Question about Microwave Ovens
Piece fell off bottom of door.....white long piece about 24 in long how do I put it back on? JVM 1350 002
  • 20 Answers
Would not be happy repairing a microwave door as ( I am an electrical appliance tester ) door seal keeps microwave emissions inside and safe -- Ps microwaves should by health & safety law be tested annually for safety - ie emmision level / earth leakage etc
Posted on May 26, 2010
GE space maker microwave jvm1350bw002. Handle broke off at the bottom. I am looking to find a replacement hand determine if I can replace and if so are there instructions on removal of the handle?
On all of the JVM series I have seen you have to open the door and look on the inside perimeter of the door. There is a sort of thin, sort of Plastic, choke seal that goes around the inside of the whole door. Toward the outer edge. You have to take a butter knife or a smallish screw driver to lightly pop that part out of the slot it is popped into. The screws for the door handle are under that choke seal. Work around the whole door until you get that part out, Get one piece to lift up then keep working artound the whole door until it comes out. Then set it aside somewhere safe as to not let it drop or fall to the floor as it can break. To reinstall the choke you just align it to the slot where it came from and then start pushing it back into place. It has little hooks on the edges and it will snap back into place
Oct 15, 2017 | GE Microwave Ovens
Two screws fell out of the bottom of my microwave door. I want to take the door off to replace the screws. Am I going to have surprises when I take the plate off that holds the door?
It might be easier to open the door, swing it out and get down under it and put the screws back in from the bottom. The less you have to remove, the less likely you are to have something else go wrong.
Give some more info.
Make/model/serial and we'll try again. No promises.
If you get it fixed and it happens again, put some thread locker on the screws. Purple will do.
Sep 16, 2017 | Microwave Ovens
Microwave door handle broken
That's correct the door has to come apart. Just be careful that screen is actually a choke to keep in any microwave radiation. Put everything back exactly as you took it apart.
Good luck
Feb 14, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
The door on my GE advantium 120 fell off and I need to reattach it
take off the top vent cover , should be three screws ...hang the door provided nothing is broken off the door or the microwave.. after hanging put the vent cover back on. If your model has a little clip/postage size at the top hinge or if you think there is something missing at that location you may need that to keep the door from coming back off... It can be bought on line if your model needs it. some do and some don't if you found something near that area before the door fell off... then your model had one..
Nov 06, 2011 | GE Advantium 120 Convection/Microwave Oven
How do I remove my ge jvm 1653 microwave?
Clean out the cabinet above the micro wave and you will find 2 or 3 bolts that secure the unit (MW) to the bottom of the cabinet. They will normally be towards the front of the cabinet.
I always put a towel or cardboard over the surface of the range for protection and a place to set the MW once it is ready to come down.
Have someone either hold the MW up by putting pressure upwards on the front of the MW or take the screws out. (don't forget to unplug the MW)
Gently let the front of the MW fall forward about 6" to 8" and lift the back of the MW upwards and it will release from a mount that is attached to the wall.
You may feel a little resistance as it might be duct taped to the exhaust going up or out the back.
Be aware that these older micro waves can be a little heavy and it is recommended that 2 people are used to do this.
Apr 09, 2010 | GE JVM1653 Microwave Oven
Microwave oven door heavy
If one of your door springs has failed, you will need to replace both, as well as any associated hardware that has failed.
You can find links to helpful exploded view diagrams and part ordering help here.
Nov 28, 2009 | KitchenAid Microwave Ovens
My frigidaire microwave door is sagging and is about to fall off
EASY get a machine screw, nut with washer. I believe I used a 1/8" machine screw.....(find something small to fit in the hole on the bottom hinge.
First step, take 3 screws off bottom to expose hinge area. Have someone hold it or support it so wires to the light do not pull out,.
Pop the machine screw through the front and then with your fingers get the washer an nut and tighten down.
If you want the professsional look. Paint the machine screw white first with a enamel white paint.
Sep 03, 2009 | Frigidaire PLMV169DC Microwave Oven
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
Need to dissemble microwave oven door GE model JVM 1631 BB 002 to remove spider.
Remove the inner strip around the door called the choke. If there are no screws visable it just snaps in place and does break if you are not very careful. This will give you access to the screws holding the outer frame piece and handle on. keep in mind, any repairs done to the door will necessitate a RFe leakage inspection. Boil some water on the front burners and cook the little guy and leave the door alone.
Eric
Jun 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Front vent fell off
This should be a very easy fix. I assume you are talking about the plastic vent grill on the top of the oven above the door. There should only be a couple of screws holding it in from the top. The grill then should tilt out from the top first then from the bottom to remove. Since you said that it had fallen off, it sounds like the tabs where the screw holes are have broken off. This is a common problem. You can buy the part by ordering from the manufacturer, or from most repair websites. All you need is the model number from the microwave. Good luck.
Jun 19, 2007 | GE JVM3670 Microwave Oven
Microwave Ovens Logo
51 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
