- Someone is sending print jobs
HP officejet J6400 - Someone is sending print jobs to my printer. How do we set the security so only I can print to the printer wirelessly?
  • MyPC Solutions
    MyPC Solutions May 26, 2010
    Please clarify what type of printer you have.
  • greg benton May 27, 2010
    are you using a router in your network?
5 Suggested Answers
bramha
  • 36 Answers
SOURCE: Hp Printers J6400
Hi
Click Start  Settings Printer and Faxes
Right click on the printer icon select Use printer online
do it will work
Posted on Nov 19, 2008
  • 2692 Answers
SOURCE: HP Wireless Printing Upgrade Kit - HP G55 Officejet Printer?
Yes ; The Officejet 6000 series os one of thse listed on the HP website under the "Wirless upgrade kit" that is compatable.
Posted on Feb 05, 2009
nalin_elliot
  • 224 Answers
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. CauseAny of the following issues can cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
Posted on Oct 03, 2009
  • 693 Answers
SOURCE: what is an error 283
Definitions
  • A communication failure occurred between the two machines.
  • The user at the remote machine might have pressed the Stop key.
  • The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line. Do not use call waiting on a line with a fax machine.
  • The power at the remote machine was interrupted, or deliberately turned off causing the fax session to be interrupted.
Solutions
  • If the error persists, and error correction is in use for the fax session, disable ECM. Fax quality might be degraded. Click here for instructions on enabling and disabling ECM (c00060802) (in English).
  • Set the host machine to receive at a slower transmission speed.
  • Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power brownouts and other power-related problems
    Posted on Aug 31, 2011
    Have a false paper jam on my HP all-in-one J6400 series printer
    look here
    http://h30434.www3.hp.com/t5/Other-Printing-Questions/HP-OfficeJet-J6480-false-paper-jam-error/td-p/12759
    Apr 04, 2014 | HP Officejet J6400 series
    Why does hp officejet Pro 8600 crashes when printing avery labels?
    Avery labels may be blocked on your computer so check your security settings. Other wise you may need to refresh the page, your computer or the printer. If that doesn't help you may need to double check your ink cartridges are full and correctly placed, also that the wires connecting the printer to your computer are all in properly.
    Mar 01, 2014 | HP OfficeJet Pro K8600 Printer
    My son bought me a new PC & he downloaded the OfficeJer J6400 serries software to instal my HP to the new computer. It keeps saying HPOfficeJer J400 series failed installation. I also have this Ibm...
    You can find all HP OfficeJet J6400 series driver and software HERE.
    Try to de-install and re-install again when running as Administrator.
    (right mouse click on the setup file)
    Sep 06, 2011 | Computers & Internet
    I am using an hp officejet 6500 and I keep getting an error message 0x61011bec, what can I do to fix this problem?
    The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
    If you prefer, you can skip this information and go directly to downloading the tool .
    • Connectivity :
      • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
      • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
    • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
    • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
    • Device manager : Checks for problems in Device Manager that would prevent printing.
    • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
    • Port : Checks the port settings for the HP product.
    • Driver : Checks for alternate-driver settings.
    • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
    • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
    Oct 26, 2010 | HP Officejet 6500 Wireless All-in-One...
    HP Officejet J6410 ink reset
    1. Unplug the cord from the printer. Wait 30 seconds.
    2. Now Press 3 and the # key at the same time while plugging in the power cord.
    3. Release the buttons after the product starts up.
    Your product has now been reset to factory defaults.
    Jul 16, 2010 | HP Officejet J6410 All-in-one InkJet...
    Can't installed my HP Officejet J6400 on my laptop.
    * Which is the operating system of the computer?
    *What are the HP entries listed in the Programs and Features lsit? (or Add/Remove programs)
    Please get back to me with the above information. I can solve this problem
    :) Dr Tony
    Apr 08, 2010 | HP OFFICEJET 6410 All-In-One InkJet...
    I can not get my HP Officejet J4680 Inkjet Printer to work on wireless. Can only use with USB cable. I no longer have my Setup CD. Any suggestions?
    First check that your antivirus and firewall software are not blocking the print jobs. Do this by turning off the services for a few minutes. If you can print, check for a setup option of trusted machines. If that doesn't help, make sure you have a strong wireless signal between the computer and the printer with no interference from other appliances (cordless phones, microwaves, etc). Also check your settings to make sure the printer and computer are set for the same wireless network profile and security settings.
    For additional information, try the user's manual: http://h10032.www1.hp.com/ctg/Manual/c01770356.pdf
    I hope this helps.
    (I have generally preferred printing with a wired connection (USB) over using a wireless networks. I've always spent more time on printer problems that were directly linked to the network signal loss problems rather than printer issues.)
    Dec 05, 2009 | HP Officejet J4680 InkJet Printer
    Hp 4255, if i send five pages, it shut first five blank pages
    check your settings in Start->Settings->Printers->HP4255 rightclick ->properties-> preferences.....
    Oct 29, 2009 | HP OfficeJet 4255 All-In-One InkJet...
    HP Officejet Pro L7580 Wireless Connection
    YOUR PRINTER IS NOT A WIRELESS PRINTER IT CAN BE USED USING AN ETHERNET CABLE TO THE PRINTER FROM THE ROUTER
    STEPS
    SETUP>>NETWORK>>RESTORE NETWORK DEFAULTS
    SETUP>>NETWORK >>WIRELESS RADIO>>ON
    CONNECT THE ETHERNET CABLE FROM THE ROUTER TO THE BACK OF THE PRINTER.
    SETUP>>NETWORK >>PRINT NETWORK CONFIGURATION PAGE
    INSTALL THE PRINTER
    SELECT WIRED CONNECTION
    AND INSTALL
    IT WILL PRINT.
    OR IF YOU WANNA USE AS WIRELESS YOU CAN USE WPUK (WIRELESS PRINTING UPGRADE KIT)
    FROM HP.COM HOPE IT FIXYA
    Apr 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
    HP Officejet J6400 was unplugged, now Computer wont recognize it.
    CHECK THE FOLLOWING AREA OR FOLDERS IN THE COMPUTER SYSTREM.
    GO INTO CONTROL PANEL AND OPEN THE FOLLOWING FOLDERS:
    DEVICE MANAGER,
    NETWORKING AND SHARING CENTER,
    PROBLEMS AND REPORTS,
    SECURITY CENTER
    WINDOWS DEFENDER
    WINDOWS WIREWALL
    I WILL TAKE A GUESS IT IS THE ANTIVIRUS AND THE FIREWALL CAUSING ALL OF YOUR PROBLEMS.
    RODGANDYSR
    Mar 12, 2009 | Computers & Internet
    66 people viewed this question
    jasbo
    jasbo
