Question about Dometic Rooftop RV Air Conditioner
The cover on my 57915.010 is cracked and broken on the top of the trailer and I would like to replace it. The unit works great inside but looks awful on the outside. Can I purchase only the cover anywhere??
I have a travel trailer with a coleman 7300 roof top ac unit. the unit will blow cold air but water leaks thru the plenum. i was told by the previous owner that it needs a new seal. i would like to fix it...
If it's leaking inside where filter cover is, then real good chance the drains being plugged is the only problem. If water (condensation) not running off roof when operating in cool mode, then I'd bet drains, which are located under unit on roof, and you should see them sticking down like buttons. They have a hole in side that needs cleaning with a pipe cleaner or similar to open them up. If need be, shut off power to unit and remove top cover on roof unit and look for the drain holes in base, and clean them out. If water comes in while raining, but AC not running, then it's gasket. That is remedied by removing ceiling assembly (just screws) and 4 bolts that pull/hold the upper and lower assemblies together, unplug wiring to upper unit, and simply lift it off, change gasket and re-install. Tighten those 4 bolts equally when gasket is aligned properly over hole, only until gasket is approx 1/2, original thickness. Plug harness back in and your done. (about an hours work.) Only other thing that may be wrong is styrofoam drip tray for cooling unit, under cover on roof may have a crack , allowing condensation to leak in. If that 's the case, you can try to find a sealant compatible with styrofoam to seal those cracks.
Nov 14, 2010 | Dometic Rooftop RV Air Conditioner
Leaks inside when running
you might have a drain line plugged up...or a dirty evap coil...call if you need direction an what to look for...
May 12, 2010 | Dometic Rooftop RV Air Conditioner
The inside of the dishwasher bottom is a film like covering. it is cleaning dishes great, but the stainless steele bottom looks awful. HELP!
this is usually scale build up and can be remove by using lime away. and run the unit in an empty cycle. there are dishwasher cleaner that can be bought from local parts or home improvement store
Mar 28, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Broken screen on Blackberry Curve needs to be
you can use warranty or send it to the company and they will charge you if you hadnt taooken the warranty
Sep 12, 2009 | RIM BlackBerry Curve 8310 Smartphone
2005 Ford F 250 Trailer signal and Brake lights not working on the right side of the trailer. Left side works great. The Truck lights work great as well. I have switched the fuses for the right and left...
Check the light mounts on the trailer's right side. It sounds like the ground is not connected on that side or the light bulb socket is broken or loose. A bad groundis usually caused by either a broken wire or rust under where the light is mounted. If there is rust, clean with a wire wheel then remount the light and test.
If the bulb socket is cracked or loose to the touch, replace the light mount but clean the mounting area as above.
Sep 07, 2009 | 2005 Ford F 250 Super Duty
Ac unit blowing water with air on after a few minutes
2 things to check, one is remove filters on inside & look at front coils to make sure they aren't frosting/freezing up. The other, remove cover on upper unit & check that drain holes in base are not plugged. Be careful of wasp nests when removing cover. If neither one of those is problem, you may have a cracked drain pan, which you can also observe/inspect when cover off on roof unit.
Jul 21, 2009 | Heating & Cooling
My LG VX8300 phone has a cracked camera lens cover. I would like to replace it myself if LG can provide the parts. Can you help with instructions? Thanks!
I repaired mine by using a knife to pick out the old one. Then I opened the back by removing the 4 screws and prying it apart. I cut a piece of clear plastic the size of the lens from a flash memory box, removed the black ring around the hole on the inside and pressed the new lens in, replacing it. I used a little glue to hold it in and put the black washer on top of it. Then I closed up the phone. It works great. With the new lens inside, it won't get broken again.
Bill
Sep 28, 2008 | Cell Phones
Air conditioner leaks/drips from filter inside travel trailer
Either your 14"x14" a/c gasket is lose on the roof allowing the condensation to flow into your RV or you have a cracked condensation tray under the evaporator. I'm guessing the later
JGRV
Aug 01, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
117 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
