Question about Kenmore 22422 Top Load Washer
I have a kenmore electric dryer #86671100 it seems no air is exiting the dryer it gets warm, and the drum rolls just no air passing. I checked the screen it is clear what next?
    Problem Solver:
  • 17 Answers
Open the door, keep lid switch closed.
start dryer, does the drum roll? if so then
your fan on the motor may have broken
if drum does not roll you have a broken belt
either way you need a tech.
Posted on May 26, 2010
Drum gap
what is the model number?
Dec 09, 2012 | Kenmore 83142 Electric Dryer
Won't tumble. Drum won't roll. How do we open it
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 11, 2011 | Kenmore 62702 Electric Dryer
There is condensation building up in my dryer drum, cleaned lint hose there is no water in vent hose where is it coming from
check the rest of the exhaust system ther is a clog between the end of your flex hose and where it exits outside,to ck run the dryer and check for airflow at outside vent.should feel pleanty of warm air coming out vent
Aug 05, 2010 | LG DLE2512W Electric Dryer
Dryer takes extremely long time to dry
Dryers work on heat and air flow. If the machine is getting hot(clothes are warm) check the vent duct, is it smashed flat or bent sharply. Is there air comming out where is exits your house. Is it clogged. Check your vent.
If this was helpful Please leave feedback. Thanks SnugglePants
Oct 20, 2009 | Kenmore 62602 Electric Dryer
Kenmore 90 electric dryer drum does not turn
Yes it should turn by hand and may be easier one direction than the other. It could be as simple as something stuck in the blower preventing the fan from turning. This also stops the motor from turning. Worst case is a froze bearing on the motor but I would pull the fan cover off and see what is in there.
Eric
Let me know what you find as I have found some very interesting things in the fan over the years....
Jun 09, 2009 | Kenmore 659 Electric Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore Dryer makes Noise Model 86671100
Very few of the tubs are true to round. You stated it has made the sound since you've owned it. Observe and listen to see if you can determine the closet area to the noise. Usually moveable parts get louder over time. Your problem could be a number of things. I would start by adjusting the bottom leveling feet and be sure it is level front to back as well as left to right. Other items could be drum seal gasket bearing, rear felt seal, rear drum support roller, belt tension pulley, blower wheel, blower wheel housing, front drum glide bearing, shaft drum support roller, bracket for drum support roller, front ring bearing kit, pully on the motor, or even lose cabinet housing bolts.
Use the below link to refer to on how to get inside:
http://fixitnow.com/2003/11/appliance-tip-of-day-dryer-disassembly.htm
Nov 07, 2008 | Kenmore 22422 Top Load Washer
Kenmore dryer
could be;
belt slipping
over loading
tumble veins inside drum broken
Dec 13, 2007 | Kenmore 62802 Electric Dryer
Clothes not drying
A couple of possibilities to check. First, is the lint trap empty? If so, then the symptoms point to hot air bypassing the drum. Look for broken or misaligned plastic ducting inside the dryer itself. Check the exhaust air for moisture, as that is a better indicator than temperature. Don't forget that towels hold an enormous amount of water, & can be extremely long in drying, especially if not spun enough.
Jul 10, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore 22422 Top Load Washer Logo
66 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
