Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
It won't spin and I get a error message of 5 d?
    Problem Solver:
  • 17 Answers
Open lid, check that the tap to contact lid switch actually allows machine to work.
Jam a pencil into the slot to see if it will
come on, if it does then you need a lid switch.
Posted on May 26, 2010
My LG washing machine door won't open
UE is unbalanced load. Unplug machine for 5 minutes then plug back in. That may cause it to unlock.
Oct 14, 2017 | LG Washing Machines
Tricity Bendix AW1260W - drum won't turn - 5 beep error repeats
Washer motor control board failure is the likely problem, also check all connectors for signs of burning. Also test the washer motor.
Apr 24, 2017 | Tricity Bendix AW1260W Front Load Washer
Won't spin and water is left and error message 3d
Please check the program controller unit and also the drain pump which could be clogged.
Check this link for tips and advice : www.espares.com
Jun 25, 2012 | LG WM2688HWM TROMM SteamWasher
Why is my Miele Novotronic w1512 saying Drain fault?
I have the same problem, i have cleaned the filter area and there was a plastic sweet wrapper in there also. However, I have put the machine back on an express cycle ans still have the error message coming up?? Drain Fault! I then tried to spin and the spin cycle wasn't working eithet. Whilst the machine was still on i patially undone the filter cap and removed a full tray of water, it then began to spin. What could yhe problem be?
May 21, 2012 | Miele Washing Machines
Won,t spin
A LD (Long Drain) error code means that (more or less), the drain pump is failing.
May 11, 2012 | Bosch Washing Machines
Cd in02 lincoln ls light comes on ( cd error ) wont work or eject ??
This can be from a couple things that caused this. Most the time and 99% of the time that causes this is the cd driver is dirty, which some times it just spits it out after error message comes on. AND in your case, it is staying in there spinning and reading error, and won't eject. One way that is possible to have this kick out is, to unhook battery, wait 5 minutes, and re- hook battery up, and sometimes it will trigger it to eject. If not, you do not want to start forcing something in there, it could cause more damage. You would then, i suggest , take it to car stereo shop as they have all kinds of methods to check it out and eject cd and figure out the fix method. Which could be as simple as a good cleaning, or cd itself was bad, or mechanism is screwed up.
I hope this helps Mike.
Oct 23, 2011 | 2002 Lincoln LS
Hi, I have an LG 1412RD washer dryer. I received the DE error message so opened the front to access the door lock and plugged in the electric socket which seemed loose. Now I am getting the OE message...
http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WD-1412RD&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WD-1412RD&initialTab=documents&targetPage=support-product-profile#
Owners manual above. LG washing machine error code – OEThe LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn’t pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Apr 10, 2010 | Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
97 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
