Question about Zenith Z50PX2D 50 in. Plasma HDTV
Black out screen
Sounds ok , channel change ok , only its black out screen
THIS SEEMS TO BE A Y BOARD PROBLEM REPAIRE WILL COST 350 DOLLARS MIN
Posted on May 31, 2010
Sanyo TV - black screen, sound find
The black screen on your Sanyo TV is symptomatic of power supply failure
Jun 03, 2013 | Televison & Video
Soft "Pop", Then Black Screen. Sound is OK.
First check the inverter for any burst capacitors and the display boards.
Aug 28, 2012 | Toshiba 20DL74 20 in. EDTV-Ready LCD...
My vizio1080p full HDTV is black i caN change channels and the sound works it is just a black screen
Consider having a shop look at it as only boards are sold for this set and guessing and installing them can get expensive.
Aug 26, 2012 | Televison & Video
No data is sent to the screen
When the screen goes completely black, shine a very bright flashlight closely at the screen. If you can see the image, then the most likely problem is that the backlight inverter has failed.
The inverter is a circuit board that works like a flourescent light ballast. If the inverter fails, there is no backlight, and the screen is black.
Since the invertor is a high-voltage component, I would also listen for any unusual sounds associated with the failure: e.g. buzzing, whistling, popping.
To rule out some sort of connection failure, see if you can recreate the failure mode when using the TVs internal setup menu. The setup menu does not rely on any external inputs....of course neither does the volume control or channel indicator on the screen.
Oct 07, 2009 | Philips 32PF7320A 32 in. LCD Television
Black out
Try turning off the Closed Caption..
Feb 03, 2009 | Polaroid TLA-01511C 15 in. LCD Television
DS204D-S26 No Picture Soundis OK
check the power supply proper voltage supply
Sep 21, 2008 | Sova Digital DS205-S32 Television
Tv screen not work
No picture, FR406 ok
Check the video output amplifier stage for failure
Display dead rest of functions ok
Change transistor Q1701 on Timer operation board
Nov 24, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Pls more info; what do you mean tv on, picture froze? you are watching on tv chanel, do you use cable? I can help you but need more details.
Aug 29, 2007 | JVC AV-32D305 32" TV
How to get rid of a black screen on my tv. sound is ok
If you mean that you get a black box, with a little of the picture visible around the edges, then your closed captions are on and set to TEXT. This puts a black box on the screen about 10 seconds after changing the channel. Go into the menu and turn off the closed captions and the picture will be back to normal.
Jul 07, 2007 | JVC AV-27530 27" TV
Zenith Z50PX2D 50 in. Plasma HDTV Logo
148 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
