My haier hwr05xc7 temp won't stay on where i want it.it starts at 85 degrees and takes forever to go down. If i put it on 70 degrees and it just goes back to 85.Takes forever to cool my room down
  • 901 Answers
Thermistor problem. Replace with identical part.Check the compressor relay also.
Lastly the micro controller board.
Posted on May 27, 2010
What temp does fan come on
cooling fans should start operating from 80degreesC depending on the sensor setting (70-85) for your vehicle . But the fan should be full on at 85 degrees C
Apr 18, 2014 | 2003 Cadillac CTS
I have a Haier BC112G. It is not cooling at all. Temp panel works, so I can set the thermostat up or down, but nothing happens and it just goes back to room temp after that.
Our magic chef wine cooler (mcwc50dbt) when temp is set on digital panel at 45-50 it jumps immediately back to 70 degrees constantly
Sep 25, 2013 | Haier BC112G Wine Cooler
Motherboard A8V-E SE core Temperature at 58C is that normal?
Hi
AMD's CPU temperature's range from 10-85 degrees, the normal is around 48-60 degrees. So your within the normal. Sometimes depending on what your doing, the chip will run up to 70 or so, that's also normal, but you want to make sure that it doesn't stay at 70 for long. It will shorten the life of the CPU.
Thanks for asking on FixYa
Mark
Jan 31, 2010 | ASUS A8V-E SE Motherboard
A/c stops blowing cool air after 90 minutes to 2 hours driving
sounds like it has a slow leak in it i would put dye in it and drive with it on for about 3 days and take a light see if u see dye comeing out anywhere
Jul 19, 2009 | 2004 Dodge Intrepid
I have a comfort zone furnace. If it's 50 degrees in the house, and i set my thermostat to 70 or so,it takes at least 24 hours to reach 70 degrees. The furnace starts up and runs normally for about five...
When the thermostat calls for heat it should run until the room reaches the temperature setting then shut off. Is the blower motor running and can you feel air coming out of the vents? It sounds like the blower is either not running or putting out enough air to keep the furnace heating. The blower moves the heat from the heat exchanger to the room, if it can't remove enough heat from the heat exchanger there is a limit switch that will shut the burner off if it gets to hot and that's what it sounds like is happening.
Apr 25, 2009 | Heating & Cooling
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
Haier hwr05xc7 after a few hours completely shuts off
I don't own this unit. However, you can try calling the "Haier Customer Satisfaction Center" @ 1-877-337-3639. Good Luck! littlesinger
Jul 21, 2008 | Haier hwr10xc6 Air Conditioner
Humidifier not taking out water
I have the same problem. I have had the unit less than a month. Haier's policy is for me to pay $14.99 so they can send me another one. What a huge ripoff.
Jun 03, 2008 | Haier 65-Pint Dehumidifier
Heating & Cooling Logo
160 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
