Question about Canon i350 InkJet Printer
Canon i350 does not print all colors
My Canon i350 does not print all colors, just green. Cleaning and color ink tank replacement didn't help.
Any clues ? In the midst of printing a color document printer goes from full color printing to just green. Tried to print other documents and it prints only green. Can you help, please?
  • Anonymous Mar 31, 2014
    canon ir2550 printing green colors
  • 4,889 Answers
Looks like the print head is clogged with green..
Have a look at this..
http://www.fixya.com/support/t489595-much_green
Posted on Apr 07, 2008
  • 813 Answers
Hi friend
u have clour cardige are bad so replace it buy new cardige & try to print i tink ur problem will solves
    Genius:
  • 3,422 Answers
HI,
Hope this will give you hints. To pin point directly you need to replace printer head. But before replacing please consider suction cartridge caps or nozzle by cleaning and freeing clogged airways by dettaching manually. I understand that the long time being not used has caused the problem. However if you can still use black and other colors then used it than complicating downtime in repairing procedures. Yes, you are right no need to clean deeper more than three times it will consume inks half empty. Have a nice day.
Please don't forget to rate the solution..
My Canon Pixma MP258 printer can't print the red color but other colors are okay.When I print out any words or pictures that needs red color,it becomes green color.I don't know what's wrong...
Solution
1. Press START - Devices and Printers
2. Right-click the Canon MP258 series - select Printing preferences
3. Click Maintenance - Cleaning
4. Select All Colors BK, C, M, Y - Execute
5. Wait until the process is finished (Do not start another operation until the cleaning has finished).
6. Click Print Check Pattern OK
If the results print out like this, there are two possibilities:
1. Red ink in the cartridge runs out. Solution: injecting with red ink
2. If the red ink has been filled, and check pattern is still not out, meaning the color cartridge error.
Solution: replace the cartridges
Oct 15, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Canon i350 printer won't print; alternates flashing green/orange.
Sounds like the printer head is clogged or damaged.
I believe that sequence stands for (error sending data to print head). Not sure if it can be repaired or not, its hit or miss with the canon printers.
The ip series, the heads were removable and the whole section could be replaced. Give canon a call and see if thats possible with the i350 series. Worse case you will have to replace the whole printer.
Hope this helps.
Oct 25, 2009 | Canon Office Equipment & Supplies
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
Alarm flashes ink emptyhas ink! color was printing only yellow/green now prints only red/pink!
any chance it has dried out? run the test / head cleaning / did you reset the cartridge when you replaced it? generally if one or two colors work - the problem is the ink cartridge or the head for the colors not working. Did you remove the "tape" on the new cartridge?
Apr 16, 2009 | Office Equipment & Supplies
Colors are not printing out true.
I replaced the Office Max ink substitute with an original Canon ink. This did not help. I decided this problem most probably had to be a printer head issue, so I gave up and bought a new printer instead.
Dec 03, 2008 | Canon PIXMA MP780 All-In-One InkJet...
You probably have to clean the print head itself, witch seems to be a common need. Just take the print head out and clean the outputs with a Q-tip and distillated water. If tha doesn't work, let it soak in about a 1/4 inch of distillated water for a day or two and it may unclug the openings. Good Luck.
Mar 15, 2008 | Canon i350 InkJet Printer
Missing Colors
This is a simple problem just reset your printer's color management settings!!!!!!!!!!!!!!!!!!!! :-)
Oct 24, 2007 | Canon Pixma iP6000D InkJet Photo Printer
I960 canon printer
Lift lid ,let carriage stop in middle, un-plug the printer > Remove all ink tanks > Remove print head > Soak print head in > 3 parts very warm water an 1 part ammonia over night. Rinse under faucet with water directly over ink ports, shake out excess water,(if when you shake it out and if color still comes out repeat soaking for another hour or two and rinsing again ,HAD TO DO MINE TWICE) let air dry. (hair drier helps) Cured my problem for a while ,but if not used almost every day, this will happen again, I also use compatible ink tanks. Don'T believe the inks are as good as Canon Ink. But who the hell can afford them. So fill your owe with Canon ink from Canon. Still seems that the cyan always dries up first. Good luck Lestero1
Oct 18, 2007 | Cannon Canon i960 Photo Printer
Canon i350 InkJet Printer Logo
134 people viewed this question
old marine
old marine
