Question about Coby MP-C582 MP3 Player
MP3 Clip won't turn off
I can't turn the clip off. Can you help? I don't have a screw driver with me to take out the battery.
Hold down the play/pause button so the red light comes on then it will shut down.
Posted on Apr 09, 2008
Removal battery clip
This can be a trick. You can slide a small screw driver between the battery and the clip to release the clip. Sometimes you need a third hand. Tapping the bottom of the belt clip on the edge of a counter while slipping the screwdriver in the sweet spot will sometimes help.
Dec 31, 2013 | Motorola Mag One BPR40 Two Way Radio
My 2000 licolin battery died the key won't open the door lock how do get in to the engin to put jumpers on the battery to give it enough power to work the locks ps i don't understand why the key...
The key has to open the drivers door
Raise the car up,support it,& put your battery
charger on the starter battery cable terminal
& ground the black clip
Try charging the battery for 4 hours or so
Jul 02, 2011 | 1998 Lincoln Continental
I have a Sansa 4GB. It has been a great machine. Lately, however, when I try to turn the volume up or down, there are problems, it does not repsond or the sound fades in and out.
Hi, first you will need to troubleshoot to know exactly what makes it malfunction before you will need to reset the mp3 player.
Pause the Clip before powering off the device and attaching it to the USB adapter. If you turn off the Clip while it is playing a track, it will resume playback when connected to the adapter and prevent it from quickly charging.
Reset the Clip by holding the On/Off switch in the On position for approximately 20 seconds. Release the switch, then attach it to the USB adapter to charge it. This process can help when the Clip does not appear to be working at all.
Reload the Clip's firmware (available on the SanDisk Web site) if your MP3 files play correctly on your computer but do not play correctly on your Clip.
Enter the "Settings" menu on the Clip and select "Format" if you are not able to transfer any files onto the device. Be warned that this process will delete all of the current content on your Clip.
How to Reset a Sansa MP3 Player
With a Sansa MP3 player, you can easily listen to music wherever you are. Like most computer-based devices, Sansa players can sometimes "freeze," which will effectively stop the device from playing any files and from obeying buttons. Luckily, it's a quick and near effort-less challenge to unfreeze it and make it work again.
Instructions
Reset via command
Push the "Power" switch downward into the "Hold" position.
Press and hold the "Menu" and "Record" buttons at the same time until the device resets.
Push the "Power" switch upward all the way to turn it back on.
Reset via switch
Grab a steady hold around the device.
Push the "Power" upward and hold it there until it powers off.
Power the device back on by releasing the power switch and then pushing it upward again.
Force reset via power-cutting
Unscrew the screws on the back of the device (or simply push the lid off if it is a model without screws.)
Take out the batteries from the slot and wait until the screen goes black.
Insert the batteries the same way they were mounted and attached the lid again.
Push the power switch upward to turn on the device.
Tips & Warnings
A good idea to stop Sansa devices from freezing is to always make sure that the player's firmware version is up-to-date. Download the firmware updater software from the Sansa website (see link in Resources).
Hope it helped.
Feb 23, 2011 | Audio Players & Recorders
After charging my sansa clip the unit will not turn on and I believe the battery must have died. How do I change the battery and where do I buy a battery
you should have some electronics experience before attempting a repair like this
rip off the black rubber back
if yours has screw righty tighty lefty loosey
if not cram a small screwdriver in very very carefully and break the back off without injuring yourself
than locate battery pack [looks like watch batteries
unsolder/UN-clip
take battery pack to radio shack [might as well get good ones]
now do the above steps backwards
super glue or black electrical tape [i used that]
or if you really want to impress gray duct tape maybe you could even bedazzle the project?
really its a throw away product i got out the magnifying glass and read the very not-so helpful owners manual that came with my Sansa view
hope this helps please vote
Nov 30, 2010 | SanDisk Sansa Clip MP3 Player
The sansa clip got stuck on
try contacting sandisk or something and ask them
Mar 21, 2010 | SanDisk Sansa Clip MP3 Player
My Sansa Clip won't turn on even thought the battery is full.
Unfortunately there was a manufacturing flaw with many Sansa Clips which caused one of the battery leads to detach from the battery. A symptom of this is that the Clip will turn on and charge when connected to an external power source, such as USB or an AC adapter, but will not actually turn on using the internal power source (eg, the battery).
If your Clip is still under warranty, you should return it for a refund or an exchange.
Feb 17, 2010 | SanDisk Sansa Clip MP3 Player
It wont turn on ive tried to reset it and it only turns on on the computer or when i charge it
thats a generic problem with SANSA Clip....the battery wire must have come off....if you're confident at soldering,u need to open the unit and solder the wires in the right place....generally the red wire comes off.... the body is held together by clips rather than screws so u need to pry the body with some thin tool.... TRY OPENING AT YOUR OWN RISK
Aug 24, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip mp3 driver
All the software that you need is on the downloads section of this page:
http://www.sansa.com/support/sansa_clip/faqs
-Tha Mp3 Doctor
Feb 26, 2009 | SanDisk Sansa Clip MP3 Player
Computer wont recognize sansa clip mp3 player
Reformat clip with disk utility after looking at it like an external disk. Do this by turning it off. Puting it in lock mode. Hold down middle button as you plug it in.
I am mad at my Clip as it did the same thing.
Screen shot here:
Sansa clip not recognized.
Dec 26, 2008 | SanDisk Sansa Clip MP3 Player
Coby MP-C582 MP3 Player Logo
48 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
