just quit working while in use ...any advise on how we can fix this unit ...
4 Suggested Answers
darth yoda
  • 4 Answers
SOURCE: Motor runs but base doesn't spin to do the trimming. How can I fix this? I have a Black & Decker 14 inch Grass hog- electric trimmer.
gearbox!! get rid of it
Posted on May 29, 2009
saumyar
  • 174 Answers
SOURCE: need manual for edge hog
you can buy it from amazon.
http://www.amazon.com/Black-Decker-LE750-Electric-Landscape/dp/B00004DTNH
thanks.
Posted on Jun 09, 2009
  • 133 Answers
SOURCE: how to restring back and decker grass hog
For Black and Deckers: Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit. Replace empty spool with new full one or wind on aftermarket string. Wind in direction of arrow on spool. Make sure spool is seated on rachet firmly.
Posted on Apr 21, 2010
Blade spins with out a load but with load it stops spinning B&D Edge hog Le750 type 3
sounds like the drive may be stripped. look up parts diagram for drive parts and see if there is a plastic part.
May 17, 2013 | Black & Decker Black and Decker & Grass...
My Mod. 2400, type One is dull--7yrs. old. How do I sharpen it? Thank You
Hey i found this for you i might help. Click on the link at the bottom!!
How to Sharpen a Black and Decker Hedge Hog sharpen-black-decker-hedge-hog-800x800.jpg Maintaining the sharpness of electric timmers can made landscape trimming easier with beautiful results.
Electric hedge trimmers make trimming hedges and bushes easier and quicker than using manual hand-powered trimmers. Electric trimmers, the most popular type in the U.S., cost less and require less maintenance than gasoline-powered models. Electric trimmers are used most often by homeowners with the Black and Decker Hedge Hog series being very popular. While they are not premium products, electric trimmers like the Black and Decker Hedge Hog trimmer can keep trimming reliably for years with proper maintenance, including sharpening the blade's teeth.
Difficulty: Moderately Easy Instructions Things You'll Need
  • Work table
  • Two medium size clamps
  • Dremel tool or similar hand-held multi-purpose tool
  • Grinding wheel attachment for hand-held tool.
  • Dremel 971 (or similar) aluminum oxide grinding sharpening stone with a tip small enough to cover the flat facet of a Hedge Hog blade tooth
    • 1 Unplug the electric trimmer before trying to sharpen the teeth.
    • 2 Clamp the electric trimmer to the work table using two clamps if necessary so the Hedge Hog is firmly held down with the blade teeth accessible over the edge of the work table.
    • 3 Insert and secure grinding tip in hand-held multi-purpose tool.
    • 4 Maneuver the grinding tip so it is perpendicular to the facet of the Hedge Hog tooth.
    • 5 Sharpen teeth in one direction, being careful to try and maintain the same cutting edge angle on the sharpened tooth of no less than 35 degrees.
    • 6 Make same number of grinding passes/grind the same length of time a few seconds on each tooth.
Tips & Warnings
  • This task should take about 15 minutes.
  • Keep a light touch; too much force can break the grinding surface.
  • For best results, insert the sharpening bit slightly less than all the way into the tool.
Read more: How to Sharpen a Black and Decker Hedge Hog ' eHow.com http://www.ehow.com/how_7163131_sharpen-black-decker-hedge-hog.html#ixzz1XsAosvvl
Sep 13, 2011 | Black & Decker Hedge Hog 24-Inch 3.0-AMP...
I have lost my manual for my Black and Decker Edge Hog model LE750 any help in finding one would be greatly appreciated. Thanks for any help you can provide, Bill
Which type of the Black & Decker Edge Hog do you have? (This will be on the plaque with model and serial number.)
Black and Decker has the manuals for type 1 through type 5 on their site: http://www.blackanddecker.com/outdoor/LE750.aspx . Click on the Instruction Manuals link.
The direct link for the manual for type 1-3 LE750 Edge Hog is http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/243420-02,LE750.pdf .
I hope this helps.
Jun 21, 2011 | Black & Decker Garden
I have Black Decker electric Edge Hog, does not turn on anymore. Is there a fuse or power reset switch?
I have a black & Decker Electric Edge Hog, does not turn on anymore. Is there a fuse or power reset switch?
Jun 13, 2010 | Black & Decker Le750 Lawn Edger
Do I ever need to sharpen? If I do, how?
How to Sharpen a Black and Decker Hedge Hog sharpen-black-decker-hedge-hog-800x800.jpg Maintaining the sharpness of electric timmers can made landscape trimming easier with beautiful results. Electric hedge trimmers make trimming hedges and bushes easier and quicker than using manual hand-powered trimmers. Electric trimmers, the most popular type in the U.S., cost less and require less maintenance than gasoline-powered models. Electric trimmers are used most often by homeowners with the Black and Decker Hedge Hog series being very popular. While they are not premium products, electric trimmers like the Black and Decker Hedge Hog trimmer can keep trimming reliably for years with proper maintenance, including sharpening the blade's teeth.
  • Work table
Tips & Warnings
Oct 17, 2009 | Black & Decker Hedge Hog 24-Inch 3.0-AMP...
Need manual for edge hog
thanks.
Jun 09, 2009 | Black & Decker Le750 Lawn Edger
Auto feed will not work
I think your problem is the little plastic ( white ) lever ( part# 598435-00 ) on the inside of the housing that holds the spool. Mine was working fine and then it just stopped feeding line altogether. I would order a couple (3-4) so you have them in stock. Looks like a part that will wear out fast. I wish they still sold a bump type weed eater. Hope that helps.
May 28, 2009 | Black & Decker 14" Grass Hog Xp...
Garden Logo
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
